Question about VCT Electronics Vct Vt-500j Japanese Step Up Down Voltage Transformer Converts Japan
Need fuse and cap for VT-500 - VCT Electronics Vct Vt-500j Japanese Step Up Down Voltage Transformer Converts Japan
1984 Honda VT 500 C Shadow lights do not work
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1984 Honda VT 500 Shadow fuse box location Google Search
Honda Motorcycle Wiring Diagrams
http://www.cycleterminal.com/Service-Manuals/Honda-VT500C-Shadow-Service-Manual-English.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vt-owners-manuals
Apr 12, 2014 | 1984 Honda VT 500 C Shadow
1983 Honda vt 500 ft ascot wiring diagram
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1983 Honda vt 500 ft ascot wiring diagram Google Search
1983 1988 Shadow VT500 Motorcycle Repair Manual PDF Download Download Misc $10
Nov 09, 2013 | 1983 Honda vt 500 ft ascot
1983 Honda vt 500 ft Ascot coolant overheating
Hi, Anonymous and the usual suspects are:
1. Low coolant level.
2. Restricted radiator air flow.
3. Faulty thermostat.
4. Coolant pump or fans inoperative.
5. Vent hose crimped.
6. Air in the coolant and needs bleeding.
7. Engine idling too long or bike moving too slow.
8. Coolant too old needs to be replaced.
9. Faulty temperature sensor, wiring or connector.
85 VT500C overheat blows out coolant
83 Shadow VT500c overheating
1983 1988 Shadow VT500 Motorcycle Repair Manual PDF Download Download Misc $15
https://www.partsfish.com/page/oem-parts-for-honda
Jun 04, 2012 | 1983 Honda vt 500 ft ascot
1986 Honda VT 500 C Shadow tail light not working
Hi, Anonymous tail light issues are relatively easy to diagnose and repair always check the tail light fuse first and make sure you have power on both sides of the fuse holder and the usual suspects are:
1. Tail light bulb element is broken.
2. Tail light bulb soldered contacts are extremely worn down.
3. Tail light bulb socket corroded.
4. Tail light bulb socket has no power and or ground.
5. Tail light wiring harness damaged from the rear tire.
6. Tail light rear fender wiring harness connector faulty due to corroded, broken, or loose pins/sockets.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
1984 VT500C Tail light problem
84 vt500c no tail light or license plate light
Feb 07, 2012 | 1986 Honda VT 500 C Shadow
1983 vt 500 honda shadow. Replaced both head's. Starts fine has good power. Yet it pop's or back fires some times after giving it progressive fuel. What do you think. Thank you!
Three things that can cause popping or backfiring. 1)You may have cracked, leaking,or broken intake manifolds or bad o-rings on the manifolds. 2)Leaking exhaust gaskets in the head or between the head pipe and muffler. 3)Bad spark plug caps and partially fouled plugs. Check it out.
Apr 21, 2011 | 1984 Honda VT 500 C Shadow
How do I check the coolant level on a Honda VT 500
With the engine cold, take off the radiator cap under the tank and make sure it is full to the top. Then check that the overflow bottle down by your foot, is full to the full line. Use only anti freeze that is non-silica formula (no rust scrubbing particles). Regular anti freeze will shorten the life of your water pump by damaging the ceramic washer in the seal.
Dec 08, 2010 | 1984 Honda vt 500 ft ascot
I own a 1984 honda vt 700cc shadow the problem is that the radiator fan wont cut in when engine is hot is there any fuses to the fan motor and where are they or is there a thermostat which is stuck. ...
Most common problem for Honda's is the switch (about $100) Usually it is right on the radiator or in some cases on the radiator cap mounting tube. There are two switches you will find ,single wire is the temp sender, two wire is the fan on/off switch. The two wire switch is the one that usually goes bad. Test the fan motor to make sure it works (rare). New they can run $200-$300.
Jun 20, 2010 | 1984 Honda VT 500 C Shadow
1984 VT 500 C Shadow: 1983 honda shadow -starts and runs, seems to miss ...
The fuel filter is in the tank on the petcock and is self cleaning. I suspect you have bad spark plug caps on your bike the cap is part of the wire. If you remove the wire and take a reading with an ohm meter, the cap should read 5000 ohms . Anything above or below and you should replace the cap. This is probably causing the slight miss.
May 06, 2010 | 1984 Honda VT 500 C Shadow
VCT Electronics Vct Vt-500j Japanese Step Up Down Voltage Transformer Converts Japan Logo
53 people viewed this question
Top VCT Electronics Electronics - Others Experts
Are you a VCT Electronics Electronics - Other Expert? Answer questions, earn points and help others
