Question about Kitchen Ranges
AEG Cooker Hood Flashing Red Light
The number one speed led light keeps flashing all the time when on even after selecting a faster speed. The filters are cleaned regularly and I have checked the manual and followed instructions mentioned regarding the flashing LED. Have also switch off and left off for a couple of days but the problem stiill persists.
Model No HC5690M
SOURCE: Power up problem
One thing u can do also. Open your system case, remove cmos battery clean cmos battery and then insert like same. And restart your system. Other wise check power connections voltage. If it is ok then definitely it will wirk.
Posted on Sep 07, 2007
SOURCE: filter light keeps flashing
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
Posted on Sep 16, 2007
SOURCE: Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Posted on Feb 16, 2008
SOURCE: cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Posted on Feb 18, 2008
SOURCE: indesit cooker hood
HELP WHERE IS THE FUSE
Posted on Mar 11, 2008
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
I have a D60 and when using my new lighting kit if the aperture is faster than1/200 it creates a blackout across part of the image due to the mirror. Any solutions?
It's not the aperture, it's the shutter speed. It's also not the mirror, but the shutter.
The camera's fastest shutter sync speed is 1/200. You must use a shutter speed no faster than that. Due to the construction of the shutter, the frame is not fully exposed simultaneously at faster speeds and thus part of the image is blacked out.
Using a flash, the amount of light is controlled almost exclusively by the flash; the exposure is controlled by the aperture and the shutter speed is all but irrelevant.
Feb 15, 2013 | Nikon D60 Digital Camera
4wd 4wdlow light flashing
Hi there:
That flashing is a signal from the GEM computer that indicates a failure in the Control-Trac system. Typically it is one of the Hall-effect axle speed sensors (located in the t-case) that has failed. In the auto position on your model the system monitors relative front and rear axle speeds, increasing the period of engagement of the clutch pack in the transfer case to eliminate the rear moving faster than the front. If it gets to full-lock, for example, and the rear still seems to be turning faster then it reverts the system to 4WD (locks the transfer case in 4wd as it does in 4wd-lo) and flashes the lights to tell you of the problem (in 97 and later models it reverts to 2WD in the default, auto position). Some have reported cleaning the contacts on the speed sensors has helped, but you may want to get to a dealer if the problem persists. Watch that they dont automatically try to replace the computer or the transfer case. Usually it is just a sensor problem, which is relatively easy and inexpensive to replace. There is a shift motor on the t-case on these models, but it is only used to select 4wd-lo and yours seems to do that OK.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 23, 2012 | Ford Explorer Cars & Trucks
When failed trun signal bulb, Jeep turning signal is fastly blinking. I changed rear turn signal bulb with LED bulb, but turn signal blinking speed doesn't go to normal, At first couple of seconds it is...
Try replacing with the same bulb type as was failed. Flasher unit isusually reliant on resistence from the bulbs to what speed that side will flash at when powered.Some of these led type have less resistence and that equates to a faster flash speed.That is why when one bulb blows that side will flash faster or may even stay on without flashing.You could even swap the led to the other side( to confirm.Check with the bulb retailer to whether they have those bulbs with a higher rated resistence in led.If this vehicle has leds as standard,you may need to get the correct type from dealer. Hope this helps or get back with findings if it still has fault after replacing bulb.
Mar 29, 2011 | 2009 Jeep Patriot
I have a pentair intelliflo 4 x 160. It was running, I turned it off to clean my DE filter, I tryed to start it right after I put the filter back to gether, it turned just a second then the alarm light...
Check the wiring connections, and count how many times the alarm light blinks upon start up. It is probably a loose or broken connection, but the alarm blinks will give us more information to go on if its not.
I install these regularly for 3 years and the only time I saw this incident was when I had a bad connection inside the J-box.
Jan 11, 2011 | Pentair 4-Speed 230v IntelliFlo 4x160...
I have a flashing orange light and cant find the manual, I have changed the inks but its still flashing?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Dec 02, 2010 | Canon Office Equipment & Supplies
Do I need to clean coils in haier hwro6xc7 air conditioner
You always need to keep both coils clean on your AC.
The evaporator coil (where room air is drawn in and through a filter) - is easy to keep clean - 'just keep the filter changed on a regular basis and you will probably never need to actually clean the evaporator coil. Occasionaly you might need to brush the coil with a brush or something - but this is not a big concern.
The condenser coil (where hot air blows from) is even 'easier,' for you don't have to mess with a filter, just keep the coil clean. You can occasionally pull the unit (when needed) and wash this coil with a water hose. In reality this coil will not get very dirty very fast - although it will (over time) acquire some dirt/dust, but as I say - it is pretty easy to keep clean. Note: Condensing units (split systems) that sit in a yard will get much dirtier much faster than window/thru the wall units such as yours, but you still have to keep a eye on the coil.
A good rule of thumb - is to change the filter (in front of the evaporator coil) - monthly.
As for the condenser coil (where hot air blows from) you can easy see it and just need to keep it clean, with no set (usually) time to do so.
good luck!
May 02, 2010 | Haier HWR06XC5 Wall/Window Air Conditioner
It keeps flashing E and then 3. what do I do?
MP150/160 resetting errors
Do it : 3 times Orange EEPROM reset
button pressing
procedures below.
procedures below.
Sep 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
Sep 05, 2009 | Thermador HNW48YS Stainless Steel Kitchen...
Kitchen Ranges Logo
575 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
