Question about Dyson Vacuums
When I turn the vacuum on there is no suction and when I then go to turn it off it sounds as though it is backfiring. It is a Dc39
  • Official Brand Answer
  • 2,572 Answers
Hi Robyn, it's Jack at Dyson.
From what you've described, it sounds like your DC39 is blocked. This would prevent the machine from picking up as well as it should do, and will cause the relief valve to activate, making the 'backfiring' noise you've mentioned.
We'd recommend checking the floor tool, telescopic wand and hose for blockages. If you can't find any, it's likely the blockage will be in the duct hose. Our Online Support guide will walk you through how to clear this: http://www.dyson.com/support/dc39/dc39-animal/diagnosis-root-menu/performance-flo-extension-tube-suction-check-dc39
It's also a good idea to give the filter a wash, as shown in the video attached. This should be done at least once every three months in normal use. We recommend using cold water without any detergent, then allowing the filter to dry completely for at least 24 hours before replacing it.
I'm confident this will resolve the issue, but if you would like any further advice from our experts please email askdysonUS@dyson.com and we'll be in touch as soon as possible.
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Posted on Oct 17, 2013
2 Suggested Answers
  • 4088 Answers
SOURCE: My Electrolux Upright vacuum cleaner will not
The air passage form the brush area to the bag is plugged somewhere. Remove the lower plate and the bag above so that you have access to the air passage from both ends. A hooked, stiff wire will help pull the debris out. This problem is usually caused by delaying a change to a clean bag. A higher-pitched motor/fan sound is a clue that air flow is being restricted.
Posted on Oct 19, 2009
The roller stops as soon as machine turns on, then air leaks with poor suction. How do I fix it?
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC39 Multi Floor, but from what you've described it sounds like your machine may have a blockage in the floor tool, wand, hose or inlet duct. This is simple to resolve by following each of the steps shown in our video guide:
If you continue to have issues with the suction performance or the brush bar in the Triggerhead floor tool after checking for and removing any obstructions, our experts are on hand to help you further. You can reach the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Apr 11, 2015 | Dyson DC39 Multi floor canister vacuum...
Brush bar doesn't spin on dyson on dc39
DC39's Trigger head floor tool is powered by a turbine, driven by your vacuum's suction. Following these simple checks should help you resolve any issues which could be preventing the brush bar from rotating as normal: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/trigger-head-not-working/dc39-check-the-brushbar/dc39-check-triggerhead-tool
If you'd like further help from our experts after giving this a try, please get in touch with us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we can also confirm if this is covered under your Dyson parts and labour guarantee.
Feb 24, 2015 | Dyson DC39 Animal Canister Vacuum
The turbine head of my DC39 stopped working. The suction is super, took the brush out and disconnected the hose and looked into it, no blockage is visible looking. ideas?
hi russ, it's jack at dyson.
i'm sorry to hear you're having difficulty with your dc39's triggerhead floor tool. i appreciate you've already checked for a blockage, but you may want to follow the steps shown in our online support guide just to make sure there's nothing you've missed: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/dc39-check-extension-tube
if you find there's no improvement after running through these checks we're happy to help further - and if a replacement is needed, we can confirm if this is covered under your dyson warranty. you can reach our experts directly by calling on 0800 298 0298 (uk), 1-866-693-9766 (us), 1-877-397-6622 (ca) or 1800 239 766 (au).
Jan 20, 2015 | Dyson DC39 Animal Canister Vacuum
Why does my Dyson Dc-39 vacuum have good suction, but the beater bar barley turns?
The beater bar may be clogged with pet hair and other debris. You may have to do some disassembly to get everything working again.
Dec 18, 2014 | Dyson DC39 Animal Canister Vacuum
Why does the brush on my dyson 39 not work
Hi Anne, it's Jack at Dyson.
If your DC39's brush bar won't rotate, but you're confident your vacuum has strong suction, we'd be keen to take you through some further troubleshooting checks when you have your machine to hand. If we can determine that there's an issue with the Triggerhead floor tool itself, we can confirm if we can replace this for you under the free Dyson parts and labour guarantee.
When you have a moment, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide further assistance.
Dec 01, 2014 | Dyson Vacuums
Power pushing reset
Hi Paula, it's Jack at Dyson.
Like most Dyson vacuums, DC39 is engineered to shut itself down for protection if it starts to overheat. This will usually be due to a blockage, and the filter may also need a wash.
You should find the machine will reset itself after it's had at least three hours to cool down. But to prevent any damage to your vacuum, please give the filter a wash, and check for any blockages.
To check for any blockages in the floor tool, wand, hose or hose inlet, please follow the steps shown in our online Support guide: http://www.dyson.com/support/dc39/dc39-animal/diagnosis-root-menu/performance-flo-extension-tube-suction-check-dc39
DC39's filter should be washed once every three months in normal use, as shown in the video below. Use cold water without detergent, and allow up to 24 hours for the filter to dry completely before replacing it.
I'm confident this will resolve the issue, but if you'd like any further advice after you've given this a try please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 24, 2013 | Dyson DC39 Animal Canister Vacuum
WHEN EVER I PLACE THE SPINNER ON THE VACUUM IT STOPS SPINNING
Hi Linda,
I am sorry to hear you are having difficulty with your DC39 brush bar. The brush bar on your machine is air driven. Generally, if the brush bar stops rotating it is due to an obstruction that is preventing air flow. Please visit the appropriate link below for step by step instructions on locating and removing a blockage from your machine.
US:
UK:
http://www.dyson.co.uk/support/dc39/dc39-multi-floor/machine-is-not-working/dc39-check-extension-tube
We also recommend inspecting the brush bar to ensure it is free of any debris and washing your filters. If for any reason the recommended trouble shooting does not fully resolve the problem please contact our Helpline to speak with an expert.
US - 1-866-693-9766 or UK - 0800 298 0298
Best wishes,
Jessica
Dec 15, 2013 | Dyson DC39 Animal Vacuum
Turbo head on DC39 animal will not spin. I have removed any hair etc caught around the brush but still no spinning..
I have the same problem with my DC39 Animal's brush bar. Im on my 3rd one in 9 months of ownership. The DC39 brush bar is driven pneumatically (there is no electric motor in the brush head) and switched on and off via a suction activated pneumatic ratchet within the brush head. The moving components are actuated by bellows. Ive found that the glue holding the bellows fails stopping the ratchet working intermittently at first and then completely as the bellows comes away completely. At first you can help the ratchet by tapping the brush head - the red ratchet ring can be seen to click round. This, in my opinion, is an inherent weakness of the DC39 design and cannot be easily repaired. The only solution is a new brush head. Luckily Ive got a 5 year warranty and at the current rate I will have got through about 20 brush heads !
Mar 31, 2013 | Dyson DC39 Animal Canister Vacuum
Vacuums Logo
81 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
