Question about Fujitsu LifeBook E780 Notebook
Wireless button - Fujitsu LifeBook E780 Notebook
Where do I find the wireless button on an IBM thinkpad X31?
Some laptops don't have a wireless button or switch. If that's the case they control the wireless by keystrokes. Look onboth sides and in front for the Wireless Switch and turn it on. Look on both sides and in front for a wireless button. Look just above the keyboard for a wireless button.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
Jun 01, 2012 | Computers & Internet
Wireless capablity turned off in hp probook 4520s
You can use the wireless button or HP Connection Manager (select models only) to turn on and turn
off wireless devices.
NOTE: A computer may have a wireless button, a wireless switch, or a wireless key on the
keyboard. The term wireless button is used throughout this guide to refer to all types of wireless
controls. Refer to the Getting Started guide for information on identifying the location of the wireless
button on your computer.
To turn off wireless devices using HP Connection Manager:
? Right-click the HP Connection Manager icon in the notification area, at the far right of the
taskbar, and then click the power button next to the desired device.
- or -
Select Start > All Programs > HP > HP Connection Manager, and then click the power button
Jun 24, 2011 | HEWLETT-PACKARD HP ProBook 4520s Notebook
Hi there! I would like to know how to unlock internet button from my HP probook. Its button light is orange and I have no access to the internet. I'll glad you anything you can do for me! ...
Not knowing the model of your unit, I respond with a general answer:
Using the wireless controls
You can control the wireless devices in your computer using these features:
?? Wireless button
?? Wireless Assistant software (select models only)
?? HP Connection Manager software (select models only)
?? Operating system controls
Using the wireless button
The computer has a wireless button, one or more wireless devices, and two wireless lights. All of the
wireless devices on your computer are enabled at the factory, so the wireless light is on (blue) when
you turn on the computer.
The wireless light indicates the overall power state of your wireless devices, not the status of individual
devices. If the wireless light is blue, at least one wireless device is on. If the wireless light is amber, all
wireless devices are off.
Because the wireless devices are enabled at the factory, you can use the wireless button to turn on or
turn off the wireless devices simultaneously. Individual wireless devices can be controlled through
Wireless Assistant software (select models only) or through Computer Setup.
check chap.2, page 22 in this manual:
http://tinyurl.com/3czcyss
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks,
Joe Diaz, Nashville TN.
De Cayey, P.R.!!
May 20, 2011 | Computers & Internet
Cant locate wireless button
The Wireless button is at the front of the Laptop. In the following diagram, it is number 6, or Wireless
communication button/indicator:
http://www.4shared.com/document/DHVptXen/Acer_TravelMate_2480_Wireless_.html
Mar 11, 2011 | Acer TravelMate 2480 PC Notebook
How to activate wifi in janab
There will one of two different types of switches or buttons to enable the wireless networking feature on your notebook.
Button on the front of the notebook:
  1. Locate the wireless networking button on the front of the notebook.
  2. Press the button to either enable or dislable the wireless networking
  3. Once the wireless networking feature is enabled the button will light up amber.
Switch on the front of the notebook:
  2. Slide the switch to the right to enable or disable the wireless networking feature
    Note: The switch will reset back to the left after switched to the right. This is normal and does not indicate the the wireless feature has been disabled.
Nov 30, 2010 | Acer Aspire 4720 Notebook
Dlink accesspoint doestnot connect with playstation3
The Dlink wireless modem is configured correctly and the computer/laptop can access the Internet wirelessly.
The PS3 needs to be configured with the Dlink modem's wireless settings so it can communicate with the wireless modem.
To configure the PS3 please follow these steps :-
1. Power up the PS3 and login then Select Network Settings and
press X
2. Select Easy then press > button
3. Select Wireless then press > button
4. Select Scan then press > button
5. Select the wireless modem you want to use, then press X button
6. Confirm the SSID for the wireless modem then press > button
7. Select the security settings (ie WAP, WPA - this is the in the wireless modem settings) then press > button
If there is no encryption I suggest you enable the encryption on the wireless modem, use passphrase to generate the encryption key.
Write down this encryption key, you will need this key for your computers and PS3.
8. Enter the WEP or WPA encryption key (from the wireless modem) then press > button
9. Check the settings then press X button
Dec 23, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
I want to connect my telstra wireless modem to my PS3
I assume the Telstra wireless modem is configured correctly and the computer/laptop can access the Internet wirelessly.
The PS3 needs to be configured with the Telstra modem's wireless settings so it can communicate with the wireless modem.
press X
Dec 22, 2009 | Sony Computers & Internet
Turn on wireless
on some compaq laptops the wireless switch is on the side of the laptop! look for a button! also some laptops have a wireless symbol on one of the f keys if you find the symbol on the f keys then you click on the fn and the f key with the wireless symbol at the same time!! that should work!
Nov 09, 2009 | HP Compaq Presario CQ50-110US Laptop
Wireless on/off button doesn't detect wireless card.
drivers possibly or if its a switch then a bad switch
Apr 30, 2009 | Acer Aspire 6920 Notebook PC
Can't enable wireless...how do you do it...where is the wireless button
you have a black strip with the wireless logo, above the keypad, press the logo and it will get blue (wireless activated)
Apr 13, 2009 | HP Compaq 8510p Notebook
Fujitsu LifeBook E780 Notebook Logo
26 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
