Question about Ovens
Need interior glass for main electrical oven door for a Belling double oven. D'not know the model and no tag on the unit
SOURCE: just brought belling xou594 double
BELLING XOU252 WHEN IT IS SWITCHED ON IT TRIPS THE MAINS ALL WIRES SEEM TO BE GOING TO EARTH.
THANKS
MEL
Posted on Aug 16, 2008
onthejob5130
  • 640 Answers
SOURCE: cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Posted on Dec 27, 2008
amgm
  • 32 Answers
SOURCE: trying to set oven timer
Hi, switch off the mains for the cooker, wait for about 15 seconds then press the 2 buttons on the left and hold them, and then press the - or + button to set the time.
Cheers
Posted on Feb 19, 2009
  • 4 Answers
SOURCE: kitchen aid oven door glass shattered
gget a new door
Posted on Jun 21, 2009
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
How do I get the glass off the door of my Belling Format oven, I want to clean it and can't get to it.
The glass window in the oven is not intended to be removed and cleaned. It is a sealed double pane unit.
Dec 14, 2016 | Belling Ovens
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
Reassembling thermador Thermatronic II lower oven door cmt21
you can use some of the glass of the old oven just need the size of the glass if you order from the manufacturing it very exp
Jan 03, 2010 | Thermador SMW272 Electric Double Oven
The main oven door will not shut tightly, how do you adjust it?
if its a pull down door the hinges are prob worn and need replacing.
Sep 27, 2009 | Belling XOU492 Electric Double Oven
I was wondering can i buy glass for the oven door seperate?
Providing the oven is not more than 10 years old, then there,sholud be no prob obtaining a new door glass.
Go to: www.belling.co.uk
Then click on: www.4belling.co.uk/spares
Pleas leave a rating for my suggested solution.
Thanks.
Feb 17, 2009 | Belling Ovens
My belling oven door
get these instructions and look at door removal
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
if the glass has come away from the metal inside doror its was originally secured by a silicone sealant/adhesive. Try Toolstation 59104
Jan 29, 2009 | Belling XOU487 Electric Double Oven
Belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Sep 29, 2008 | Belling XOU592 / XOU593 Electric Double...
Fan is running fine but main oven does not heat up
It is most likely the element they are very cheap on line ,
Sep 11, 2008 | Belling XOU592 / XOU593 Electric Double...
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
