Question about Carrier Bryant Payne Air Handler Control Board 322848-751
Berrow fan doesnot stop running after ac shout down
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
It is snubber problem. It causes due to emf field in fan motor. You have to just add a snuuber component in pcb or problem can be removed by switching mains off
Posted on Oct 15, 2013
Ac condenser fan will not run
Disconnect it first and supply it with a separate power supply only from the battery manually to see if it is not burnt out then get back to me. Remember to rate my help and if you need further help just shout thanks in advance.
Mar 01, 2014 | 2004 Isuzu Rodeo
Fan not shouting down when i turn car off
Sounds like a fan relay is stuck. Check out pictures of this part on sites for Autoparts. Yours may be next to Radiator fan. Now if fan eventually stops, some are made to cool engine compartment once car is parked as heat builds up for a period of time once the engine has stopped.
Apr 26, 2013 | 2000 Lincoln Continental
My fan keeps running after the engine is turn off its a 2003 x-type, after using the a\c
if the car is hot the fan will run affter the car is shut off to cool it down
Jun 24, 2012 | Jaguar XKR Cars & Trucks
When im at a red light i turn on my ac and my engine gos off . but i can run my ac when im on the highway or im moving in the car. but when im getting ready to come to a stop i have to turn off the ac or...
Problem could be a number of things:
  1. worn or slick drive belt - drive belt slips and with AC on could cause stalling
  2. bad MAF (mass air flow) sensor
  3. dirty EGR valve
  4. bad TPS (Throttle Position Sensor) - controls idling speeds under all conditions ie. engine is cold, warm, running with AC on
Sep 08, 2011 | 2005 Chevrolet TrailBlazer
Samsung split ac mdl # u24a2qc, system is about 10 years old. outside condensor operates fine until warmest part of day, then the fan on the compressor unit cycles on and off repeatedly although the...
I would guess that the motor is pulling to many amps, it could be to small (not the horse power as should be), could be bad incorrect fan blade (to many blades or pitch on blades) over loading the motor. I have seen fan motors get to hot and stop from a dirty coil. Take a garden hose and a nozzle use a solid stream carefully watching the fins don't bend by high water pressure. Throughly clean the coil every inch or it. Hope this helps.
Jul 09, 2011 | Samsung Heating & Cooling
05 vue ac problem, ac not cold at idle, blows cold while driving, had checked freon is full, expansion valve was replaced, because high side flutters and low side does same. seems that compressor doesnot...
Hello, Are the cooling fan(s) coming on with the truck in park and the engine at idle? If the cooling fan(s) are not working A/C will not cool with truck setting still.
Oct 02, 2010 | 2005 Saturn VUE
The display doesnot come and processer and powersupply fan also doesnot move?
If the fans do not "spin", nor even "rock" slightly, just once, when you connect the AC power-cable, or press the ON/OFF button, then it is the power-supply that needs to be replaced, at least temporarily, to "trouble-shoot" the problem.
Sep 09, 2010 | Intel DG31PR Motherboard
BMW series 3 fan for cabin problem
Remove the Heater / AC control unit and then check if it still runs when the car is off. If not then the control unit is faulty.
Aug 03, 2009 | 2000 BMW 3 Series
Toshiba Satellite shuts-down by itself in about 1 minute
Could be hardware or software problems, IF its hardware issue the only problem makes this if the Cpu fan doesnot work, so the Cpu gets hot and then it shutdown in order not to be damaged. but mostly its software issue that remeber if you installed any program before this is happen, and try to stop shutdown by this command, if you did this and this stop shutting down your laptop this is absolutley software problems or programs conflict:
hit Start, then Run , then type this : shutdown -a
this will stop your shutdown if it works, try to uninstall the last programs causes this issue,if it doesnot let you use safe mode command.
Regards
Mar 01, 2009 | Toshiba Satellite M45-S265 Notebook
Ducted gas hetaing keeps tripping the thermo fan switch. We seem to have plenty of air flow out of the vents and have replaced 75% of the ducting
It seems that you are saying the thermo fan stops first, thenfotre the safety limit switch shouts off the gas. This would mean the thermo fan motor is bad. It is overheating, which cuts out the thermo fan switch. The gas only shouts off because the thermo fan motor is bad.
Jul 23, 2008 | Heating & Cooling
Carrier Bryant Payne Air Handler Control Board 322848-751 Logo
54 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
