Question about EliteGroup Computers & Internet
Motherboard not working powersuply ok - EliteGroup Computers & Internet
  • 3,799 Answers
Replace the motherboard.
Posted on Oct 14, 2013
Intel fw82801db
on your board theres is a spot where the fan from the cpu goes it saids cpu fan on the board near by cpu socket
Aug 06, 2013 | Asrock Computers & Internet
My motherbord(MSI 865 PE NEO)... suddently shutingdown it self and then its broken, i cant turn it on, i ve change the powersuply... but it didnt work..
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 26, 2011 | MSI 865PE Neo2-V Socket 478 Pentium 4...
My rode k2 di box has stopped working. It powers on but I cannot get the mic to work with the di box. The mic works on my friends k2 di box but mine won't work.
Since I can't find a DI box on Rode's web site, are you perhaps talking about the power supply for the K2 tube microphone? If so, it sounds like you have a powersuply that is broken.
Since you have proven that your mke is working OK, how about the power supply it's self? If you swap your friend's and your power supply, does his mike work?
If so, then you may have a bad input on your mixer. If not, then your power supply is bad. If it is, I would reccomend that you check with Rode about warranty and or RMA repair.
Dec 13, 2010 | Rode K2 Professional Microphone
Powersuply is not
powersuply is not ? Please repost the question.
Sep 07, 2010 | Samsung SyncMaster 510N 15" LCD Monitor
UPDATING BIOS... DISK BOOT FAILURE INSERT SYSTEM DISK
This happens because the boot process fails: either because in the boot order the floppy isn't mentioned (put it first) or the bootdisk isn't good.
BTW you should update the BIOS only if you have problems, like a new processor not being recognized.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
How can i switch the powersuply on with out
Most newer computers will have to be hooked to the MB to recive the signal to power up.
Sep 11, 2009 | Computers & Internet
Intel d845gvsr m/b did not power on with good powersuply
Hello, make sure that the power supply is propertly connect to the mobo and look for the cmos jumper and try moving it, also take out the cmos battery and wait 2 minutes. Thanks let me know if it helps.
Nov 26, 2008 | Intel D845GVSR Motherboard
No power up no post no nothing on dimension 3100
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. It sounds like you have isolated the problem to the motherboard since you removed everything but the board and power supply. You may be able to locate one by browsing the internet. Just type in “DELL Dimension 3100 motherboard” and see if you can locate one at a reasonable price.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You
Sep 27, 2008 | Dell Dimension 3100 PC Desktop
4 error beeps on a HP DC7600
this sounds like the ram problem open the pc or mac case make sure you remove power cable from powersuply and once inside look for your ram sticks and have a peice of toilet tisue and some cotton buds to hand carefully remove your ram sticks and place them onto the toilet tissue and one by one you will clean the contacts along the ram stick holding them by the sides using the cotton buds when you have cleaned both sides of them place them back onto the toilet tissue then place one back into the pc or mac motherboard and replace powerlead back into power unit then power up pc or mac then if this gives you beeps place this to one side repeat for all ram sticks to find out if you have any that need replaceing.
and close up case with ram stick that are ok.
Best of luck with this one
Jul 08, 2008 | Computers & Internet
Computers & Internet Logo
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
