I am working on a Amana Tandem 7300. It stops working when it gets to the spin cycle. Hear motor humming but it won't spin. Took back cover off and found 2 pieces of white plastic broke and laying in the bottom and a broken bolt approx 5 in long sheared at the thread line. Seems like motor is getting juice but refuses to operate. Cannot locate where broken plastic and bolt came from. How do I check the motor to see if that might be the problem? The belt is in place and is ok. Can u email me elect. schematic or offer me another solution to locate and fix the promenade. Have meter n know how to use it. Thank you.
Noggin
  • 944 Answers
SOURCE: WFMC3200UC Broken Plastic Piece
here is a link which shows the exploded diagram for your washer - perhaps you can identify the part; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM and here is the parts list; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM at the top you can order parts direct from bosch. Here is the link to the user manual if you need it; http://www.bshextranet.com/files/techtoolbox/WFMC3200uc.pdf If you have no luck with this then; Best thing you can do is to take a picture of the part and where you think it came from, and either post it again here or e-mail it to your nearest bosch dealer (page 26 of the manual has a phone number). Hope this helps :) ps - if you do contact them, please tell Bosch how good the access to their product literature is - if all manufacturers did this our landfill sites would be half as full - they deserve some praise :)
Posted on Mar 18, 2007
  • 57 Answers
SOURCE: removing motor to replace belt for agitator
first unplug washer then there are 4 half inch bolts on the motor holding it to the frame take those out unplug the motor harness. then twist it out you may have to take the hoses off. then there are 3 torxs screws in the pump take them out and put new belt on same way you took off and then reverse the steps and you will be ok
Posted on Feb 16, 2008
aborcass
  • 2651 Answers
SOURCE: Amana NAV2330 Wont Agitate or Spin
i would assume that perhaps you did not wind hte belt correctly arround the legs of the pump and therefore are not putting the correct tension on hte pulley(remember to hook spring back up to tension idler?)
Posted on Dec 08, 2008
  • 574 Answers
SOURCE: Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Posted on Aug 24, 2009
Testimonial: "Thanks for your input. I'll look into it. If the problem is a bearing, is it an easy fix or should I start saving for a new washer?"
richroth
  • 9472 Answers
SOURCE: amana tandem 7300 stopped ,door is locked wash
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Posted on Nov 28, 2010
I have a Amana tandem 7300 front loader washing machine. It's stopped working nothing's happening except the display lights. Stopped in the middle of the wash cycle is there a reset button? Offbalanc
The only reset is to unplug the machine from power for about 5 min's and if that fails you may need to replace the washer timer control board.
Apr 19, 2017 | Amana Washing Machines
Amana tandem 7300 washer hums but won't spin. Stopped with clothes and water in it.
If you would drain the water out with a hose (siphon it out) and remove the wet clothes, then look underneath the machine and see if you have a drive fan-belt, you may find it broken or slipping.
A very few machines have a drive shaft with a coupling instead.
God bless your efforts.
Jan 02, 2017 | Amana Washing Machines
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
My amana tandem 7300 will not turn on any cycle it will go back to wash but does not turn on it just beeps please help if u can
It may think the door is open, front load machines will not proceed to fill if they cannot sense a locked door...
Apr 22, 2016 | Amana Washing Machines
My Amana tandem 7300 front load dryer was making
could be that the belt has come off of is jammed take the back off if it come off and take a look or turn on it side and look under it could also me a wight has come off and jammed
Oct 12, 2014 | Washing Machines
Door will not unlock
there should be a reset button in front of the machine on the right side..hold until you hear a click from the door. or go to
How-2 repair.com
Mar 31, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
Nav5800aww
The motor sounds like it is overloading and kicking out. Most likely cause: binding brake pads.
Sep 13, 2013 | Amana NAV5800A Top Load Washer
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Nov 28, 2010 | Amana Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
