Question about LG Microwave Ovens
I jus brought an LG microwave oven (MODEL MC-7847BS). The problem is that during cooking it suddenly stops, the lighting bulb went dark and there is the display that read E-02 on the LED display. Pls help to solve this. is it the Microwave that not gud or am using it wrongly?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 54 Answers
That usually indicates a keyboard error...not a good thing...take it back and get a new one.
Posted on Apr 24, 2009
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
I cooked oatmeal and after 1 minute, the microwave stopped and went dark. It has ben about 10 minutes and nothing..........help!!!!
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Mar 19, 2011 | Jenn-Air JMC7000 Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
MICROWAVE LG MODEL MC-806BL LAMP BLOWN
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
In the UK, LG customer support is here. You may find your owner's manual online here.
Dec 19, 2008 | Microwave Ovens
Light fails to operate with door open
If the light comes on during cooking then the bulb is ok.. in all probability the problem is the door switch that senses when teh door is open and activates the light... Hope that helps..
Aug 15, 2008 | Frigidaire GLMV168K Microwave Oven
Light inside microwave dos not illuminate
bulb to be replaced with same similer, if it is not available please get me touch, 9791055855, india, The bulb cost is Rs: 125.00
G.K.Mahendran
Aug 01, 2008 | GE JVM1340AW/BW/WW Microwave Oven
Microwave Ovens Logo
302 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
