Question about Smoothfitness Exercise & Fitness
Escessive noise in rear roller - Smoothfitness Exercise & Fitness
    Top Expert:
  • Smoothfitness Master
  • 12,223 Answers
See the video attached, lube the rollers bearing front +and back too.
test the drive belt motor, replace the belt if necessary.
If the problem persist, replace the old board deck belt.
God bless you
Posted on Oct 14, 2013
Dryer is making a loud screeching noise
Most likely, the rear drum bearing, a drum roller, or a drum slide has failed. Most models do not have all three types of drum support, usually one or two types. (Rear bearing with front sliders, rear rollers with front sliders, front and rear rollers, etc.)
Could possibly be a belt idler pulley or motor bearings, too.
You should diagnose and find the problem, before buying the parts.
Mar 05, 2017 | Dryers
Tip
How to troubleshoot a noisy treadmill
First verify if your are getting the noise with a user physically on the machine, without anyone on, or both.
Creaking or squeaking while running on the machine usually indicates an issue in your incline motor, deck frame, springs, and or pivot points.
A loud grumbling noise getting louder and louder while elevating speed, usually means you have a bad bearing.
Any knocking noise coming from a treadmill indicates bad bearings in your front roller, rear roller, or drive motor.
Isolate the bearings in the front and rear rollers from the drive motor bearings.
To test: Unplug the machine, remove the main shroud, remove drive belt from drive motor and front roller pulley.
After doing so, move the treadmill belt by itself by pushing it backward or forward with just your hands and listen for any noise, if you get any noise it is most likely coming from either the front or rear roller. To isolate the noise from the two rollers you can loosen the belt and turn each roller individually.
If no noise with the first test, go ahead and start the machine and run it at a low speed. You want to listen for noise, if you get knocking or grumbling while drive motor is running with no drive belt attached then the issue is in your drive motor.
A lot of times simple maintenance will save your treadmill from noise, you want to make sure and lubricate your treadmills pivot points. Incline motor bolt, shaft, deck screws, and or any pivot points on the bottom of your machine. Metal on metal pivot points are usually the culprit in most cases.
Pivot points are just areas of high friction where there may be a bolt, washer, and nut attached to the base of your frame or any hinges on your folding type treadmills. Metal on metal needs to be lubricated to minimize wear and tear of those areas.
Synthetic grease works best or any spray on lubrication works fine if you do not want to remove any bolts or hardware.
If you ever find yourself needing technical support, please do not hesitate to call us 888-713-2880 or visit us online at www.sportsmith.net
on Jul 13, 2015 | Exercise & Fitness
Making very loud whistle noise
Be sure to verify if you are getting the noise while you are physically on the machine or with no one on it
To test: Unplug machine, remove the main shroud, remove drive belt from drive motor and front roller pulley
After doing so, move the treadmill belt by itself by pushing it backward or forward with just your hands and listen for any noise, if you get any noise it is most likely coming from either the front or rear roller. To isolate the noise out of the two rollers you must remove the rollers and turn each one individually.
If no noise with the first test, go ahead and start the machine and run it at a low speed. You want to listen for noise, if you get knocking or grumbling while drive motor is running with no drive belt attached then the issue is in your Drive Motor.
A lot of times simple maintenance will save your treadmill from noise, you want to make sure and lubricate your treadmills *pivot points. Incline motor bolt, shaft, deck screws, and or any *pivot points on the bottom of your machine. Metal on metal *pivot points are usually the culprit in most cases.
*Pivot points are just areas of high friction where there may be a bolt, washer, and nut attached to the base of your frame or any hinges on your folding type treadmills. Metal to metal needs to be lubricated to minimize wear and tear of those areas.
If you have any other questions please do not hesitate to call us or visit us online
888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
May 29, 2015 | Reebok RX6200 Treadmill Motor Control...
Rear roller makes noise
most likely the bearings are going bad.try loosing the walking belt and rotate the roller by hand. if you feel any grinding or its not smooth it shoud be replaced. normally only the two adjusting bolts hold it in there
Apr 19, 2014 | Golds Gym MAXX Crosswalk 650 Treadmill...
Nordictrack 3700 makes a knocking sound when I run on it
Hello.
Knocking noises more than likely come from the rear roller, there could be a small chance it's coming from the motor it's self though.
Have some walk on the machine and make the noise while you locate which end of the treadmills coming from.
If it is the rear roller the bearings will need to be replaced, this can be done by removing the rear roller and taking it down to any bearing shop and have them locate the bearing numbers. Ask them for advise on removing them as well.
If the noise is coming from the front of the treadmill then have a look at the fly wheel coming off the motor, locate grub screws and tighten.
GymWorld.net.au
Jan 11, 2014 | Nordic Track Nordictrack Track E 3700...
Clicking noise
Check the printer thoroughly for any small pieces of paper caught on a roller in the printer. If your printer is making a grinding noise, you may have a loose gear or roller in the printer.
If the noises started shortly after you installed a toner cartridge, turn off the printer and pull out this toner cartridge. Look up into the printer where this toner went. Make sure that both the charge roller and the transfer roller are still seated in the printer properly.
  • The charge roller is a tan-colored or gray roller attached to the inside of your top lid. Remove the toner cartridge from your printer. Close the top lid halfway with the cartridge still out. You will see the charge roller come down as you lower the top lid. Make sure that the charge roller is installed correctly within the two black arms on each end and that the roller does spin freely.
  • The transfer roller is the black, spongy roller in the bottom of the printer, under the toner cartridge. Push lightly down on it at both ends to make sure it is seated properly in its housing. NOTE: Try not to touch the charge roller with your bare hands. It is susceptible to the oil and may cause a permanent fingerprint to remain on the roller surface.
  • When you have checked the charge roller and the transfer roller, look around inside the printer. See if you can find any rollers that look loose or broken inside. Also look for any loose shreds of paper. If you do find a loose or broken part, you printer will probably require service to fix the problem.
If the rollers look fine, go ahead and reinstall the toner cartridge. If the squeaking/grinding noise continues and none of the rollers looks out of place, try swapping out the toner cartridge. There is a small chance that the toner cartridge is causing the squeaking/grinding noise. If you have any extra toner cartridges in stock, try another toner cartridge and see if that clears up the noise. If you have another working printer of the same model, try swapping the toner cartridges. See if the problem follows the toner cartridge or stays with the printer.
If replacing the cartridge does not cause the noises to go away, there are a few other things you can do to help pinpoint the source of the noise.
If the noise continues on the main printer, try opening the rear exit door while printing. See if you can tell if the grinding noise might be coming from one of those rear exit rollers/gears. If it does sound like it is coming from the rear of the printer, again look for any loose or broken part or any small pieces of paper.
If you have added any additional feed options (like a tray 2 or 3 option, duplex option, or envelope feeder), please remove these options. Try printing a few prints without these feed options attached. This will eliminate one of the feed options as the cause. If the noise goes away when you remove the options, reattach them one at a time. If the noise returns on one specific option, a roller or gear on that option may be the cause of the noise.
Is your printer making a rhythmic THUMP - THUMP - THUMP - THUMP noise when printing? This noise is a side-effect of a feature called Envelope Enhance. The Envelope Enhance feature is built into the fuser unit of the printer to help keep envelopes from wrinkling. This sound is perfectly safe and normal if the printer is printing on envelopes.
If none of the above fixes eliminates the noise, the printer will probably need service to return it to working condition.
***If you need any technical help on printer then you can reach at here
Feb 15, 2013 | Canon imagePROGRAF iPF8000S 44"...
Rear Roller need lubrication.
see the video attached and proceed according, this is a matter very easy to lube the rollers bearing. Use the extension plastic coming the LUBE and put a little oil for lube the rollers bearint. Use WD-40 NOt use for LUBE deck belt, this 100% LUBE SILICONE special.
God bless you
Nov 26, 2012 | Exercise & Fitness
Griding noise while spinning. the unit heats and spins but makes grinding noise as if the drum were off track
Hello Friend, Your problem is very simple to fix. You need to replace the Rear drum support rollers. To replace the Rear drum support rollers just remove front of dryer body exposing the drum, look under the drum and you will see the belt and tention wheel in front of the motor. Now, release the tention on the belt and remove belt from motor shaft. At this point you can remove the drum up and out of the dryer cabinet. Look towards the rear of the dryer cabinet and you will see the rear drum rollers. The roller on the left has a support strap held on by a press on clip. just pry this clip off and remove support bar. Now there will be a plactic triangular clip holding the roller in place. Just remove the plastic clip and replace roller. The roller on the right just has the triangle plastic clip just remove and replace that roller as well. Be sure to lubricate the roller shafts with some 3 in one oil prior to re-installing the new rollers. Make sure you re-install all of the retaining clips. After re-assymbly of your dryer if should run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks.
Jun 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Noise
You may have something caught in the rear felt or you may have a bad drum roller. Inspect the inside of the drum at the rear to see if there is anything stuck in the rear felt. Also check the front felt. If nothing is there you probably need a set of rollers part number 349241t. To replace the rollers, first remove the lint screen. Then remove the two screws under the screen (phillips). Swing the top back, it is hinged, and then remove the two 5/16" screws that hold the front in place. Swing the front out of the way being mindful of the wires going to the door switch. Now disengage the belt from the motor pulley and pull the entire drum out of the machine. You will see the rollers at the rear. They are removed by pulling off the traingular plastic retainer. Before you replace the rollers clean the shafts with emery cloth and give them a short spray with wd-40. Wipe the shafts clean and replace the rollers. You should inspect the belt (p/n 341241) and the idler pulley (p/n 691366) and replace them if they are worn.
Apr 08, 2009 | Whirlpool LER8648P Electric Dryer
Exercise & Fitness Logo
77 people viewed this question
Top Smoothfitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Smoothfitness Exercise and Fitnes Expert? Answer questions, earn points and help others
