Question about IBM ThinkPad T21 Notebook
Some keys are not correct
Hi, my problem with IBM T21 as follows: Some Keys on the right of key boars are not correct. Ex: Key (shift & +) becomes [, ... How can I solve it? O.S: WimXP SP2 Thanks
    Problem Solver:
  • 5 Answers
Hi!
Depending on your country, make sure that you have set the keyboard to your correct language in the (Control-Panel)
'START-MENU> SETTINGS> CONTROL PANEL> KEYBOARD'.
Please note that you are always set to the DEFAULT language which is (U-S ENGLISH) you will need to change this for your country for the keyboard to map the keys.
John
Posted on Apr 24, 2009
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
Keyboard numbers are jumbled
Number keys on think pad lock using openoffice.org
On Thinkpads laptops the keys on the right hand side double up as the number keypad. To switch on the Number lock key pad on - press and hold the Shift key and press the NumLk/ScrLk key, it is above the F11 key, the Num lock LED will also light up. Press these keys again to turn off the Numer Lock.
Nov 10, 2009 | IBM ThinkPad T42 Notebook
The keys with nunbers/ & letters on the right of keyboard are
The num lock key up by F12.
Usually you press and hold the shift key and the correct key.. It will be in the upper right of the keyboard.
Sep 03, 2009 | IBM ThinkPad R40 2681
Cant find the colon on a IBM thinkpad
filmmakernz -
There should be a colon on any standard keyboard, to the right of the "L" key.
If you still can't find it, hold down the ALT key, then type "0", "5", "8", then release the ALT key. This should put a colon wherever you are, even in a DOS command line.
Michael
Jun 30, 2009 | IBM ThinkPad T21 Notebook
The @ Key
Shift-2
If that puts up the quotes instead of @, then go into your keyboard settings in the control panel and select usa english.
Nov 10, 2008 | IBM ThinkPad T21 Notebook
IBM R52 laptop shift key deactivated - pls help
you might have accidently disabled 'stick keys' it is a short cut that is activated is you press shift 5 times
Mar 19, 2008 | IBM ThinkPad R52 Notebook
Shift key not working - deactivated
Start -> Settings -> Control Panel -> Accessibility Options. The default panel that comes up will in fact be for the keyboard options. There you can turn off whatever happened to have been turned on. While you're there for each of the three options, press Settings, and uncheck Use Shortcut. Now Windows will no longer misinterpret your random keystrokes.
IBM ThinkPad T21 Notebook Logo
87 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
