Vacuuming window type aircon unit
Give me the procedures on how to vacuum a window type aircon unit
  • 1 more comment
  • Anonymous Mar 15, 2014
    what fuse they have
    What is d stands for in window type ac
  • Anonymous Mar 26, 2014
    How to remove the cover of aircon to clean filter of
    Window type LG aircon
  • 113 Answers
There shouldnt be anything on a window unit that a vacuum could hurt but you might wanna be sure there is nothing like dirt dobber nest or something that might stop up your vacuum
Posted on Apr 24, 2009
Aircon comes on when engine under load..ie..accelerating up a hill, even though it is off on the dash
Your vacuum mode control switch is either leaking in the AC control panel (on the dash) or the switch is getting a low vacuum signal due to a pinched vacuum hose or defective vacuum line or vacuum storage canister under the hood..
Mar 23, 2016 | Cars & Trucks
I need a Vac bag for this unit
Hey, this is Jeremy with Crucial Vacuum,
Unfortunately, you did not specify what type of vacuum you were looking to get replacement bags for. I have attached a link to the Crucial Vacuum website where you might be able to find the right type of bags you are looking for.
http://www.crucialvacuum.com
You can purchase replacement bags, filters, and accessories for a wide range of vacuums direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10. We strive to provide our consumers with the lowest possible prices and believe that you will be very happy with what you find.
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 18, 2015 | Vacuums
How to install split type aircon?
Plan the location of your outdoor and indoor unit. Make openings for the pipes and wiring's that should be accessible for repairs or maintenance. Never place the condenser near the walls, and follow the allowable clearance from the walls. Same thing follows for the indoor unit make allowance from the ceiling and it should be tilted to drain the water from the drain pan. Make the piping and wiring connection following the suppliers recommendations. Drain pipe should be lower than the wiring installation. Do not use seal tape for threaded connection, only apply refrigerant oil and tighten all nuts. Leak test or vacuum the lines from the valve fittings outside the condenser to the evaporator( in and out of the evaporator ). If vacuum or pressure stays unchanged for an hour, there is no leakage. If you applied vacuum, just fully open the service valves. If you pressure test the line with Nitrogen, release Nitrogen gas by loosening a little the bigger pipe nut from the condenser until no pressure comes out.Then open the small service valve from the condenser a little until pure freon comes out of the loosen big nut and then tighten it. Full open all service valves and unit is now available for operation with power supply.
Sep 03, 2011 | Friedrich (5TF37) Split System Air...
My 1996 nissan lec engine shuts down when the aircon is turned on, i already tried adjusting the idle. the aircon functions at high rpm. can you suggest a solution.
Check the a/c actuator, round metal with rod at the bottom, vacuum hose at the side. Located beside the carburetor.
When you turn on the A/C it will push the idle up( via vacuum system ). It has an adjuster at the top to set the right rpm of your engine.
Test also the vacuum hoses and A/C vacuum switch, just follow that black 1/4" dia. hose( vacuum hose ) and check the system.
If you have no idea on repairing the vacuums and the actuator, my suggestion would be to bring your car to the nearest A/C technician to have him repair it.
Thanks for asking FixYa!
Aug 09, 2011 | 1996 Nissan Sentra
What to do about vacuum advance on distribuitor , what to do wiyh all vacuum hoses that are appaerently abandoned?
Hi there .
Well vac hose comes from distributor to inlet manifold so run a small hose to that ,
Another is for heater /aircon
A bigger one for the vacuum to brakbooster
Jun 13, 2011 | Datsun 210 Cars & Trucks
How to add freon to central air conditioner
dear sir
if you have some knowledge about air conditioner system then first connect hose with suction side of aircon pipe conector(valve) with Gage and second hose with cylinder and GAGE .during of this you must remember don,t forget to open valve before START this job then make your ac unit vacuum it should be 18-20 micron after vacuum fill freon (approxmatily 60-65 pci)
and check your aircon system,s evaporator all pipe has been cold not and any pipe is getting ice on it .if its reach pressure 60-65 psi AND YOUR AIRCON BLOWING COLD AIR then it,s good the close by cup nut on the connecting point and remove hose from connector and disconnect Gage from system .
(but please don,t do if you have not proper knowledge it can be dangour)
warning: if you don,t have knowledge to do this please don,t try
thank you
hope answer the question
Aug 22, 2010 | Whirlwind FH-778 Air Conditioner
How to perform a vacuum test
if you want to perform a vacuum test on your aircon system, you will need a vacuum pump and a pressure gauge.
Sep 07, 2009 | 2003 Chevrolet Suburban 1500
Replace belt - how do I get off the interior housing
Rather than try to explain this procedure by typing it, I'll give you a link to an online guide with pictures that show the procedure. You'll see two links on the page regarding belts , look at both and use the one that is closest to your model. Hope this helps.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Aug 21, 2009 | Hoover Soft and Light Supreme U4266-930...
Where do i put the clean water at and the cleaning solutions
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=695898
Generic problem for all Vacuums
Where do I put the
Posted by nichole171 on Jun 22, 2008
Where do I put the clean water at and the cleaning solutions
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not sure what type or brand name for the type of scrubbing unit you have , but the clean water and the cleaning solution generally go into the same container and then it will release onto the carpet or floor.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 22, 2008 | Vacuums
The dial regulating suction does not seam to work the vacuum works constantly on the full power and the light indicating overheating stays on.
This would depend on the brand and model number you have – without knowing the model or brand of vacuum you have it would be hard to give an accurate answer – the over heating light could indicate some type of clog or blockage and may have nothing to do with the dial to regulate the suction – that merely is a height adjustment …. As this does happen to most vacuums that the overheating light comes on – if there is no problem have it looked at from your local vacuum dealer or repair shop would be the best advice that I could give you.
Apr 15, 2008 | Vacuums
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
