Question about Electronics - Others
What are audio cleaners used for? - Electronics - Others
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 14 Answers
Audio cleaning software is used in the post-production phase of creating an audio track or a video. They help to get rid of unwanted sounds in the audio tracks.
Posted on Oct 14, 2013
Sony Handycam ux10/ux20. Why isn't it recording audio?
sir,
please use an external microphone and test, if there any corrosion or dust inside the mic jack, it will cause to dis recording of audio, use some cleaner liquid in the jack, still the problem persist, must open the unit and check the audio circuit with test equipment like oscilloscope.
Feb 01, 2016 | Sony Video Cameras
Scratchy rec audio
Could be several things, controls need cleaning, use contact cleaner, could be bad speaker, replace, caps on audio section need replacement, service with correct components, could be bad audio amp, replace with correct replacement. Not enough info to say for sure
Mar 13, 2014 | Alinco Radio Communications
I have a JVC XU-301 BK...When i play MD i get some static disturbance in my audio out put..however when i play Audio CD it workd fine and out put is cleare
I'd suggest you get a MD head cleaner or give the MD head a blast of comporessed air, also check your MDs. If someone gave you a dirty MD the disc can have dust in the case which does exactly what you are talking about.
If you get the MD head cleaner use it sparingly or it will wear the head out (MD cleaners come in sets of two one for the upper head the second for the lower head). You can find them on eBay.
Jan 12, 2014 | JVC XU-301BK 3-CD/1-Minidisc...
Playing music from my computer into my tx-ds494 it has been cutting out into a really loud fuzzy noise like when your between radio stations
Sound like a poor connection to me. Verify the integrity of the cable on some different equipment if possible. Use some electrical contact cleaner such as DeOxit or Servisol Super 10 on the cable connectors and also in the computer audio output. Spray cleaner on the jack and then push in and out of the socket several times to scrub the connectors.
If you are using built in sound from a PC, it may be worth getting an external audio interface as the standard internal ones are not known for their hi-fi sound!
Sep 20, 2011 | Onkyo TX-DS494 Receiver
Licence key?in PC cleaners
Well, you must have downloaded that pc cleaner from internet..then unistall it..or if you need a pc cleaner.. try to purchase a complete pack. i don't prefer if a pc cleaner if downloaded from net, thought it would give their product 100%, it will pop out anytime when you are on middle of something, other thing is , you haven't mentioned which pc cleaner you are using? Please install a genuine cleaner, it comes with license key and also claimable if anything goes wrong. Good luck
Sep 18, 2011 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Hi Guys, I have a Realistic home audio reciever STA-46 that I tried to restore. I think I sprayed contact cleaner on some fins in tuner section which may have caused the tuner to seize uo. Is there a way I...
The tuner fins are a component of the variable capacitor that is the most important component of the tuner. I understand the logic, but it does not like contact cleaner.
See if you can get some compressed air and/or a small paintbrush and try to dry it out. Typically the cleaner will evaporate in a few days and hopefully it will operate again.
Generally you should stick to using contact cleaner (and use one with lubricant, like Radio Shack's "Tuner Control") on pots and audio jacks if necessary.
Mar 02, 2011 | Audio Players & Recorders
The audio device supported by this application is not detected. the application will exit. Sound blaster 5.1vx with Creative T6100
My Audigy Sound Blaster 2ZS got the same problem . And just sometime that problem appear without warning and proper reasons .I have had try some difference way like restore back time ,remove software though Add and remove .Reinstall software from CD ..etc ..etc .But i was success after remove software and use Driver Cleaner NET software to clean all Creacive Audio lite ,Creactive Audio Driver backup.. etc...etc .Then use the Creactive CD to clean install ...Driver Cleaner software with keygen :
Sep 11, 2010 | Creative Labs Sound Blaster Live! 5.1...
VCR not functioning
You probably used too much "wet" cleaner on the tape which caused the heads to get fouled. You could try running the wet cleaner through again but use a little less solution than recommended. Failing that you could have the mechanism out of alignment which will require professional help to repair.
Oct 06, 2008 | Audio Players & Recorders
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Mar 14, 2017 | JVC GRD650US DIGTL VIDCAM 32X ZOOM 16:9...
Electronics - Others Logo
680 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
