Question about Caterpillar CAT 3126B 3126E ENGINE WORKSHOP REPAIR SERVICE MANUAL Bonus
3126b engine skipping - Caterpillar CAT 3126B 3126E ENGINE WORKSHOP REPAIR SERVICE MANUAL Bonus
Cadillac skip
If the check engine light is on, you may want to check for a engine misfire code which cause the engine to "skip".
May 27, 2014 | 2008 Cadillac Cts
Tip
How to Diagnose Your Engines Skip
Sometimes it's easy to tell if your engines got a skip. Other times its not so evident that a skip is what's causing your engine problems. Even when your know its a skip, deciding on which cylinder is the problem. This how to makes finding that problematic skip easy as pie.
Instructions
Things You'll Need:
infrared thermometer
Step 1
First thing you need to do is get yourself a infrared thermometer. Sounds fancy but they are not all that expensive, you can find them for under 50 dollars. These things are handy for so many things, trust me you will wonder how you ever got along without one.
Step 2
Now you'll be putting the laser of the thermometer on the exhaust headers where they meet up to the head so make sure you have a line of site to all of your header pipe ends. This works on manifolds as well but not as good. Its still the easiest way to find a skip either way.
Step 3
Now just locate the skip. To do that start the engine and quickly go under the hood with your infrared thermometer. Check each cylinder temperature, the cylinder with the skip will be cooler than the others around it. This works great because it will show you if you have a dead skip or just a cylinder that is running a little cold, all in a matter of mins. Information like this is very valuable for fine tuning and getting the most out of your engine.
on Jan 31, 2010 | Audi 318 Cars & Trucks
Power loss to honda fireblade 929 rry
A WAG, is there water in the gas? Fuel injection systems will pass water in the fuel, if it gets past the fuel filter whereas, in a carburetor water will adhere to brass jets and block the fuel. If the filter has reached its capacity for holding water, water will get through.
In the years i was involved as a motorcycle dealer and also had an auto repair garage, when we had an engine that skipped, i would put a n old style neon timing light in the ignition circuit, either between the distributor and the coil or later at each spark plug, in turn and run the engine or drive the car or bike. If the light skipped when the engine skipped, I knew it was an ignition problem, if the light did not skip when the engine skipped, i knew it was probably fuel.
In the work you had done, you did not mention fuel filter, so I suspect some foreign material passed through and is effecting one or more injectors. A poor spray pattern can cause a skip. Run the engine skipping to get the pipes hot, shut it down quickly and using a squirt can squirt a bit of oil on each pipe and watch the smoke. The coolest pipe reveals the skipping cylinder. Pull the injector and observe for dripping and the spray pattern. If it is good, and the neon timing light did not skip on that cylinder, you may have a valve train problem.
Jul 28, 2017 | Honda CBR 929 RR Fireblade Motorcycles
Engine seemed to skip at about 70 mph and service engine light came on. Then seemed to skip several more times at different speeds. Ran fine. Just continued to skip as we drove.
hi the engine is not skipping the problem is the engine is miss firing
that is caused by a bad .spark plug or -wires-or coil pack - when was the last time the
car had a tune up . check spark plug connections
Jun 12, 2011 | 2005 Nissan Altima
Engine skips
That sounds like a dirty EGR valve...I had the same problem. Change the EGR valve and your problems shall be gone.
Jan 12, 2010 | 1995 Cadillac DeVille
Engine skipping
well i had a 98 dodge neon that seems like it did the same and it said engine misfire and all i did was due a tune up change spark plugs and wires.
May 21, 2009 | 2007 Dodge Charger Daytona R/T Sedan
Engine skips
When you press the clutch the engine control computer senses the clutch is in and adjusts the idle speed, maybe the idle speed control motor is dirty and sticks, this will almost feel like a skip or miss, do you have any trouble codes?
Dec 03, 2008 | 2000 Mitsubishi Eclipse
Engine Skipping, emmission issue?
check the catalytic converter first...it will make it sputter
Jul 05, 2008 | 2003 Ford F150 Regular Cab
Caterpillar CAT 3126B 3126E ENGINE WORKSHOP REPAIR SERVICE MANUAL Bonus Logo
70 people viewed this question
Top Caterpillar Photography Experts
Tony
Are you a Caterpillar Photography Expert? Answer questions, earn points and help others
