Question about HP Color LaserJet CM6040f MFP Q3939A Printer
Error code 59.f0 hp 6040 - HP Color LaserJet CM6040f MFP Q3939A Printer
4 Suggested Answers
SOURCE: HP Laserjet CP2025
The yellow flashing light shows network activity and is quite normal. It flashes every time a message is sent anywhere on the network.
Posted on Jul 22, 2010
MedManHelp
  • 55 Answers
SOURCE: I HAVE AN HP LASER-JET
60.X ERROR To continue turn off then on The tray specified by X is not lifting correctly. Follow the instructions on the product control panel.
Posted on Aug 02, 2011
SOURCE: error code 59.co for hp laserjet 3800 what is the problem
READ THIS.
http://www.laserquipt.com/support/idx/58/592/article/59C0-Error-Displayed-on-Control-Panel.html
Posted on Aug 30, 2012
Hp color laserjet 3525 error 59.F0
we recommend you try reseating the transfer belt assembly a couple times, also try reseating the toner and the fuser assembly.
Aug 14, 2017 | HP Office Equipment & Supplies
My printer is showing error 59.0F Hp laserjet cp 2025
see some articles below for similar errors.
It does not appear to be user fixable error unless it is that debris to be cleaned. Printer HP Laser Jet CP4525 59 F0 Printer Error
Apr 28, 2016 | Office Equipment & Supplies
Hp laser jet pro 400 m401 printer 59.A0 error
i have nOt used this site before but i believe they do have a description of the error code you describe. it said problem is defuser or main motor error, heres the link
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
HP LaserJet Error Codes 50 59
Apr 20, 2016 | HP Office Equipment & Supplies
I receive 59.fo on my HP color laserjet 3425dn
59.f0 is related to the transfer belt. Made sure it is installed correctly. If you have a spare transfer belt try that.
May 26, 2015 | HP Office Equipment & Supplies
When i sand a test page the printer show an error 59.f0 what can i do
Pull the transfer unit out, and turn the white gear on the side. Not the one that turns the transfer belt--the one that causes the belt to push up against the toner cartridges. If the gear turns somewhat freely (it's not stuck), then reseat the transfer unit and see if the error goes away.
More comprehensive troubleshooting guide is here:
http://www.partsondemand.co.nz/uploads/97806/files/Feb_14_59.F0_error_Tech_Talk.pdf
But if it passes all the "checks" and you still have the error, check this out:
http://cincinnatiprinterrepair.com/hp-cp3525-59-f0
Apr 22, 2014 | HP CP3525N Color LaserJet Printer
Hp cm3530 error 59.F0
chance the sensors chance the motor on the fuser and big gearbox chance the transfer belt chance the main board the err 59f0 on a hp cm3530fs ,what can be the cause !!!!
Mar 19, 2013 | HP Laserjet Cp2025n Printer
Laserjet cp3525 error 59.f0
If it helps, I solved the error 59.F0 blowing on the sensors that are on the outer side (right door) under the edge of the transfer belt. You must remove the fuser and transfer. To locate the place to blow, craft and close the door stations toners, we see a long plastic slide guide in the machine with the door movement. Must blow into the small holes that are filled with dust with compressed dry air.
Good luck.
Jan 09, 2012 | HP CP3525N Color LaserJet Printer
HP Color LaserJet CP352dn 59.fo error
59.F0 ERROR
The primary transfer-alienation motor has experienced an error.
1. Check to ensure the ITB is installed correctly.
2. Run a sensor test to verify that the primary transfer disengagement roller is functioning. If not replace the sensor (SR17).
3. Run the primary transfer drive test in actuator drive mode. If not functioning replace the ITB (Intermediate transfer belt).
Jul 27, 2011 | HP Laserjet Cp2025n Printer
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
HP 5500n 59.ck error code
HP LASER PRINTER 2300 ERROR 59.B, 59.C
1. The Alienation motor error.
2. Replace the alienation motor.
3. Replace the D.C. controller board.
May 15, 2009 | Office Equipment & Supplies
HP Color LaserJet CM6040f MFP Q3939A Printer Logo
109 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
