Question about Fanimation Ceiling Fan - 210457
I am looking for the ceiling base plate for a micromark mm9091
    Genius:
  • Fanimation Master
  • 1,617 Answers
Call 1-888-567-2055 ( Fanimation )
Posted on Oct 14, 2013
Recently moved into a property with an alarm. MICROMARK TN 0045903J, it requires batteries. Looking for a user manual.
Maybe the reference it is not correct, here are some examples of Micromark alarms references:
MM9412
MM9492
Try to find the correct reference or model number, contact me and I will help you
Oct 26, 2017 | Home Security
The fan is installed but fell down or looks like it was not completed , what do i do to screw the base from the wall to the base of the fan ?
In a typical ceiling installation, the fan assembly is attached to a downrod which, in turn, is securely attached to a junction box in the ceiling.
Dec 13, 2015 | Hunter (25417) Ceiling Fan
I need to replace the remote sender and receiver for this fan. I have no idea where the receiver is located in the fan motor housing.
Are we talking ceiling fan? Can we be more specific? If it is a ceiling fan it's in the base plate that covers where the fan meets the ceiling
Jul 28, 2015 | Dryers
Where do I buy replacement parts for a casa vieja cieling fan circa 1990 I need the base plate the blades screw into
Hi Paul....Guffans Ceiling Fan Parts in Texas -
Telephone 979 553 3260
Fax 979 553 3391
I hope they are still in business.
Regards,
Dennis
Oct 11, 2014 | Casa Vieja Dryers
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
I recently purchased a home that has Hampton Bay ceiling fans and I am trying to take them down to replace them. Please Help!!!!!!. Do not know how the housing is held on. They are ceiling huggers (very...
There are 3 small screws holding the cover to the base of the fan located at the upper most part of the fan at the ceiling.
Remove these screws and drop the cover plate down.
Turn off the power to the fan,remove the wire nuts,then lift the fan out of the support yoke.
Sep 03, 2010 | Hampton Bay Heating & Cooling
My Nutone 8814R motor went out on my ceiling fan and i just ordered a new motor. My question is how do i take out the old one and replace it with the new one. Will it be easy to do myself? Also is there an...
The good news is that this is a relatively easy item to remove and replace, as they make a replacement fan/motor unit (sub assembly) that you can swap out for the old one.
All you need to do is pull down on the trim vent plate and then squeeze the wire retainer clips together to remove the grill/trim.
Once you've done that, you can unplug the fan portion of the exhaust fan unit from the base enclosure. Now simply remove the screw or nut that holds the fan and mounting plate into the enclosure and simply pull it down and pivot it out of the enclosure - you might have to push in on the side of the enclosure where you removed the screw/nut to get the fan and metal plate out of the cabinet.
The replacement fans usually come with a new metal mounting plate that fits many of the older exhaust fans, but if your's looks different or doesn't work, you can remove the fan and install just the fan motore onto your old metal fan mounting plate.
Instructions are typically included in the replacement unit packages. This is also very simple to do with only 2 screws holding the fan onto the mounting plate.
Once you're done, simply hook the edge of the plate back into the fan enclosure and then push it up and fasten the mounting screw/nut onto the plate and plug the fan into the ceiling enclosure and replace the grill plate and you're all set!
Hope you find this Very Helpful and best regards!
Oct 12, 2009 | Broan-NuTone Deluxe 8814R Ceiling Fan
Looking for light kit for ceiling fan
if you can manage doing some mechanical stuff and electrical connection, this can be done, however it is difficult to say what kind of fixture will fit your existing fan, say for example the mounting plate, this will be a little tough job, there are a lot of light kit available in home depot, the only problem is if you can manage to connect this electrically and mechanically.
let me know your model and if you have a remote control base type.. cheers
Jul 28, 2009 | Dryers
I need a celing mounting bracket for 52in 5 blade encon ceiling fan. where can i get one the model # is 94b03-0395
I just uninstalled my 29 year old Encon flush mount fan light. The number on the base is E101004. It was a lighted base. The mount bracket is built into the base. It is the 4 prong and hook style the allows the motor to hang suspended while wiring and then swings up. There is a glass ring that is sandwiched between the base plate and decorative bottom.
It's the only usable part besides the 4 glass light covers. You can save this from the land fill if you haven't purchased a replacement fan.
May 08, 2009 | Encon Industries 78716 Contempra Ceiling...
Fanimation Ceiling Fan - 210457 Logo
35 people viewed this question
Top Fanimation Dryers Experts
Michael Galve
Michael Galve
Paul Bade
Piyal Perera
Piyal Perera
Are you a Fanimation Dryer Expert? Answer questions, earn points and help others
