Question about Car Audio & Video
How do I remove the standard stereo from my Isuzu Dmax LSU 2009
  • 6982 Answers
SOURCE: my isuzu dmax oil pan
In order for that dent to have any real effect upon oil delivery, the dent would need to be perfectly flat up against the oil pump pickup. Chances are it isn't. The pickup in most pans is located a bit above the pan bottom to lessen the chance of ingesting any contaminants (sand, grit, hard carbon etc). With the clearance diminished, chances of that are greater.
While only oil pressure is measured, volume is also important. With the pan that close to the pickup, pressure probably won't be a problem but you may loose some volume (impossible to tell how much).
When I put together a fresh engine, I like to see pressure of about 40psi or better. As an engine wears, engineers claim that anything above 15psi is OK...I use a higher number of 25psi (at idle) as a minimum "safe" limit. Anything below that, you know you have a problem and it's wise to find it early and fix it. (Pumps rarely fail...most low pressure problems can be traced to engine bearing wear, resulting in bleed off past the bearings)
As for your pan: If the pan is bent, and you have it off the engine, why not hammer the bend out a little? or, better yet, get another pan from a scrapyard and replace it entirely?
If you have not removed it, there's no real way of measuring and what you are seeing may not be the whole story...pickup clearance may be greater elsewhere. In that case, just continue doing regular service and save pan replacement for a day when you have time to do it.
Posted on Mar 30, 2011
headstrong56
  • 493 Answers
SOURCE: isuzu DMAX sudden power loss
could be fuel filter clog.air filter or MAP sensor or an intermittent speed sensor on the transmission
Posted on Jul 13, 2012
marknphyll
  • 197 Answers
SOURCE: Vehicle is a 2009 Isuzu DMax Ute - won't idle to warm up. Surges/hunts, then runs fine and suddenly cuts out at idle when cold. At second start, it is time to creep away slowly with slight throttle pr
You need to check to see if you have any Codes stored into your ECM. Take it by a Auto Zone type store and ask for a person to check your c
Codes for you. They will be glad to as it may give them a chance to sell you a part to fix it.
Posted on Jan 08, 2014
  • 227 Answers
SOURCE: Gear lever stuck in park (P)
Question are you putting in the correct size fuse ? Look in the owners Manuel it will tell you what amp fuse goes where. May be as simple as that always make sure you put the same amp fuse back in very important.
Posted on Feb 18, 2014
nobody322
  • 20706 Answers
SOURCE: Does anyone know where i can get a locking wheel nut remover key please its for a isuzu dmax. Thanks guys
tire shop.
ask em.....
or any auto repair shop....
there are many types of locks,..... to defeat each type, is like 10 page answer.... not doing it.
Posted on May 24, 2015
DMax EGR valve, I have removed mine and cleaned, while off I applied voltage to the solenoid and the valve opens, what makes/causes it to close? I have to prize it closed with a small bar.
Isuzu or Chevy? They both have a DMAX. Also try reversing the polarity on the power that you are testing it with and see if it closes.
Oct 16, 2017 | Cars & Trucks
2013 Isuzu D-max valve clearances?
what car , Dmax
what engine? they have many engine choices world wide...
what country,
Jul 28, 2016 | Isuzu Cars & Trucks
DMAX 4 wheel drive utility. How do I remove the plate lamp?
wow no year car stated or country. 2002 to PRESENT.
is car outside, USA ?we dont have books on DMAX here.
license plate lamps.
on our cars the operators guide in the glove box covers this, turn to Bulbs page and its there. get the guide, never lose it.
13 DMAX assembly plants world wide, and most are not the same.
(laws in your country all dictate light rules, most)
see?
Jul 16, 2015 | Isuzu Cars & Trucks
Feb 18, 2014 | Isuzu Cars & Trucks
Jan 08, 2014 | GMC Vehicle Parts & Accessories
Want to know where to conect blue and black wire on isuzu dmax gearboks
If there only two wires then check the blue one for power and if so then the wires will probably go on the reversing switch
Dec 29, 2013 | Isuzu Rodeo Cars & Trucks
Where can i get rid of a brand new Isuzu DMax tub
I am looking for a Isuzu dmax tub ,, contact number 0419264083
Mar 14, 2013 | Isuzu Pickup Cars & Trucks
Isuzu DMAX sudden power loss
Jul 13, 2012 | Isuzu Cars & Trucks
Car Audio & Video Logo
326 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
