Question about Sunbeam GCSBDS-212 Digital Steam Master Professional Iron
My GCSBDS-212 will not get hot - Sunbeam GCSBDS-212 Digital Steam Master Professional Iron
Sunbeam iron model gcsbcs-212 troubleshooting unit keep turning off while ironing
The iron is getting to hot internally and setting off the high limit switch. Since these cannot be repaired by design, you will have to replace the unit.
Mar 23, 2017 | Sunbeam Irons
I cannot get my GCSBDS212 steam iron to make steam.
Have a look at the steam holes in the bottom, they should be nice an clean with no blockage. If they are blocked up you will need to remove the calcium buildup inside the iron. Get some LimeAway at HDepot, pour it into the water reservoir, let sit overnight. Next day turn the iron on and try steaming on some old papers covered with an old rag or towel, once it starts working steam for a few minutes, then unplug, drain it, put in clean distilled water and flush it out until the steam comes out clear. Use distilled water not tap water, it has much less mineral content and will be less likely to plug it up. Most pharmacies and Walmart sell distilled water. ! gallon about $1.25.
Feb 05, 2015 | Sunbeam GCSBDS-212 Digital Steam Master...
How to disassenble bcsbcl-212
laundry.manualsonline.com has free manual.
Jun 19, 2014 | Sunbeam 4214 Iron
Cleaning non stick soleplate on iron
Soak in vinegar until softened wipe off. If needed use rough side of a sponge or SOS pad to aid removal.
Jan 25, 2014 | Sunbeam Classic Iron - GCSBBV-212
How to work Conair Volume Hot air curling brush
has 2 parts: a) use heatings elements b) blower for supply the hot air
God bless you
Jan 25, 2013 | Conair Volume Series Hot Air Curling Brush...
Handle gets to hot
you just open it and look for whats wrong in your iron.... or the handle in it is not compatable in the iron soo put some leather on the handle...
Jul 24, 2009 | Irons
What is the temperature of the synthetic setting?
I would use some scraps of fabric and transfers to do some trial and error experimenting.
Keep in mind that the iron will not produce steam until the internal temperature is 212 degrees farenheit.
good luck with this.
Jan 06, 2009 | Rowenta Professional DM890 Iron with Auto...
Sunbeam GCSBDS-212 Digital Steam Master Professional Iron Logo
Top Sunbeam Irons Experts
Tony
Henry  Thomas
Henry Thomas
Wayne Fellows
Wayne Fellows
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
