Question about Sony VAIO Computers & Internet
I'm using a Sony Vaio Duo 11 touchscreen laptop. The cursor keeps on clicking on the far right of the screen. How can this be solved?
    Top Expert:
  • Sony Master
  • 12,223 Answers
Restore the computer using the control panel, use the utility restore and put the last days that you know was working good.
God bless you
Posted on Oct 14, 2013
  • 3 Answers
SOURCE: Sony Vaio PCG-K86P laptop
fjhdsjafjkds
Posted on Jan 02, 2008
  • 8 Answers
SOURCE: computer displays black screen with blinking cursor
Its seems its not booting correctly. Just Insert Windows CD and fix the windows. Another solution is to press (I think) F1 or F11 or F12 (depending on the model) when booting the machine. It will take you to recovery mode. Use it to restore the boot section ONLY.
Posted on Mar 06, 2009
Geekman
  • 32281 Answers
SOURCE: vertical pink line on the right side of the vaio screen
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 11, 2009
Geekman
  • 32281 Answers
SOURCE: my sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
Check out
www.lcdparts.net
Posted on Jul 24, 2009
SOURCE: VGN-SZ330P laptop stays on opening VAIO screen after two beeps
Just hold down the F1 key after the two beeps and the computer should continue to boot up as normal
Posted on Dec 21, 2010
Having issues with screen, everything with computer works and lights are all turning on but screen wont light up and shows no image.
This sounds like a faulty hardware. i would suggest taking it to sony if its still under warranty and get it replaced. if not contact a local technician.
May 31, 2015 | Sony VAIO Duo 11 SVD11225CXB 11.6"...
HOw do I turn off touch screen on a Sony VAIO Tap 20 Touchscreen All-in-One Desktop Computer, Intel Dual-Core i5-2430M 2.4GHz, 8GB RAM, 750GB 5400 RPM HDD, Windows 7 Home Premium 64-bit
1.Press the Windows logo key + X.
2.Select Device Manager from the list.
3.Click the little arrow next to Human Interface Devices to expand the list.
4.Click the touch screen driver (in my case, NextWindow Voltron Touch Screen).
5.Right-click, and select Disable from the list.
6.Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver.
7.Restart your computer
When you want your touch screen to work again, follow the process above, EXCEPT when right-clicking the touch screen driver, select Enable
See the website
Turn off VAIO all in one touchscreen function disable annoying system...
Mar 07, 2015 | Sony VAIO VPCL23CFX/B All-In-One PC - 2nd...
Screen goes black unless the comuter is on charge, although it's fully charged
Right click on the battery icon in the taskbar (Normally located near he clock, bottom right corner of the screen).
In the sub-menu that pops up, select "Power Options".
Next to the power plan you are running, to the right of it, click on "Change plan settings".
Scroll down to and click on "Display" and you will see the computers setting options for both "On battery" and "Plugged in" with the screen turn off time in drop down boxes.
You need to select what time the screen turns off in when no user input is detected for that time. I usually select 5 mins for battery.
Hope this helps, and wishing you a Merry Christmas. ;)
Dec 15, 2013 | Sony Vaio Duo 11
My left button on the mouse pad wouldn't work
try to tap on the touchscreen instead of the left click
Mar 07, 2013 | Sony VAIO Notebook
Sony Vaio laptop (PCG-61317L) once I start browsing the internet, the screen freezes and the mouse cursor disappears from screen. When I don't browse the internet, it sometimes does the same thing
The reason this is happening is that as you are typing; you're resting some weight on the thin plastic above the touchpad...which then makes contact and registers a 'click'; thus moving your cursor around. Or you're brushing your thumb against it when hitting the space key.
Some laptops are more susceptible to this than others. Some more modern laptops come with a button to turn the touchpad off to solve this very problem.
The only thing you can do about this is to disable the touchpad through the touchpad driver (down by the clock, usually) and use a mouse instead. Depending on how you use your laptop, this will be more or less inconvenient- if your laptop never leaves the desk; disable the touchpad and use a mouse...no problem. If you go mobile a lot, you'll have to enable and disable the touchpad all the time.
The other thing you can do is adapt your typing style so you don't put any weight on anything but the key you're pressing. This is quite difficult and uncomfortable, and is not recommended for long sessions.
Dec 01, 2012 | Sony VAIO VNCX1/B.CE Mouse
Hi, I got a VAIO PCG-K27 Notebook from my friend recently, got problem so need to load window XP os. Now after reloading and reformatting i am having view small ( less 1.5" both sides left and right)...
Use your mouse to RIGHT CLICK on an empty area of your desktop.
Select PROPERTIES.
Select SETTINGS tab.
Move the SCREEN RESOLUTION SLIDER to a different setting.
Click APPLY.
Keep trying different settings until you find one that is acceptable.
Then Click APPLY and OK and then reboot your computer.
That should do it.
Good luck and please rate this with 4 Thumbs Up if it was helpful.
Thank you.
Feb 14, 2011 | Sony VAIO 15.4" Widescreen Notebook PC...
Can't get full screen even though maximize
TRY USING MOUSE CURSOR TO WIDEN SCREN BY EXPANDING WIDTH AND HEIGHT. ONCE DONE RIGHT CLICK ON WINDOW AND CLICK "REFRESH" CLOSE WINDOW...THEN REOPEN ND SEE IF IT OPENS TO PROPER SIDE.
GODD LUCK
Oct 19, 2010 | Sony VAIO VGN-N325E Notebook
Remove the drop down icon bar on sony vaio
Usually, with a dropdown toolbar, you can put the cursor all the way to the top of the screen and with the toolbar visible, right click on it to activate a control menu from which you can stop it from dropping down, unlock it and move it to either sidr, or even turn it off altogether.
If this doesn't work, try entering yout laptop model name in Google search followed by "disable dropdown toolbar" for blogs and forums for your laptop model that may have a specific command or trick for your machine.
Good Luck
Jul 27, 2010 | Sony VAIO VGN-CS260J/P Laptop
Computers & Internet Logo
53 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
