Question about Acer Extensa 5620-6119 Notebook
My acer 5620 has a loose power jack how would i replace the old one with a new one can the old one be fixed
How do I fix loose ac jack on acer extensa 5620z?
If your laptop is under warranty or has a service contract, I would send it in for service according to the terms of sale. If your ac jack is loose you should check the cord in case the end is damaged and if your power cord isn't damaged you need to check the screws and connection and that's going to require removing the battery and the bottom cover of your laptop. It isn't difficult to replace most of the hardware in the Acer laptop, but you'll be exposing circuit boards and wires and there are all kinds of things that can be damaged if you're not careful, so I don't recommend taking apart your laptop unless you are certain you can replace the hardware without damaging other sensitive components. I really suggest that you have someone qualified in computer repair take a look at your laptop.
Also, once you open the back cover or take apart anything on your laptop you will void your warranty. most laptops have stickers and tabs placed on your laptop and once you remove the sticker it causes damage to the sticker and it lets the manufacturer know that you've attempted to repair it and that voids the warranty.
Once you check those see if the battery works, it may need replacing. Good luck!
May 30, 2014 | Acer Extensa 5620 Notebook PC
Acer aspire one charging port loose
If I recall this model line uses a fixed DC power jack directly soldered to the main board. When they become loose, you can visually inspect the jack itself (without the cord plugged in), and use a pen or probe to see of the center peg is excessively loose. The common result is the solder connections have been broken between the DC jack and the main board. Often the jack itself needs to be replaced (involving complete disassemble, de-soldering old jack, cleaning, repair PCB if needed, and re-solder new jack in place.
TIP - if it is not charging, remove battery, and gently put pressure from different angles with the power cord plugged in, and try to turn it on. If it turns on with pressure from a specific angle, it would indicate the DC jack is indeed loose, and likely needs to be replaced. It works becomes the pressure is making the electrical contact that has other wise been broken. ALSO, if it turns on easily, yet losses power at certain angles, its a similar issue.
TIP2 - If it still indeed charges regardless of the angle, and does not lose power, it may be a "Modular" DC jack, meaning the jack connects to the main board through a wire harness, and is less prone to breaking the electrical contacts, and the jack is simply loose inside it's retaining clips/slides. Minor disassembly and hot glue are quick fixes for this since usually the plastic clip/slide in the chassis have broke.
GOOD LUCK! :)
Dec 06, 2013 | Acer Aspire One PC Notebook
Acer Extensa 5620: The power supply jack is loose when you plug it into the laptop. Sometimes it will provide power and sometimes it will not (orange battery light on front of laptop goes on & off)....
System check
1. estimate the extent of damage, possibly requires entire board replacement housing the extension power supply modulators, possibly due to physical damage on contact.
2. Aslo check the battery life since could determine the possibilty of substituting power chord from currrent outlets with batteries
The device would not connect to power outlet without a properly functioning battery installed. A depleted battery could not be replaceble by connecting a source out power outlet. each parts of the power complement the entire process of achieving computer experiece.
Consult a technician insisting the replace the entire power system of battery and ac adapters and also fixing damages on the mother board may be contributing to power leakage
Dec 02, 2010 | Acer Extensa 5620 Notebook PC
Powerjack is loose when plugging in charger.no power,no lights battery can not be charged.
In order to fix this problem, you will have to fully disassemble your laptop to get access to the motherboard & the power jack. If the power jack is not broken but only loose, you can re-solder it to the motherboard. Otherwise, you will need to buy a replacement power jack (usually less than US$ 10), de-solder the broken power jack, & then solder in the new one.
When this is done, re-assemble back your laptop.
Nov 27, 2010 | Acer Aspire One PC Notebook
How do I replace the DC power Jack socket on my ACER Extensa 5620 .Mosel NO MS2205
Here is a place to buy a dc jack for the motherboard:
http://www.buy.com/prod/ac-dc-jack-power-port-connector-socket-for-acer-extensa-5220-5420-5620/q/sellerid/23962916/loc/101/215782024.html
This video will show you how to replace dc jacks in a laptop:
This page has the service manual for your laptop:
http://www.scribd.com/doc/13062016/Acer-Extensa-56206419-Service-Manual
Sep 22, 2010 | Computers & Internet
Acer extensa 5620 laptop will not boot uo
Then you can check 2 things to see if the machine will boot. If not, then you'll need to get it repaired. FYI, I repair Acers.
Step 1 - remove the battery and the A/C adapter from the back of the computer for about 2 minutes. Replace the battery and the adapter and try to start the machine. If that doesn't work, go to step 2.
Step 2 - Check that the A/C adapter is getting power and the LED for battery charging on the front of the computer lights. You can check the voltage from the power supply with a volt meter, if you have one -- it should read around 18-19 volts. If either of these steps don't work, you'll need to get it looked at.
Problems could be with the power supply, motherboard, power switch, CPU or something else that only time and expertise could properly track down.
Jan 08, 2010 | Acer Extensa 5620-4020 Notebook
How to wire power jack
There will be a power jack positively on left hand side of the notebook.
As that jack is for the power input only so you can easily find it by observing the size of the adaptor PIN.
Nov 30, 2009 | Acer Extensa 5620 Notebook PC
Acer Extensa 5620-6119 Notebook Logo
164 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
