Question about Siemens Dishwashers
Dimensions of SE64A630 - Siemens Dishwashers
I need exterior dimensions of old Kenmore side by side model 10656234000
Dimensions for a 17cft model!
Dimensions and Capacity:
Depth w/ Handle (In.): --------- 30.375
Depth w/out Handle (In.):------ 30.375
Height to Top of Case (In.): -- 67.375
Height to Top of Hinge (In.): -- 68
Width w/ Door Closed: --------- 28
Jul 23, 2016 | Kenmore Refrigerators
What are the dimensions of Whirlpool Fridge Model ET18GKXGW01?
You would be safe if you used the current dimensions for todays
18cf Top freezer ref. 28" w x 67.5" h x 31" d
You are right no published spec's left too old I guess?
May I suggest measuring the space allowed for the fridge?
Jul 27, 2014 | Refrigerators
What are the dimensions of the following product Bosch Hbc84k51b
Check on the Bosh website. The Owners Manual should show the installation dimensions
Jul 23, 2014 | Microwave Ovens
What are the dimensions of the Whirlpool microwave GH4155XPB?
Dimensions/Weight Exterior Dimensions (WxHxD): 29 15/16" x 16 1/4" x 15 7/16" Cavity Dimensions (WxHxD): 22 3/8" x 8 3/16" x 13 13/16" Approximate Shipping Weight (lbs.): 86 Microwave Capacity (cu. ft.): 1.5 Cooking Power (watts): 1000
Jun 06, 2011 | Whirlpool GH4155XP Microwave Oven
Dimensions (especially depth) for Magic Chef 31213XAA gas range
www.magicchef.com/
Please get a manual from the above link. Or contact them. usually the dimensions are about 24" depth
Mar 28, 2010 | Kitchen Ranges
Siemens SE64A630 GB I got a tingle up my arm when holding the dishwasher and touching my sink. I checked and when the dishwasher is plugged in, there is 24VAC between the dishwasher door and the stainless...
I would say it is an earthing problem, check over your earth wires, normally black and grey is neutral, check to make sure your earth wires are connected properly, and tight, better to completely turn appliance off by disconecting power plug while doing this, take care not to play around with the wires too much to prevent a nasty electric shock
Jul 01, 2009 | Siemens 24 in. SE64A630GB Built-In...
DiMAGE E323 dimensions and weight
Dimensions: 99(W) x 62(H) x 34.5(D) mm / 3.9(W)x2.44(H)x1,36(D) inch. Weighs: Approximately 145g, excluding battery and storage media.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
Weight and dimensions
PV-SD4090 Dimensions (WxHxD): 5-5/8" (143mm) x 4-3/8" (112mm) x 3-1/4" (84mm) Weight: 1.53 lbs (695g) without battery PV-SD5000 Dimensions (WxHxD): 5-5/8" (144mm) x 4-3/8" (112mm) x 3-1/4" (84mm) Weight: 1.53 lbs (695g) without battery
Sep 01, 2005 | Panasonic Palmcam PV-SD5000 Digital Camera
Sep 01, 2005 | Panasonic Palmcam PV-SD4090 Digital Camera
Dishwashers Logo
42 people viewed this question
Top Siemens Dishwashers Experts
Paul Bade
shaun taylor
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
