Question about Blenders
Breville CBL6 with small leak and blade turns without power but the motor is OK
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: the coupling to the motor is loosely rotating on
The coupling bush wear out in due time and must be replaced. if there is a wearing detected it must be changed or it will result in failure of the bush/ bearings of the motor and jar. You will need to remove using anti clockwise direction, Get the correct spare part from the dealer to replace. Good day
Posted on Aug 16, 2010
I have a Breville 800BLXL/B blender that won't power on. When plugged in, the power button will not illuminate.
Most likely its the large yellow capacitor on the main circuit board. I've had this fail on my Breville coffee machine and blender.The coffee machine was a 1.5uf capicitor nd the blender 1.0uf.rated at 275vac. what happens is over the years of power spikes and surges etc the capacitor breaks down to a lesser value than its original "capacity. ie 1uf down to 0.3uf it provides enough power to drive the display electronics But not enough to power the relay to turn the motor on.
. there are 3 screws under the label. Peel off the label . remove the 3 screw. remove the fan cover.
to remove the fan . hold on to the blender jar mounting drive and unscrew the fan. a small square nut is what holds the fan on. remove the rubber feet an the 4 star screws under the rubber feet.
you can then remove the base.
Most likely the fuse is OK. However I've found ( in repairing mine) the big yellow capacitor 1uf 275vac is at fault. over time and power surges it breaks down and cannot pass enough "power:" for the power supply to call the relay to turn on the motor. You van get a new capacitor from Jaycar ( aus or NZ ) for about $6.00 . unsolder the capacitor and solder a new one in. reassembly is reverse. Just be careful not to trap the micro swicth wires ( black) under the motor surround.
Jan 21, 2017 | Breville Blenders
Making a high pitched noise while blending; is motor breaking down?
there are some Breville Blender troubleshooting tips here
http://brevilleusasupport.com/bbl550xl/troubleshooting . Tied in with that, a high pitched noise could come in from a few directions:
Some blenders will use reduction gears to get more torque and power out of a high RPM, lower power motor. If this is the case, the whine could be from the motor, though if you hadn't noticed before, that would not be reassuring.
Per the troubleshooting, check that the blade is firmly attached, and that the coupling from jug to base is firm. If there are gaps or loos spots, there can be buzzing or whining between sort-of-spinning parts and shafts or bolt threads.
Check the motor base for dried spilled-on margarita mix or marinara sauce or what have you. they try to seal this pretty tight in a blender, but it has to spin, so food spills can get in the gap and cause friction and resistance, which can in turn cause whining noises from parts not expecting the load. If you do any cleaning or poking there, make sure you unplug the blender first. Shocks are not fun.
likewise, make sure that blade rotates easily from turning the coupling on the outside of the jug. If not, the bearing may be siezed or contaminated. That you'd likely want to fix by replacement.
Hope this helps!
D
Nov 19, 2015 | Breville Blenders
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
The blade has become VERY tight and will hardly turn. When I turn on the blender the motor strains to get it turning, and when it does it makes a horrible sound. I've stopped using it because I don't...
put a socket or a wrench on the nut in the middle of the blades, and hold the other set with a set of pliers, and, as the original poster said, it is reverse threaded.
Mar 15, 2011 | Breville BBL550XL 5-Speed Blender
The coupling to the motor is loosely rotating on the motor shaft. Has the threads on the coupling worn out. it is a breville optiva cbl6 blender
Aug 16, 2010 | Blenders
Breville Blender
I need the blend jar for Breville Blender electronic Model BL3. I did not notice that a stainless steel spoon was in the blender. When I switched it on the crossed blade broke off.
Oct 15, 2009 | Breville ikon Hemisphere Blender - Silver
Lost Seal for Blender
I would suggest you contact the company at
http://www.breville.com.au/ (click on "what's on your mind") and let them know the problem... they should be able to direct you to a UK parts source or help you in some other way.
Mar 23, 2009 | Breville Blenders
Breville blender bbl550 stopps after 5 seconds any setting
Mine does this as well... 5 seconds of operation and then OFF.
My guess is this is a fail safe where the blender is turning itself off to avoid overheating and what could potentially cause this overheating is the blender is struggling to turn the blades. What could cause this struggling of turning the blades I am guessing is a lack of oil in the blades rotating parts.
If you hold the circular blade part and turn it, you'll probably find that its hard to turn? Mine is... and I oiled it up a bit and found I got a bit more usage out of it... although only temporarily.
Ideally I need to pull it apart and oil it properly.
Jan 29, 2009 | Breville BBL550XL 5-Speed Blender
Breville 600XL not turning on
My BBL600XL stopped working because of a blown fuse. You need to remove the phillips and torx head screws out of the bottom. Then remove the base. There you will clearly see a fuse on the circuit board.
It appears to be a 10A 250V fuse.
Jan 28, 2009 | Breville BBL600XL. 5-Speed Blender
Blenders Logo
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
