Question about Hotpoint TVF770 Tumble Dryer
The tumble dryer just keeps going and doesn't switch itself off when using the automatic sensor mode. Seems to stick on 20 mins
    Novelist:
    Scholar:
  • 100 Answers
Find the sensor, near the tub, and see if a wire has not just simply fallen off or is touching another wire that is bare. It is common, but very frustrating.
kindly,
Jim
Posted on Oct 20, 2013
Bosch logixx 10 tumble dryer
This is not a good sign. You should check to see if the door switch is bad. If it is not that then the controller needs replaced.
Jul 08, 2013 | Dryers
My Automatic 2.0 petrol Trajet keeps sticking in 3rd gear when i rest/park car for a while the problem is gone then the cycle repeats,I changed crank shaft sensor this week but no good????
It is not surprizing that replacing the crankshaft position sensor did not fix your transmission shifting problem. The cranshaft position sensor is used for fuel and ignition control for the engine - it has absolutely NOTHING to do with the transmission.
i would recommend getting your transmission problem properly diagnosed by a professional that understands how your vehicle works.
May 19, 2012 | Cars & Trucks
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
Smells hot. does not dry. sticks on 20 min all cycles
just a quick suggestion
check your exhaust outside for proper airflow
Oct 11, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Tumble dryer
You may have loose wires.
Check the door switch first.
Then check the wires going to it by opening the top or front of the machine, which ever opens to examine the switch and wires.
Also, check this link.........
http://www.howstuffworks.com
Let me know if you have the problem solved please.
Thanks,
yalmer
Mar 13, 2008 | Dryers
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
System switches itself off
The HT-DB120 has an automatic shut down that should turn off after 20 min of idle mode, it seems yours is malfunctioning. try disconecting the DVD from power for a few minutes.
Jan 07, 2006 | Samsung HT-DB120 System
Hotpoint TVF770 Tumble Dryer Logo
97 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
