Question about Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw
235e husqvarna - Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw
SOURCE: Cant get clutch cover off new Husqvarna 235e chain saw
Mine did this when nearly brand new. You likely have a nasty jam of oil and sawdust stuck between the chain brake and the flywheel. It can be loosened by either careful prying of the case or precise shots of carb cleaner up in the housing. While you are in there look for a buildup of oil around the chain brake connection to the kickback paddle.
Posted on Dec 31, 2008
dontbother10
  • 2220 Answers
SOURCE: i have a 235e husqvarna with tool-less chain
Any weekday between 1300 and 1600, stop by McNasties, buy 2 premium coffees (one black). Continue on to your friendly neighborhood Husky dealer (leave the saw in the car) and present him with the coffee. Discuss the problem you are having and ask for his help. It appears to be possible to replace the tool-less setup with the tried and true version. I estimate $20-30. Probably less than repair cost for your current arrangement.
Is not new and improved wonderful? We found a way to simplify manufacture, use fewer parts, and negatively impact how well our product performs... You pay more!
This may also help Mr McKenna:
HusqvarnaUSA.com http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week.
I hope this was helpful.
Lou
Posted on Jan 21, 2010
  • 4088 Answers
SOURCE: husqvarna chainsaw 235e starts but the chain won't
Does the brake seem to 'snap-over' like it should? Pull it back to release position, and remove the drive cover. Check the entire brake for debris accumulation or bent/damaged brake band. Check the chain to see if it is being oiled. Remove the bar/chain and clean the entire assembly, particularly the small oil passages in the drive end of the bar. Start the engine and watch for oil oozing out of the small side port where the bar fits. If ok, reassemble the bar/chain. If no oil comes out, investigate the oil pump, lines, and filter/valve in the oil tank. Mount the side cover, but leave the fasteners finger tight. (The chain teeth cut toward you on the bottom run) Tighten the chain until the lower run comes up to the bar, but can still be turned by hand. Tighten the fasteners and recheck the tension. Trip the chain brake and make sure it locks the chain, then release it and make sure it turns freely. Check the chain oiling by running the bar tip at speed near some cardboard--it should leave a thin line of oil on the board. Hope this helps!
Posted on Jun 26, 2010
  • 4088 Answers
SOURCE: husqvarna 235e will not stay running
Take the saw back for warranty service. We have a Husky #435 that had starting problems when new last year--warranty service replaced the ignition module the first trip, then a little later, they replaced the carburetor--it has worked very well since. I suspect that Husqvarna has had problems with our ethanol blended fuels. Hope this helps!
Posted on Jul 14, 2010
puertobori
  • 7733 Answers
SOURCE: how do you replace a chain on a Husqvarna 235e
Take out the chain guard.Once there you will look at a bolt holding the chain plate.Untight the bolt and adjust the cahin,but not too tight just test by hand if it moves freely but tight.Usually a gap of about 1/4 or less is enough,tight and guard back.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 20, 2010
How do you replace a fuel filter for 235e husqvarna chain saw
They are kinda hard to get them out but it is in the fuel tank on the fuel line just get it out the gas tank filler hole then pull off and replace with new one..
Jul 15, 2014 | Husqvarna 235e 16-inch 34.4cc 2-stroke...
How to get chain guard off 235e husqvarna?
The chainbrake must be open, then turn the chain tightening handle counter clockwise. The side cover can then be removed.
Apr 26, 2014 | Husqvarna Forest & Garden #952802239 235E...
How to adjust oil flow on husqvarna 235e
I dont think you can on this model. I think its permenantly set. However, depending on the season you can get 'thicker'/'thiner' chain oils.
Sep 06, 2012 | Husqvarna 14-Inch 34cc Gas Powered...
How heavy duty is the Husqvarna 235E 14" Gas Chainsaw? can it take a larger bar?
The 235e chainsaw was a complete disaster, all sorts of problems too many to list, i would not put a longer bar on it.
Feb 27, 2011 | Husqvarna Garden
How do you replace a chain on a Husqvarna 235e
Nov 20, 2010 | Husqvarna Forest & Garden #952802239 235E...
Husqvarna 150bt losses power
possibly the spark arrestor in the exhaust is part blocked
Nov 02, 2010 | Husqvarna Forest & Garden #952802239 235E...
Husqvarna 235e will not stay running
Jul 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
