Question about Vacuums
Switched on my dyson dc 14, but suddenly started to splutter, smell of burning, i switched it off and now it wont switch back on. i have changed the fuse.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
Burning smell is NOT good. Sounds like an electrical short in the motor field windings. You'll have to take the machine apart to locate where the damage occurred and see what can possibly be repaired or needs to be replaced.
Posted on Oct 19, 2013
  • macaron28
    macaron28 Oct 19, 2013
    Also, it might have been an electrical short in the SWITCH, which would be MUCH easier to find out and replace. MUCH cheaper too.
SOURCE: Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Posted on Jun 10, 2008
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/
Posted on Jul 05, 2008
SOURCE: dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Posted on Aug 11, 2009
SOURCE: Dyson DC 25 Ball - no power to motor
Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
Posted on Apr 18, 2010
Samyfam
  • 379 Answers
SOURCE: dyson smells of burning when
It sounds like the motor has overheated and has now been irrepairable damaged.
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Posted on Aug 17, 2010
Dyson dc08 not turning on
you can go to: http://www.dyson.com/support/help.asp?article=51&product=DC22-MOTORHEAD-US, this a section for troubleshooting for dyson.
You must clena any clogged from hose, bag.or blockage, Clean the filter. In most time, the machine has a thermic switch or thermal fuse, Inspect or test and replace or reset.
God bless you
Jul 15, 2012 | Dyson DC08 Cylinder Bagless Canister...
Dyson will not switch on
Usual problem is the fuse in the plug. Check the fuse first. If this fails then your problem is either the Switch (Unlikley) or the Motor. Its unlikely the motor would break without warning though. If you have had any burning smells or funny noises recently then its the Motor.
If there are no Smells then im confident its only a case of changing the fuse. Quite common for the fuse to go.
Oct 23, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
The brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
The brushes wont turn,but it has good suction for the hose
you have to remove the bottom cover to inspect the belt. Usually if the brush is jammed, you will smell an odor similar to burning rubber. In the absence of that smell, its likely the belt. Its easy to replace
Sep 20, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson dc14 vacuum cleaner ,the power, off-on switch does not work
Take it back - the power on switch button sounds like its being tempramental and it shouldn't do that. It would have to be repaired.
Mar 31, 2009 | Dyson DC14 All floors Bagless Upright...
Dycen DC 14 Beter bar not turning.
call 866-693-9766...dyson has a five years warranty on their vacuums, you will void your warranty if you do any work
Dec 06, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson upright
hi this is an expensive repair and would probably be cheaper to buy new one the problem you have is with the motor bearings seizing its expensive to repair because when dyson made thes vacs they were made so you need special tool to take them apart so replacing the motor would require calling a dyson bloke out as i found out with mine when my switch failed i tried removing and replacing myself but when the bloke came out he used a thin piece of metal down the side of switch to press button to release switch after i payed him to do this 2 months later i got your problem and called them back they tryed selling me new one as the repair was 50 quid more than a new vac.
Hope this is some help sorry i couldnt give you good news
Jan 08, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC14 all floors.
sept 30,08 bought dc14 all flloor. After 3 to 4 uses it started making lots of noise when on carpet setting. I examined the roller brush and it was cracked at one end. I returned it Oct 13 ,08 and got another dc 14 all floor. Now this one after 2 uses has the same problem only a larger crack in the brush and a small piece of the brush broke off. Very dissapointed.
Jan 08, 2008 | Dyson DC14 All floors Bagless Upright...
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
