Question about Charging & Starting Systems for Chrysler Neon
My Chrysler neon r/t is draining the battery, I think it is a problem with the CD selector but cannot work out how to disconnect it
    Master:
  • 492 Answers
Check to make sure the battery is getting charged. 13.8 v min. A voltage below that indicates a charging problem. When it gets to 12.0 v the bike is drawing power slowly from the battery.
Posted on Oct 15, 2013
Chrysler neon starting problem no slap
The camshaft sensor was faulty with my Neon. Sometimes it started sometime it didn`t or took 20 seconds.
Apr 21, 2014 | Fidanza 2001 CHRYSLER NEON 361312 Clutch -...
Chrysler neon radio
That sounds like an earth fault. If you can add a temporary additional earth and see if that cures it over period of time.
Sep 24, 2013 | Chrysler 2002 Neon Radio / CD Player...
What causes a battery drain on a 1997 dodge neon
How old is the battery? Is there any aftermarket alarms or stereos installed? And are the cables clean and tight? If the battery is new and the cables are tight you have a parasitic drain. you need a DMM, disconnect negative terminal and place one lead on cable, one on post. Set DMM to amps and compare reading to man. specs usually between 20 to 50 milliamps. If out of spec disconnect one fuse at a time looking for a fall in the reading and that will tell you what circuit has the issue
Sep 05, 2011 | 1997 Dodge Neon
Cd in car stereo won't eject. I have a 2005 Chrysler T&C van and there is a CD in my stero that won't eject. Any suggestions?
Try turning the radio off and disconnecting the battery for 2 min then reconnect the battery and turn on the radio. This may reset the radio to default so you can eject the CD and reset your station preset and clock. make sure the radio is off before disconnecting the battery or your going to be prompt to program a radio code. Good luck and this should work.
Jan 02, 2010 | 2005 Chrysler Town & Country
Different wiring plugs
If it were me, I'd cut off the connectors and switch them, but I solder things every day. I don't think they make any adapter wiring harness for this problem.
Dec 16, 2009 | 2001 Dodge Neon
Speedometer and tachometer don't work
try disconnecting your battery for 5 minits then reconect you might just find this will sort out your problem. Hope this helps
Jul 07, 2009 | 2006 Chrysler Neon
Cd player wont work on a 2003 dodge neon
look on the front and look for a small hole ther ma be a reset buton that you need to put a pin or pen to push
May 04, 2009 | 2003 Dodge Neon
The internal lights of my Chrysler Neon car is always on.
I had the same problem a few months ago. If you locate the pressure switches on the door frames (which are pushed in as the doors are closed to switch off the lights) you will see that the centre of each switch is adjustable. Working on each of the doors, if you carefully pull the centre of the switch out slightly and then close the door the switch should then adjust itself and create the contact needed to switch off the interior lights. I hope this helps. David W
Nov 12, 2008 | 2006 Chrysler Neon
Vehicle Parts & Accessories Logo
66 people viewed this question
Top Chrysler Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Tim Garcia
Tim Garcia
Are you a Chrysler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
