On booting i get a message to "halt on Mouse" press F1. once it is doen then there is no problems ahead
technotech
  • 183 Answers
SOURCE: error message
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
This will resolve your issue
Posted on Nov 27, 2008
  • 158 Answers
SOURCE: BOOTING PROBLEM
Hii, Go to the BIOS setting by pressing DEL at the system startup and then set it Default and then save setting.
Posted on Feb 22, 2009
  • 489 Answers
SOURCE: Bootup Problem of Dell PE6650
Your NVRAM was corrupted (probably by a dead CMOS battery) or your hardware configuration has cnaged (deah boot disk, etc). Enter setup to see if the date/time has reverted to a previous date. If so, the CMOS battery needs to be replaced and the BIOS reconfigured for the server. Otherwise, check to ensure that your disk configuration is correct. If the battery is not dead and your disk configuration is incorrect, you may have a bad hard disk.
Posted on Jun 05, 2009
SmartAviator
  • 449 Answers
SOURCE: Bootup Problem.
Try getting BIOS access by pressing F2. Then try rebooting.
Posted on Jul 17, 2009
mahhek
  • 662 Answers
SOURCE: my system can not booting error message is chasis intruded fetel
KINDLY QUOTE THE EXACT ERROR MESSAGE YOU ARE GETTING. Start tapping the del / f2 key immediately after you turn on the system
Posted on Aug 26, 2009
Digilite h61 serise
hello guys going to bios setup diable on ps2 keyboard mouse option
annamalai2008@gmail.com
Oct 14, 2013 | Computers & Internet
My pc dell optiex gx270 when i attach 1 hardrive in computer in start up time in black screen message 0 seek failure , boot press f1 to stup press f2 when i press f1 message not boot drive find when go to...
once in the setup (F2 at boot) turn on Caps Lock, NumLock and Scroll Lock (all 3 keyboard lights on)
Press ALT + E (system should beep once) Press ALT + F (System should beep once) Press ALT + B (System should reboot and re-detect drives)
Aug 05, 2011 | Dell Dimension 3100 PC Desktop
On my computer i have to push f1 to start it
first try to notice the message before the (press F1 to continue) message, it could be a bad component (memory, hard drive, etc...) or the time & date is not set correctly in the BIOS, this would help a LOT thank's...
Jun 25, 2011 | Dell Computers & Internet
Dimension 8300 boots up to a black screen that says "Alert! Storage battery voltage low" Press f1 to continue, f2 to enter set up etc If I press f2 I can use the keyboard to scroll through...
i think storage battery low indicates that the cmos battery is losing its ability to reatin a charge. try replacing it. if that doesn't solve your problem, you have deeper issues. consult a professional if this is the case.
Jan 31, 2011 | Dell Dimension 8300 PC Desktop
My system only boots as far as the initial bios screen where it says Press F1 or Delete for setup and just hangs there. The keyboard indicators light up, but it will not boot any further.
Good Morning!
and wish you a Happy New Year2011.
1. Visual checkup of the Motherboard: See for any defective capacitors on the board near Processor. A defective capacitor will have a tapered surface and a good one will be flat, on the top. You need to service motherboard. Most of the motherboards carry 3-years warranty.
2. RAM problem: try to put your RAM chips in another slot if vacant. if you have two slots and both are occupied, then try starting system, by placing one RAM at a time and in each slot alternately.
If any combination works then you can make out if and whether your RAM or its slot is faulty.
3. Hanging due to overheating: Before you get the message "Press F1....", pres PAUSE key several times, it should halt the process and the message will not be displayed. This will make sure that the system is halted by pressing the PAUSE Key. After one minute, release pause by pressing any other key and see if you can move further. There may be two possibilities . . .
a) If you are still in the same position, where you have paused the system. The system is halted due to CPU over-heating. Clean the CPU fan with blower or a vacuum cleaner. See, if all of the locks of the CPU FAN and the heat-sink are intact. If the fan itself is not rotating, check for the fan cable and if it is OK, then try replacing CPU Fan.
b) You have reached the same point where it used to stuck before, i.e. at "Press F1...". Now this means your system has halted while detecting other peripherals or add-on cards.
i. HARDDISK: Most possible cause is your HARDDISK is making "click-click" sound and not getting detected. Switch off system and remove all HDD cables (Power and Data both). Start your system and see if you get any message like "insert system disk" this means there is problem with your HARDDISK. the same problem may be caused due to CDROMs. try same and try again.
ii. SMPS POWER SUPPLY: This symptom may be caused due to inadequate power supply. You can change SMPS and make sure if the problem is due to power supply.
iii. ADD-ON CARDS: Remove any add-on card like, Sound card, Graphics card, Modem and switch on the system. if system starts, then turn-off PC. Try placing one card at a time. and start system to make out which card is making the problem.
If the problem remains, get back to us.
Have a nice day!
Jan 03, 2011 | Mercury KVM800M Motherboard
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
The service tag is 19sfy91. At first I could not get past BIOS error "Alert! System Halted. Incompatable processor" I flashed BIOS and the PC boots up but I still get the error message with option F1 to...
The new series of Intel G1 stepping Pentium 4 processors (Prescott) is not backwards compatible with all the latest BIOS versions for OptiPlex systems.
Jun 05, 2009 | Dell OptiPlex GX520 PC Desktop
I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem...
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Mar 11, 2009 | Computers & Internet
Computer wont boot up
first reconnect your keybord and mouse jack in computer then power up the compter then press del or F1 or F2 to nweter in bios setup then just press F10 and save settings .
Feb 07, 2009 | Dell Computers & Internet
Error message
Nov 26, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
