Question about Electronics - Others
Istar korea x40000 - Electronics - Others
Istar korea x1500
I have the istar korea x1000 & x1500 and the ip tv channal is gone from list snd also need a user code iptv.how can i fix this problem.
Dec 28, 2013 | Electronics - Others
Istar korea
After researching your question to try and make any sense of it... i figured that it must be a satellite receiver. Are you asking if it can be set up for closed captioning?
Oct 20, 2013 | Electronics - Others
Removal iStar.exe application
Sounds like you encrypted the drive. Under Computer, right click the drive and format it. You will lose all your data and there is no way around this. Write your password down somewhere if you can't remember it.
Dec 21, 2012 | Electronics - Others
I'm here in the philippines i' m trying to call in korea with this # 01068710697 but i don't know how to call.
you may have to add:
00 82(the number to call excluding the first zero) if its a mobile number. South Korea
+82(the number to call excluding the first zero) if its a fixed landline number. South Korea
00 850(the number to call excluding the first zero) if its a mobile number. North Korea
+850(the number to call excluding the first zero) if its a fixed landline number. North Korea
Hope this helps. Please rate.
Nov 07, 2009 | Video Game Consoles & Games
How to connect a maglock to a fire relay? I have to insure that maglock controlled doors release when the fire alarm is activated. I have a Ccure Istar panel and I think a apc pwr supply
On most fire alarm panels there are normally open and normally closed relays that will change state in the event of a fire. The negative power line can be ran through these relays to allow the maglock to be powered down in the event of a fire. The relay on the fire panel may need to be programmed to do this or it may come programmed by default which is usually the case. Hope this helps.
Sep 25, 2009 | I-Star PSU ISTAR|TC-550PA RETAIL (TC550PA)...
Electronics - Others Logo
102 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
