AT&T HTC ARIA A6366 CARRYING CASE ELECTRIC Logo
s
sofia safaridze Posted on Oct 14, 2013
When I open my htc aria's camera it's always landscape and when I turn it on 90 degrees it's backwards
Can't shoot in landscape mode
sorry, you have not provided enough information. So, here is a simple answer, hold the camera so that the long side is parallel to the ground, that is landscape mode. Portrait mode is the short side parallel with the ground, thus rotate the camera 90 degrees.
All cameras work the same way, it is the position we the shooter holds the camera.
Cordially
2answers
Unlock htc aria
To Unlock HTC ARIA Phone use Unlock code...Visit the site
Mobile-unlocker.com/htc-aria/rs2wp9/ get Unlock code and get Free Unlocking instructions at Mobileunlockguide.com/htc-aria
and Unlock it step by step...
Free htc arei unlock codes
It's HTC ARIA...You can Unlock it easily using the unlock code..Free Unlock code is not possible to get for the Model...You need to pay for it..Visit the site Simpleunlocking.com/htc-aria/rs16wp9/ get Unlock code at reasonable cost and unlock it from network lock easily..
Htc aria wont fully charge
I had the same problem with my droid 2 before i got rid of it for my iphone. I took it back to the store and they said," the battery is done with its life." lol. i got a new battery and it fully charged after that until i sold it. Also my friend had the same problem but his was his charger.
Hope this helps
4helpful
I dont know how to reset my htc aria
Please note that all data will be deleted from the HTC Aria as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
  1. Turn the power off. If your HTC Aria is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Hold the Power button until the display turns on
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button to select
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the HTC Aria. Once the wipe is complete, the phone will reboot to its factory fresh state.
WHEN i TAKE LANDSCAPE REPLY SHOWS PORTRET AND WHEN PORTRET TAKEN REPLY IS ALSO TURNED 90 DEGREES PLEASE ADVISE
WHEN i TAKE LANDSCAPE REPLY SHOWS PORTRET AND WHEN PORTRET TAKEN REPLY IS ALSO TURNED 90 DEGREES PLEASE ADVISE that Further to crhendo1's Findind's - i have found that if Picture with the EXIF Orientation set to "lower left" (ie one that needs Rotating) is first imported into iPhoto or Aperture and then displayed on the ATV (ie iTunes is set up to share/stream from iPhoto or Apeture)- all is fine - ie picture is displayed correctly rotated.
However, if the pic - left as a Jpeg - is place in a folder - on a Macbook Pro, or a Windows PC - and iTunes is set up to share/stream from that folder - then the picture will be displayed on its side
Futher more - if you then export the Picture from the iPhoto/Apeture Library - and put it in a the folder it is also displayed correctly rotated
for further information visite this website http://newsallworld.com/
Jul 11, 2011 • Cameras
3helpful
5answers
I need to unlock my htc aria
To Unlock the HTC Aria Phone Reach here
Wickedunlock.com buy the Unlock code and Unlock it step by step.....
HTC Aria Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your HTC Aria mobile phones. If you enter over a certain amount of wrong unlock codes on your HTC Aria mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your HTC Aria with a Not ACCEPTED SIM Card.
2. If your HTC Aria asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Aria will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Aria is now unlocked.
*NOT ACCEPTED : We mean, to use a Sim card from a network other than the network your HTC Aria is locked to.
My HTC aria for what ever reason won't play videos Like YouTube or anything when I click on the yield icon It says flash player not supported
Try to open the youtube in the browser(m.youtube.com) instead of app, becaue HTC aria processor doesnt support the FLASH.
I have no service and when i turn my phone off and back on it says sim not provisioned mm # 2
My htc aria phone always says no service when i know i have service in the area, is my phone broken or is there a way to fix this?
My new eos rebel xsi won't let me set it on portrait; instead it sets on landscape for both portrait and landscape
To take a picture in portrait mode, you just have to turn the camera 90 degrees. When you view the pics, the camera will automatically make the picture upright for viewing but it will still be a portrait.
Top AT&T Cell Phones Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
