Question about Frigidaire ATF6000ES Front Load Washer
Code 0E not draining the water - Frigidaire ATF6000ES Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Hello Faye, thank you for allowing me to assist you!
I understand that the washer will not drain; however is it making a humming noise? If so, either the drain or pump is clogged and needs cleaning. Let's try setting the washer to spin cycle on. Will water pump out? If it does not, then the unit could possibly be experiencing a communication error with the control board, faulty pump, timer or door lock assembly. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs. You can often locate a qualified provider by visiting the manufacturer website.
Posted on Oct 15, 2013
Error meaasage 0E Drain Error what to do?
This OE error or fault code indicates that the machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Finally, if the drain line is clear and the pump seems to be clear, you may need to replace the drain pump assembly.
Mar 01, 2016 | LG 4681EA2001D Original Water Pump Drain...
WHAT DOES IT NEED DONE WHEN ERROR MESSAGE SAYS 0E
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
Oct 24, 2015 | LG WM2301HW Front Load Washer
My Samsung front loader is taking in water and flashing 0E. Can you help tell me what my problem is? Thanks
An OE code (not 0E) is an overflow error. Too much washing powder/liquid may have been added. Turn off power, wait 30 seconds and turn on power again. You should hear the drain pump operate to drain the machine.
Feb 22, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Error code 0E on LG WM1290 FHB ?
The error code 0E stands for obstruction error, meaning that the drain line is obstructed. This is why the spin fails as all the water is not being drained. Check the drain hose for kinks and clean the drain filter. If they are not the problem, there could still be an obstruction in the drain hose in or about the drain pump.
Dec 28, 2014 | LG Washing Machines
LG washing machine error code 0e....filter clean and machine level but still have error code
The drain pump on the machine could be faulty. This pump cannot be repaired it will have to be replaced if found to be faulty.
Sep 08, 2014 | LG Washing Machines
I have an lg wd12650tp and it has stopped full of water with the code OE showing. I've tried emptying the filter at the front but it still wont drain? Any suggestions? btw apparently the code means...
Hi.
Error 0E is drain error.
Access the drain pump, located behind the service door at the base of the machine, in the front side, right below the washer door.
Disconnect power before starting the procedure.
Open the door and undo the pump attachment. Have a container ready to collect a good amount of water.
If that does not fix the problem, then there may be a fault. Further blockage, faulty pressure switch and faulty drain pump are the faults that can trigger error code 0E.
You can find parts and diagrams for most models using the link below:
Where do I find parts and diagrams?
Please click here to read an article showing how to fix common drain problems.
Regards.
Oct 21, 2011 | Washing Machines
Code 0E
That is actually a "DE" code, which stands for Drain Error. Open the access door at the bottom left on front of the machine. Use the small hose there to drain the last of the water out of the machine. Open the bigger knob in there and pull out the attached filter and clean out the filter. If there was nothing in the filter, replace the pump motor.
Feb 19, 2011 | LG WM0642H Front Load
Hi my washing mashine wont spin, and code 0E comes up on sreen and start button starts flashing PLEASE HELP THANKS
That is actually DE. (Drain Error) Open the small access door at the bottom left corner of the front panel. Use the small hose to drain the remaining water out of machine. Unscrew the big knob and pull it out to clean out filter. (If filter was clear, replace pump motor.)
Jan 01, 2011 | LG Washing Machines
Getting error code 0E on LD-14AW3 model dishwasher after 2 minutes. Checked drain hose and water seems to be coming out but won'y go any further in cycle Also makes a loud humming noise when running.
To little info, but looks like pipe is much to low. Not getting the opportunity to fill up properly.Raise it higher.(Im asuming that you can hear the drain pump run and water is being pumped out as wall.
Aug 09, 2010 | Dishwashers
De error code on samsung topo loader stops working
0E - OVER-FLOW ERROR
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 28, 2010 | Samsung SW62ASP Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
