Question about Atmlp10 Atm Low-profile Fuses; 5 Pk 10 Amp
I need to buy a fuse cartridge ceramic, were can I buy?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
Any where at gas stations, canadian tire your dealership would just give you one.Most likely.
Posted on Oct 14, 2013
How do i replace needle on record player
Here is the cartridge you need to buy: http://www.turntableneedles.com/Pfanstiehl-P-188-Ceramic-Cartridge-for-Yorx-Crosley-Nostalgics-CZ800-etc_p_1760.html
Feb 11, 2015 | Crosley CR711-BK AutoRama Retro Turntable...
Where can i buy the ceramic fuse for my toshiba flat screen?
That model uses a e.t8ah250vp fuse and they are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=316
The fuse is located inside on the power supply board.
Mar 27, 2013 | Toshiba 40E200U 40-Inch 1080p LCD HDTV
Need a fuse for my TV
yes , this 8 amp fuse , just buy the slow blow fuse but most of the time when this fuse is bad is because you have another problem on the power supply
Mar 05, 2012 | Emerson Televison & Video
Where can i obtain a realistic 32-1200 manual for free? or what does cera and mag on the back of the mixer mean?
In reference to the question -
" what does cera and mag on the back of the mixer mean? "
these jacks are for the input of phonograph record cartridge signals.
Phonograph cartridges are of two types -
1. "Cera"mic (ceramic) cartridges generate their signal using a ceramic crystal which provides almost 1/2 a volt of current.
2. "Mag"netic (magnetic) cartridges generate a more accurate signal than a ceramic cartridge but the magnetic cartridge generates its signal using a moving-magnet mechanism (rather than a ceramic crystal) and the magnetic cartridge generates much less current than a ceramic cartridge, so its signal needs a lot more amplification than a ceramic crystal's output. So the two jacks on the back of the mixer provide different levels of amplification for the phono cartridges, less amplification for a ceramic cartridge and more amplification for a magnetic cartridge.
Since few people play phonograph records any more it is understandable that the public has little knowledge of the differences between ceramic and magnetic cartridges. But each have their own benefits and usually ceramic cartridges are cheaper than magnetic cartridges simply because it takes a lot more sophisticated manufacturing technology to make a magnetic cartridge, though magnetics are usually preferred over ceramics because of their more accurate generation of a signal from the wiggling groove in a phonograph record. But for those who can hear, the complete sound signal from a phonograph record is much preferred over the dead and dry sampled sound from a digital CD. And the old 1/4" reel-to-reel tape recordings are the highest sound quality of all because they are direct copies of the original magnetic tape masters with no digitizing at all. The fullness of their sound is astounding compared to any digitized signal..
A mag input is down at the mic level.
A ceramic input is almost up at the line level.
Jul 25, 2011 | Audio Players & Recorders
Fuse blown on Europower PMP 3000. Where can I find a 10 Amp 250 V ceramic replacement fuse?
You don't need to use a ceramic fuse if one's not available. You can also use a glass cartridge fuse as well. Just be sure the rating is the same. Be aware, though, that fuses seldom blow on their own. Usually it's because something else has shorted. So don't be surprised if replacing the fuse only results in another blown fuse. Behringer stuff is notoriously cheap and under-protected, so by the time the fuse blows it's usually more trouble than it's worth trying to fix. But maybe you'll be lucky and it will be something simple. Good luck, and thanks for using Fixya!
Jul 05, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Turned on at main switch but no power when switched on.
there are 2 cartridge fuses located behind the dryer where the main power cord enters the unit,you need to unplug the unit,then unscrew the two black round fuse holders to access the fuses they are 15 amp at 250 volts a.c. ceramic fuses
Feb 21, 2011 | Asko T712C Dryer
My ac/heater stopped working yesterday (2004 Honda Accord EX). I've read posting relating to the blower motor as the possible cause. I'm not sure which fuse controls this. I wanted to check this first....
Yes, I would check the 40A fuse for 'Heater Motor' but there may be another fuse under the dash that controls the ac/heater.
I would get a fuse tester from Walmart or a parts store included with a set of various fuses.
The fuse tester can be used to quickly test all of the fuses in a particular box in maybe 5 minutes of your time.
It's like a miniature test light that goes on when an energized fuse has a break in it. This saves a lot of time and the risk of putting the fuse back where it does not belong.
Inspect/Test/Replace There are three basic types of fuses in automotive use: blade, ceramic, and cartridge.
f14-353184.jpg Blade fuse, ceramic fuse, and cartridge fuse.
Occasional fuse failure can be due to a defective fuse. Corrosion on the end of the fuse can cause failure too.
The cartridge fuse is found on most older domestic cars and a few imports. To check this type of fuse, look for a break in the internal metal strip. Discoloration of the glass cover or glue bubbling around the metal end caps is an indication of overheating.
Late-model domestic vehicles and many imports use blade or spade fuses. To check the fuse, pull it from the fuse panel and look at the fuse element through the transparent plastic housing. Look for internal breaks and discoloration.
The ceramic fuse is used on many European imports. The core is a ceramic insulator with a conductive metal strip along one side. To check this type of fuse, look for a break in the contact strip on the outside of the fuse.
A visual check of the fuses in questions can sometimes show a burned fuse. Sometimes, a fuse can blow where it cannot be seen.
f37-193184.gif Test a questionable fuse with an ohmmeter.
All types of fuses can be checked with an ohmmeter or test light. if the fuse is good, there will be continuity through it.
When inspecting fuses, also inspect the fuse link:
  • Fuse link wire is covered with insulation that bubbles if a fuse link melts.
  • The blisters on the insulation indicate the failure in the fuse link.
  • If the insulation appears good, pull lightly on the wire.
  • If the link stretches, the wire has melted.
  • Of course, when it is hard to determine if the fuse link is burned out, check for continuity through the link with a testlight or ohmmeter.
Oct 29, 2010 | 2004 Honda Accord
I need to get some ceramic fuses for my big screen tv
Hi josebalbuena
You can buy ceramic fuses from here. They are in most countries of the world. If you could give me more information, exactly what is written on the fuse you require,I could pinpoint the exact one for you. Happy to talk to you further about this.
Regards robotek
Apr 08, 2009 | Philips Televison & Video
Philips fuse t8ah250vp
http://www.newark.com/littelfuse/0215008-mxp/cartridge-fuse/dp/42K9308
Fuse is a "Littelfuse 0215008.MXP"
8A 250V Slow-blow ceramic
Dec 10, 2008 | Televison & Video
Sharp carousel r-1481
Ceramic fuses of 15A or 20A rating are available at home improvement stores like Lowe's, places like Wal-Mart and local appliance stores.
Ceramic fuses are preferred because they are considered flameproof.
Nov 04, 2007 | Sharp R-1405 / R-140 Microwave Oven
Atmlp10 Atm Low-profile Fuses; 5 Pk 10 Amp Logo
Top AAMP Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an AAMP Vehicle Part and Accessory Expert? Answer questions, earn points and help others
