Question about Toshiba Televison & Video
CHANGE BATTERIES ON TOSHIBA AIR CON WH-H04JE - Toshiba Televison & Video
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
I need a replacement remote for my toshiba air-con RAS-10NKP-A2 where can I buy one?
Setup codes to check with Toshiba brand TVs are, 0028,0022,0021,0026. If you wish to get more try this link. http://electrohelponline.blogspot.com
Dec 23, 2013 | Televison & Video
Not responding to main air con unit
That sounds like a programing issue between the wall unit and you remote you might try reprograming it , often times when power goes out or you change batteries they loose there programing.
Feb 01, 2013 | Heating & Cooling
Remote Batteries
What brand and type of air con do you have.
normally the sliding part of the remote that slides down , you keep pulling it down and it comes of . You can do this is one fast motion to . The batterys are hidden behind that . the front bottom part.
Jan 31, 2012 | Heating & Cooling
My REMOTE CONTROL IS NOT WORKING I HAVE TO SWITCH IT OFF FROM THE MAIN HOW CAN I GET A RELACEMENT IT IS AN LG SPLIT SYSTEM AIR CON?
First try to change the batteries before replacing the remote control. Buy replacement from SEARS or any LG suppliers. Sometimes the problem is in the control board circuit due to condensation.
Sep 02, 2011 | LG Heating & Cooling
What does the Wh stand for on recharge batteries like sony 7.2V 5.0Wh?
The watt-hour (symbolized Wh) is a unit of energy equivalent to one watt (1 W) of power expended for one hour (1 h) of time. The watt-hour is not a standard unit in any formal system, but it is commonly used in electrical applications.
The designation 5 Wh indicates that the battery will power a load of 1 watt for 5 hours or a load of 5 watts for 1 hour.
Dec 22, 2009 | Batteries.com Cameras
Why do my radiatordoesnt turn off wh fan
may need new thermo switch or air con is on
Aug 25, 2009 | 2000 Mitsubishi Galant
My heater will not work
the remote is the "brains to the heat pump/air con, low battery power or spent batteries will effect the cycle between indoor unit and outdoor unit, replace the batteries and turn off curcuit breaker at main switch board for a couple of minutes and turn back on. Try restarting unit.
Jun 05, 2009 | Heating & Cooling
Remote control not responding to tv
You need to program the remote to work with the TV. And I hate to point you this way, but I've looked around for the manual on this remote, and can't find it, so, go to the Toshiba website and email Customer service that you have lost your manual for the remote. See if they will email you one. I bet they will.
Jan 30, 2009 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
426 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
