Question about Rapoo Blade Series E9070 2.4Ghz Wireless Ultra-Slim Keyboard Black
My keyboard automatically "type" "o" button after press once the button. I tried to reset it and changed the battery but the problem did not go away.
When i turn on my computer and try to log it, my computer automatically starts "typing" in a really long password. then when i try to type in my original password it says i need to reset it
try changing your keyboard with another one and see if a particular button or group of buttons are already pressed down on the keyboard and then stuck but if that doesnt work,you need to get an engineer to help you check out your system
Oct 24, 2010 | Computers & Internet
Hi...my wireless keyboard stopped working. I
Yes, press the button underneath the keyboard and thenn the button under the mouse.
Apr 26, 2010 | Belkin Wireless Keyboard/Optical Mouse...
I have a microsoft wireless keyboard and mouse I am trying to connect to my computer I have the mouse working fine but it seems the keyboard is not turning on. I can not get it to connect with the...
It means, your batteries are dead so need to be replaced on keyboard once you replace those the you got to turn it on and once lights comes up then you to to press wireless button for 5 seconds.
once it starts blinking then you got to press wireless button of receiver (bluetooth stack) and once it blinks then your keyboard should be detected automatically.
please post back if any thing changes and vote all answers.
Good Luck.
May 11, 2009 | Microsoft Wireless Laser Desktop 6000 V2...
Keyboard will not type
Have you replaced the batteries, have to ask that question as I had a friend say he didn't know keyboard had batteries.
Normal 0 Turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Dec 11, 2008 | Computers & Internet
Keyboard connectivity
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard. Try typing, should work okay.
Also to Rest/Connect the mouse, turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Nov 30, 2008 | Computers & Internet
My keyboard won't let me type any letters or numbers
Are you sure that they are connected to each other? Try newer batteries. Press the connect button of the receiver for 2 secs and quickly press the connect button of the keyboard or press and hold the connect button of the receiver and the keyboard at the same time for 4secs do this steps over and over until it connects. Heres a tip the light on the receiver will blink onced pressed and if you press the connect button of the keyboard the blinking will stop which means that the receiver picked the keyboard out.... hope it helps
Nov 25, 2008 | IOGear GKM541R Keyboard/Mouse
Keyboard is not working
Oct 21, 2008 | Microsoft Wireless Optical Desktop Pro...
Keyboard (laser)
Did you replace the batteries in the wireless keyboard? If not try doing that first and then use the following info.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Jul 03, 2008 | Computers & Internet
Wireless mouse won't work on hp multimedia cordless keyboard and mouse
Try changing the batteries in the mouse and then press the little sync button of both the mouse and the wireless receiver.
Nov 09, 2007 | HP Multimedia Cordless Keyboard/Mouse...
Rapoo Blade Series E9070 2.4Ghz Wireless Ultra-Slim Keyboard Black Logo
Top Rapoo Computers & Internet Experts
David Payne
David Payne
Endre Nagy
Endre Nagy
Are you a Rapoo Computer and Internet Expert? Answer questions, earn points and help others
