Question about GPS
Gyro reapeater Model SIMRAD AR78. the repeater
Gyro reapeater Model SIMRAD AR78. the repeater keeps on rotating and not able to stabilize.
  • Orlando
    Orlando Oct 17, 2013
    problem solved, I did open the gyro-compass checked the fluid level was low , I topped up. now is okay.
How to change bands. The radio won't go below 220.00MHz. I want to go to Hit my repeater at 147.120MHz ? HELP
your repeater transmits at 147.120,your radio transmits on a different frequency to the reapeater otherwise you would repeat right from the radio,you need to program your radio and repeater together,try a baofung radio and vertex 100 repeater,i have them and they work good,the radio is 30 bucks on ebay
Jul 13, 2015 | Universal Professional TYT TH-9000 VHF...
Minka gyro fan noise, my fan has a popping sound at the same point in each full rotation.
i'd take it back and get a replacement. It has a lifetime motor warranty. I used to sale Minka Aire but always had motor problems.
Apr 19, 2013 | Minka Aire F602-BNCH Gyro? Fan
Hi I have a gyro helicopter which spins in circles after taking a hit... Its a Police Gyro Helicopter from thumbsupuk Do you have any solutions for this? Thanks
Make sure that the balancer wheel/rotor at the rear is not damaged while it had the fall/hit.
If so make sure that the tails is rectified. Once the rear is damaged the helicopter stabilizes on the movement of the rear rotor as the top main rotors need a counter balance.
So it is possible that this mechanism is damaged and must be recitfied.
Dec 30, 2010 | Toys
I have the intex saltwater system and green water. can i shock the water?
you will need to do a few things.
Start by shocking the pool and then in 12 hours or so you will need to brush the sides and bottom
Now wait a few hours for the pool to settle and vacum
now clean out your cartridge and start filtering without the generator.
Now add in some liquid non foaming algecide
Now a day later repeat the brushing then vacum again clean filter and reapeat till your pool clears
Remeber to add a good stabilizer so that the chlorine that is generated holds longer and get test strips that read #'s to test salt you want to have the salt as close to 3000ppm as possible
Once pool is clear continue to use the non foaming algecide every week
Jun 30, 2010 | Intex Automatic Salt Water System for ...
I cannot get a position on my Simrad CE33 chartplotter/sounder
Ensure that the external position to be OFF, refer to manual below. See interface display in [MENU],7,2
Try resetting the Chart Plotter to factory settings. Use the Delete Memory and Factory Preset options as described in section 9 of the user manual below:
M A N U A L Simrad CP33 Chartplotter
Sep 05, 2009 | Simrad CE44 GPS Receiver
The camera vibrate when i took a picture
Your camera has a gyro image stabilizer. The Gyro is faulty as many are in these camera. Go into menu of the camera and turn of image stabilization. This should solve the problem.
Jul 02, 2009 | Sony Cybershot DSC-T20 8.1 MP Digital...
GPS Logo
55 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
