Question about Yamaha RX-N600 Receiver
I plug my ethernet cable to my router/modem. But it doesn't work. I cannot listen to any radio.
    Sergeant:
  • 310 Answers
Somewhere in the setup or settings for the network on your receiver make sure DHCP is turned on. DHCP (Dynamic Host Control Protocol) allows it to get a IP address and subnet from the router so it functions on the network. Likewise DHCP must be enabled on the router as well otherwise the downstream device (your receiver) won't be able to get an IP address.
Posted on Oct 15, 2013
Can i hook up wrt120n to laptop without hooking up to cable modem to fix?
Try this: Unplug EVERYTHING(related to both the router and modem). BEFORE you plug in power to anything, connect all of your ethernet. So, first ethernet goes from modem to router. Make sure they are in their proper places. Next, take another ethernet cable and attach that from modem to computer. NOW, power everything up. Google the linksys router splash page login. Im sure it'll be something like: 192.168.1.1 or 192.168.0.1 or something along those lines. From there, you should be able to set up your wireless. Once thats all good, unplug just your computer and everything should be fine. If that doesn't work, its either time for a new router or you're having wifi card issues.
Apr 28, 2012 | Linksys WRT120N Router
I need to lock my router from others using my wifi
    • 1 Disconnect the power cord from your high-speed modem. Locate the Ethernet port on the back of your modem. If an Ethernet cable is already plugged in, trace the cable to the second device and unplug the cable from it; otherwise, plug one end of an Ethernet cable to the open Ethernet port on your modem.
    • 2 Plug the unused end of the Ethernet cable to the port on the back of the router labeled "modem." Plug a second Ethernet cable into one of the open ports located above the "modem" port; connect this cable to the Ethernet port on your computer.
    • 3 Reconnect the power cord to your modem; wait for the lights on the front panel to turn green before proceeding. Plug one end of the router's power cord into the corresponding port on the back of the device; plug the remaining end into any available electrical outlet.
    • 4 Turn on your computer and log into your operating system as normal. Insert the installation CD into the computer; the installation application should load automatically (if it doesn't, you can find the application by manually browsing the CD's contents).
    • 5 Follow the onscreen instructions; after you have made the initial configurations, click on the option labeled "Security Assistant" on the left side of the installer window. Select the desired security type for your wireless network and click on the button labeled "Next."
    • 6 Choose a network key and enter it into the appropriate field; press "Next" and follow the onscreen instructions.
    • 7 Open your computer's wireless network settings and enter the wireless network name, security type and network key into the appropriate fields. Save your changes. Set-up is now complete.
Tips & Warnings
  • You can access additional settings via the modem's manual configuration interface. Open your web browser and navigate to 192.168.2.1; when prompted for a password, leave the field blank, and click on the button labeled "Submit."For optimal signal strength, choose a location for your router that will be near your computer, with as few walls and other obstacles as possible.
Read more: How to Set Up a Belkin N F5D8236-4 Wireless Router ' eHow.com http://www.ehow.com/how_5106168_set-belkin-fd-wireless-router.html#ixzz1ONVtjSQ1
Jun 05, 2011 | Belkin F5D8236-4 Router
My web browser is not working. i cant acces the internet
make sure your ethernet cable (RG45 , looks like , bigger version of telephone cable) is plugged into your (ethernet) port of the computer and the other end of the cabel must be conncted to the modem or router). make sure the router has power and the modem has power, both turned on .
Are the lights on the modem or router lit up ?
the modem must be attached to the router via anolther RG45 ethernet cable. The modem must be conncted to a main signal cable or ethernet jack from your wall outlet or plug
let me know if this helps -- otherwise get in conbtact with your internet service provider
Oct 22, 2010 | Computers & Internet
Modem router(quest gateway) works on one computer but won't connect to two other computers. was working on two ,and now only the one wired to it.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
1. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
2. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
3. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
4. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
May 11, 2010 | 2wire (1000-400108-001) Router
The ''wireless'' light on my wireless router is flashing amber
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
Ethernet cable 'splitter': Works on AT@T 'light' modem but not on cable modem. Are splitters speed sensitive
Splitters that work on telephone modems are not designed to work on cable modems. If you are trying to allow more than one computer to access the Internet, you need a broadband router.
You can find them on eBay and at stores for under $30. The primary difference between them is the number of "ports". A port is simply a place to plug in your PC. The more ports, the more PCs you can plug in.
Here's how you set a router up.
1. Plug a short Ethernet cable into the Ethernet "out" port on your cable modem.
2. Plug the other end into the "Uplink" or "WAN" port (will be labeled one or the other.
3. Plug an Ethernet cable into the LAN card on your PC and the other end into one of the open Ethernet ports on the router.
4. Reboot each PC.
You should be good to go!
Oct 25, 2009 | Linksys computers10: EtherFast Cable / DSL...
Desktop and two laptops won't work with modem & router now
Probably you used the wrong type of ethernet cable, a crossover one. Try another Ethernet cable but this time a straight one.
Mar 11, 2009 | Westell Wirespeed ProLine 6100 Router...
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
Need to hook up Belkin G wireless router to Motorola SB5120
Plug your cable line into your modem, make sure it's tight, but don't use a tool. Next plug the ethernet line from the modem to your PC ethernet port. Then plug in your power to the modem. Allow your modem to sync. Don't use the USB line at all. Do not even hook it up unless your computer doesn't have a working ethernet line. Don't run the disk either, it will only install the modem driver that is only used if you use USB.
If you have issues connecting after that, you may have to go into your ethernet adapter settings and make sure that it is using DHCP. DSL usually uses a different setting (PPP I think) and you will not be able to connect.
By the way, excellent choice in modems.
Jan 14, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Yamaha RX-N600 Receiver Logo
52 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
