Question about Acer ICONIA TABLET A501 10.1" NVIDIA TEGRA250 DUAL CORE 1GB 32GB ANDROID 3
First acer frozen on screen. Then it did not respond to soft boot, hard reset or power & volume method. Yesterday I had a dead android robot with a red triangle with a message....booting kernel image, then it would freeze on acer screen. This morning it will not respond at all, screen is black. I have a a501 Acer tablet. I would appreciate any advice. Thanks
TampaNative
  • 778 Answers
SOURCE: how to break bios password
Continue with a blank password field, since none was manually set.
If that doesn't work, locate the BIOS battery and remove it for several minutes and replace it, that should flash the BIOS to default.
Posted on Feb 12, 2009
SOURCE: my acer c312 touch screen doesn't see the pen,
You need Windows XP touch-screen version. It came on disc with the laptop. I wish I had a copy too.
Posted on Feb 18, 2010
simrick405
  • 117 Answers
SOURCE: Brand New Acer 5738PG6306 (touch screen) Notebook - BLANK SCREEN
If you can return it to the retailer, that would be my first option. Sounds like a bad backlight.
Posted on Feb 22, 2010
Testimonial: "Really appreciate the fast response, clear assessment, and open opinion."
sayedmohu
  • 633 Answers
SOURCE: Hi I have an Acer
Seems like your hard disk is not getting detected.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Start tapping the DEL key as soon as you power on the computer.
This will take you to the BIOS screen.
If it doesn't, you will have to check whether your hard disk is faulty with a local technician.
Once you get in to the BIOS screen, press F9 to load the default settings.
Than press F10 to save and exit.
Once you do this, the computer will restart.
Hope this helps.
Posted on Oct 03, 2011
revrlhoward
  • 7 Answers
SOURCE: how do I start acer iconia in safe mode
Hold the power button in for the count of ten, it should shut it down and cause it to ask you to boot up in safe mood, it may take a couple of tries but it will eventually go to a menu to ask for the boot mode....I recommend spyhunter4...I just removed that virus from a clients pc two days ago
Posted on Oct 12, 2012
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
How do I unfreeze the computer
In case your Android smartphone is complete frozen and not responding to you at all, the above restart method won't work for you! To unfreeze Android smartphone that is dead froze, force restart it by holding the Sleep / Power key and the Volume Down key simultaneously until your device's screen goes blank.
This force restart key combo varies from device to device, so it is advised to check your device manual for the right combo. If your Android device has a removable battery, you can remove it and put it again and it will restart the device.
Jan 19, 2015 | Tablets & eReaders
Bypass a forgotten lock code
Make sure the tablet has been turned off first by holding down the power button until you get the power off dialog box and choose power off. Then hold down the volume button and while continuing to hold the volume button, hold down the power button until you get a message like 'booting into recovery mode' or a dialog box that allows you to go into recovery mode and do a factory reset. Some tablets may boot into a screen with the Android robot on it that you can touch the robot and get to the recovery mode screen. When you do a factory reset, all user information stored on the tablet will be cleared, including the passwords or lock codes.
Jan 05, 2015 | Chromo Inc Vuru T2 7" Android JellyBean...
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
Hard resetting
The trick is sliding the display lock switch at the exact right moment, otherwise it will not engage. Here are the steps that have worked for my self and several other Xoom FE owners:
1. Power off the unit - if not already
2. Hold down the "Down" volume button at the same time you hold down the power button for 3-5 seconds.
3. While still holding down the "Down" volume button, release the power button and toggle the display lock slide a couple of times (located next to the volume controls).
4. The display should now show "Booting Recovery Kernel Image" and then the Android Robot will be displayed when the unit is in the rebooting phase.
5. Since the device is being Reset (erased and re-imaged), it is normal to see "Please wait for pre-load data" and this process takes about 6-8 minutes. The Xoom FE is now being Factory Restored to the original image.
Nov 22, 2013 | Motorola Mobility Mz505 Xoom Family...
I put a password on my android tablet and now i dont remember the password
Make sure you backup your files by connecting it to a PC (if you have access to one) via USB cable,you will have to do a hard reset, otherwise there is no other way to get past the lockscreen (unless you have a recovery option with your email address)
Below is the process to tell you how you can hard reset your Samsung tablet (should work with any tablet):
  • Ensure that the Samsung tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Powerbutton in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
  • Once your device is hard reset and rebooted successfully, you will see that the unlock pattern obstruction is also gone, and you can now set a new unlock pattern on your Samsung tablet.
Oct 21, 2013 | Tablets & eReaders
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Acer ICONIA TABLET A501 10.1" NVIDIA TEGRA250 DUAL CORE 1GB 32GB ANDROID 3 Logo
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
