Question about Intel Celeron -D 2.26Ghz Computer System PC Desktop
There is no display of bios often and system does not works
  • 55 Answers
1.change cmos cell and clear cmos rom using cmos jumper after then check display .
2. reinstall ram stiks and change
3. unplug one by one all internal extrnal device like HDD,CD/DVD ROM/writer and if u use extarnal cards like sound display and check display ,any one may be faulty
4. check prosessor for heating if prosessor not heating then change prosesor also now problem in your motherbord
Posted on Apr 24, 2009
System has Blue Location, and Orange Power led lit but system wont power up, no error codes displayed on diag panel.
Please remove the BIOS battery and then place the BIOS jumper and reset the BIOS. Please check jumper position in motherboard manual. Then, try again. It will power on.
Please let me know if it stil not worked.
Regars,
Kaushik Patel
Oct 30, 2013 | IBM eServer xSeries 336
LCD Monitor isn't recognized
it is an issue with the LCD on your laptop as you get a fine display on external monitor
either get it repaired from a local technician
or get the LCD replaced
Jun 07, 2008 | Compaq Armada M700 Notebook
Laptop wont turn on, got green pwr and amb bat but will not fire up
Systems covered: All failing to boot without lighting up display.
Goal of this Solution: Try to determine whether system is (a) booting successfully while failing to light its display (indicating hardware failure in the display), or (b) failing to light the display due to failure to successfully transfer control to ROM BIOS (indicating a motherboard failure).
The fact that the Green power LED, and Amber Battery LED are lit seems to exonerate the laptop power supply (brick) circuitry. Even with a nearly dead battery, a Toshiba Satellite 1135-s1552 should work while plugged into a properly functioning brick.
Here's Toshiba support's (244 page) online PDF version of your laptop manual:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=434997&rpn=PS113U&modelFilter=1135-S1552&selCategory=2756709&selFamily=1073768663
If the HDD (hard disk) activity indicator LED is active after power-on, then your system has actually got past BIOS and is booting - your LCD monitor inverter circuit or Backlight may have burned out - and to use the system, you'll need to connect an external monitor to the RGB monitor port on the back of the system (see illustration on page 32 of User's Guide) to view system activity.
Alternatively, one may attach an analog TV, using the S-Video port on the back of the laptop (see illustration on page 32 of User's Guide).
Once an external monitor is working to display the ROM BIOS part of the boot sequence, you may find that the ROM BIOS is good enough to run a few BIOS-based diagnostics. Run them all - something may indicate the source of the boot failure. Ofttimes, enough of the motherboard remains good to provide interaction with the ROM BIOS, but some motherboard failure will subvert a full boot to Windows/Linux. An example of this type of failure would be a failure of the PCMCIA bus controller, which is vital for booting a disk-resident OS, but unaccessed (except by BIOS diags) when the user interacts with BIOS. Another common failure of this type is main memory (RAM) failure.
A working external monitor/TV also provides a chance to backup important laptop data to a flash drive, sky drive, or CD-RW discs.
If no HDD activity is seen after power-up, then either your BIOS is hosed (in which case you'll need a new motherboard), or another motherboard component is hosed (in which case you'll need a new motherboard).
You may want to transplant the HDD into a working PCMCIA-bus system (any laptop) to recover/backup your important data.
If someone recently attempted and failed to update the motherboard's ROM BIOS, then you know why the system is failing to boot and also failing to light the display.
Here's a link to a site with disassembly instructions for Toshiba laptops:
http://www.irisvista.com/
Most dead laptops (even those whose power supplies have been burned out by a nearby lightning strike with the system on 120 VAC power) will still have perfectly usable HDD module(s), and RAM memory cards, so that at the very least, these removable components may be recycled into memory reserves for your next laptop or sold (Ebay.com) to help defray the cost of a new system.
Dec 14, 2011 | Toshiba Satellite Computers & Internet
HOW DO YOU GO TO THE BIOS SET UP?
Put your system on for the first time after a second press (F2 ) keyboard button immediately. Bios setup will display, if it didn't work out then off the system again and restart after a second press (F9 ) keyboard button immediately,Bios setup will display.
Nov 23, 2011 | Sylvania G-Netbook
Monitor gets signal from computer but doesn't display. Monitor will display message that says no signal when unhooked from computer but will not display menu
Sound like it could be corrupted video driver. I would try holding down the F2 key to reach the system bios. Select vga for the video display if in the bios...then save and restart. If you can't get to the bios screen, try F8 and see if you can get safe mode...if so...it should allow pc to use the vga driver and thus hopefully display will work. If you get in and see windows, then you most likely ned to remove the display driver and reinstall it.
If still not working, try hooking monitor to another video port. Might need to get a conversion adapter to fit to vga port, or dvi port or whatever else you might see.
Jul 06, 2010 | Hannspree HANNS.G HX191D 19" LCD Monitor
Radeon X1300 card displays blank screen at logon
Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
Thanks for using Fixya
Proton
Aug 28, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Screen goes blank (white), sometimes screen display will get big
You can update graphics driver, if that does not fix the issue check the display on external monitor. If the external monitor works fine you can isolate checking the display in BIOS Setup scree (Restart your computer and keep tapping F10 to getinto BIOS). If the same issue in BIOS, you may have to change display of the unit.
Jun 26, 2009 | HP Pavilion TX1320US Tablet PC
My ASUS P5SD2-VM Is Having A No Display Problem
If you are using the motherboards built in VGA graphic display, check your bios settings. Open your manual to page 2-22. Read the page.
Make sure you have the bios set to, Primary Graphics Adapter [PCI-E] set to, [IntVGA].
Set the internal VGA to, [Enable]. You will also need to set an amount of your system memory for the VGA to use. It is recommended if you are using Windows Vista that you increase your 1GB of system memory to, 2GB. Or instead you can buy a decent PCI-E video card that will use its own memory instead of your system memory. If you do this you'll need to change the bios settings to, Primary Graphics Adapter [PCI-E].
Also change, Share Memory Size to [Disabled].
If you need the manual for the Asus P5SD2-VM. Click on the link below;
http://support.asus.com/download/download.aspx?modelname=P5SD2-VM&SLanguage=en-us
Click the dropdown menu & click on your operating system. Than click Search. Asus list all drivers, manuals, FAQ's ect.
To view the manual you'll need Adobe Reader. You can download Adobe for free at this link;
http://www.adobe.com/products/reader/
Again, if you do not have any display & your using the built in VGA graphics card try resetting the bios. Doing this will reset the bios back to normal default settings. The bios will auto use the built in VGA. To clear the bios see page 1-22.
Mike
Apr 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
No display (intel original 865 ..)
Tell me the Mother Board Chipset & Oper.Sys you are using.
Try to change power settings in bios if it not works try to set bios optimal defaults, if it not you have to update BIOS.
Hope this will be helpful..
Nov 22, 2007 | Intel Motherboard
Open Questions:
as some sites suggest about cheat for igi game i tried it and make changes under Project IGI- I'm going in Cheats----hi friends in this game it is difficult to get the blood/medipack to get this use the folowing instruction. 1)first go to the igi installed folder then go to weapon folder u will find some folders like Ak47,binoculars,colt anaconda,medipack etc. 2)then go to Ak47 folder you will find a folder like weapon the open in hex editor u will find a string like weapon_id_Ak47 by using hexeditor edit the string to weapon_id _medipack. then similarly go to medipack folder u will get a folder like weapon then open in hex editor edit weapon_id_medipack to weapon_id Ak47 the save it. 3)when u will kill a soldier u will get a medipack. for hex editing i installed HEXED30f.zip software and changes in hex file as i described above but due to mistake my igi game not start well aND , SHOW A error like igi stopped and shows problem detail Problem Event Name: APPCRASH Application Name: IGI.exe Application Version: 0.0.0.0 Application Timestamp: 3a1d74c6 Fault Module Name: StackHash_169c Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Code: c0000005 Exception Offset: 00000000 OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional Information 1: 169c Additional Information 2: 169c69b50cca39ebafad90cf9acfe712 Additional Information 3: 166e Additional Information 4: 166ed9faa1184e606930c56f1ef84d85 please send solution ... or reply
Dec 31, 2010 | Intel Celeron -D 2.26Ghz Computer System...
Intel Celeron -D 2.26Ghz Computer System PC Desktop Logo
60 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
