Question about Toshiba Office Equipment & Supplies
How to print edge to edge usin toshiba estudio2040cse
My toshiba e-studio281c is cutting off the edges when i print
Check and make absolutely sure your paper guides in the trays are closed (tight against paper)
Jan 01, 2013 | Toshiba E-studio 281c Copier
Print head changing
Two screws to remove and disconnect the cables. But take care you have to check the angle which is on the print head. You may have to adjust the position of the print head. The edge must be aligned on the top od the platen. Other wise the printing is fusy.
Nov 01, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Why can't I see my toolbar?/lattop/toshiba
do you mean your Taskbar, Lucia? The bar that holds the open program icons? If so, it may be on the sides, bottom or top of your display. Drag your mouse cursor along the edge of your screen till the cursor changes to a bar with arrows on each end. Then drag it away from the edge of the screen. Then right click on the taskbar and choose lock.
Jan 13, 2012 | Computers & Internet
I had to change the ribbon in our B-472-QQ and now the print quality is very bad. Can hardly read the label. Tried changing the ribbon again, same results. Any help would be appreciated.
First of all.
B472 uses a near edge technology for printing.
You must use Ribbons for near edge head.
- You must use a WAx/resin for paper labels and Resin For Polyester or plastic labels.
You may also have your print head mis-alligned or you are not heating enough
Jul 12, 2011 | Toshiba TEC B-472 Thermal Label Printer
Toshiba estudio 210c
toner missing on that side of developper ( where toner is stored to go on paper) or drum
Sep 01, 2008 | Toshiba e-Studio 232 Black and White...
Problem setting printer server
I have the same problem, does anyone know how to solve it?
May 20, 2008 | Linksys Wireless-G WPS54G Print Server
Fargo Pro-L Not Printing Edge-To-Edge
These direct-to-card printers do not print right to the edge because of the way the print head comes down on the card. There will always be a white boarder on the card especially if your graphics are dense. The only solution to this issue is to re-design your artwork so that the image fades at the edges of the card so the white boarder is not obvious, or purchase a re-transfer printer which will give you true over the edge printing.
Dec 14, 2007 | Fargo Pro L ID Thermal Printer
Epson Stylus DX6000
There might be some problem with the Roller. I think you have to locate and clean the roller.
Nov 24, 2007 | Office Equipment & Supplies
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
