Question about Whirlpool Duet GHW9150P Front Load Washer
My whirlpool infinity will wash but the door now won't open. It drains ok but the dial seems to stop just short of the stop line after D. Any thoughts?
    Master:
  • 492 Answers
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Posted on Oct 15, 2013
  • 1028 Answers
SOURCE: My whirlpool LHW0050PQ4 compact front
probably motor control bd but on some early models when both control bds (1 under top and 1 under bottom panel)came together in a kit worked great since sometimes hard to determine exactly which control bd was actually causing the problem if you are sure wash motor is not running and belt is not off
Posted on Jul 05, 2008
  • 4 Answers
SOURCE: Whirlpool AWM8121 ?door open? light flashing
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Posted on Dec 13, 2008
skrbin
  • 121 Answers
SOURCE: hotpoint bwm129 washing m/c door won,t open
probably door lock-switch.
Posted on Feb 16, 2009
defadad
  • 351 Answers
SOURCE: washing machine overflowing
the valve on your inlet pipe may be faulty, have the valve checked or buy a new valve, not very dear, around $30 australian
Posted on May 30, 2009
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
I have a whirlpool ultimate care II washer. It stopped in the middle of a load, full of water, and now it won't do anything. It won't drain, fill, move, or make any noises.
You will need to check the capacitor on the machine. It can be tested with a capacitance meter the easiest. It can be tested with a resistance meter, but this will tell you if the capacitor is shorted or open. It will not tell you the capacitive value if the component has drifted out of tolerance. You put the meter across the terminals and watch the display for counting up to infinity. This will occur quickly and disappear very quickly. Now reverse the leads on the terminals, (reverse the polarity). The same thing should happen, but a bit more pronounced. It will once again rise very quickly and go to an infinite reading. This tells you that the capacitor isn't shorted or open internally. Here is the capacitor to order if you should find it bad.
Nov 28, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
AWM6100/s door open light comes on shortly after starting
Bought a new washing machine. The motor had one of the coils open circuit and the cost of a new motor was nearly that of a replacement WM.
Oct 05, 2009 | Whirlpool AWM6100 Front Load Washer
Water does not drain
either dial has went up or the pump has
Jul 01, 2009 | Washing Machines
Whirlpool AWM5125 - door won't open
i unplugged mine from the wall and that worked
Nov 29, 2006 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
