Question about LG KF700 Triband 3G HSDPA 3MP A2DP Phone Silver
LG KF700 can't get full functionality from PC software
Installed KF700 software. When the phone is plugged in to the PC with the provided USB cable, the software recognises the phone is connected but only offers limited functionality, i.e. back up and synchronisation. You cannot, for example open any of the folders in the tools section, so you can't open folders for pictures or music, which means you can't drag and drop anything from your PC to your phone. Another blogger mentioned that this is due to a locked mms setting, but I don't know where to find this or what it means. I have uninstalled and reinstalled the software and tried it out with XP and Vista. Same prob. Please help.
  • mumwillfixit Apr 24, 2009
    I have contacted LG (customer support Australia). They went through a bunch of obvious stuff, but otherwise had no idea and frankly I don't think they knew a lot about the phone or the software.
    Hi Kevin
    I've tried this with no luck. The "LG" folder won't accept the in coming file. Thanks for trying.
    Genius:
  • 1,847 Answers
Go to my computer and check for the new drive which comes when you connect the phone.
Try open the drive and drag some files, hope that should work.
Let me know ....
Kindly rate the answer...
Thanks
K
Posted on Apr 24, 2009
  • Legin Varghese
    Legin Varghese Apr 24, 2009
    What happen when you try with the software to transfer the file.
    Make sure the phone will not accept all file formats, it will only accept the one which it can execute.
    Try the following :
    Reinstall the software back to computer and then try.
    Try a diff memory card.
    Update the firmware and then try.
    Thanks
    K
  • 854 Answers
For locked mms, you have to contact your provider (mobile service) as they might require you to download some settings before you can use MMS. Have a look on the services website and it may have some more info there, otherwise call your customer help line.
  • redhaze89
    redhaze89 Apr 24, 2009
    If all possible troubleshooting has been done. I think you need to consider this option.
    MOBILedit! is software that brings the ability to control the phone from your PC. After connecting the phone via cable, IrDA or Bluetooth, view the contents of the phone on the PC, do full-text searches, dial numbers, send SMS
    or MMS messages. With a simple click, backup all your data, copy them
    to different mobile phones and manipulate your contacts without even
    touching
    the phone.
    When you receive a message, it arrives on your PC in a similar way as
    an email; simply reply to it or move it to the archive. You will become
    much more productive as a result.
    MOBILedit! has two breakthrough features never before seen in the
    mobile world. The mBoox and Shopping List functions will add fun to
    your daily routine and make your life more efficient than ever before.
    With the mBoox technology, you can read
    documents in your phone, including pictures, in one scrollable
    formatted file. Copy online articles, driving directions, lecture
    notes, ebooks, study material, guides, jokes, contracts, or any text
    documents to your phone and read them on the go.
    The Shopping List allows you to write lists of any kind into MOBILedit!
    and send them to your phone to be stored. Not just for shopping-create
    to-do lists, homework lists, personal goal lists, workout routines, and
    many more. Forget about the crumpled paper list in your pocket or the chance of leaving it at home. Click to items you have completed and they will cross out. No need to have a pen with you.
    Features:
    * communication via infrared, Bluetooth or cable
    * able to connect multiple mobile phones at one time and manage their data concurrently
    * full phone and SIM card status information (including signal
    strength, battery status, current network operator, connection type, hardware and software revision, IMEI, etc.)
    * ability to read selected data from the phone on demand (this refers to the fact that you needn't read everything, you can pick the desired information to be displayed)
    * file system enabling work with multi-media files stored in a phone
    like ringtones, photos, MP3's, themes, and java applications
    * a powerful editor for phonebooks stored in phones or SIM cards
    o multilevel undo
    o emphasizing all unsaved changes in phonebooks
    o intelligent differential write will save only changed items
    o intelligent phonebook synchronization for Sony Ericsson phones (if you change the content in the phone, just the differences are read into the phone instead of the whole phonebook, it is much much faster)
    o support for structured items (more data for one contact, such as fax, more phones, email, address etc.)
    o fulltext search across all contacts
    o comfortable internationalization
    o easy sorting and filtering of your contacts
    o swap the first name for the last name with one click
    o swapping contacts with drag&drop function
    o drag&drop contacts between MOBILedit! and other programs like Word, Excel, etc.
    o import and export of contacts
    * online dial control from connected phones, also hang-up and busy
    * handling of incoming calls through MOBILedit!
    * full SMS management
    o send SMS messages, automatically stores them to Sent Items on the PC
    o send long SMS messages
    o handling of incoming SMS through MOBILedit!
    o automatic conversion of SMS characters into GSM compliant character set
    o sort, read, and archive your SMS messages on your hard drive
    * Wizard helps beginners with general MOBILedit! Settings
    * archive and AutoBack-up will protect your data in case you lose your phone
    * multiple backups can be created for a single device and any of them can be restored when needed
    * open interface - API and source codes available, all developers can
    support different phones and add applications to MOBILedit!
    * smart-card and SIM readers supported via PC/SC standard
    * direct SIM card operations via smart-card readers - full SIMedit! functionality
    * complete MS Outlook support
    * complete MS Outlook Express support
    * transfer of contacts between MS Outlook and Outlook Express, you can easily migrate
    * all paying users can download new drivers, applications and versions from the Internet
    * synchronization of the time in phone with the PC
    o automatic mode
    o manually
    * multi-language support through installable language packages
    * online update system
    * intelligent install/uninstall (you will not loose created data with uninstall)
    * customizable shortcuts in the Framework window for quick navigation in MOBILedit!
    * skinnable design, skin creator available for free
    * user definable sounds for different events
    * user definable device names: you can assign names to phones, SIM cards or readers
    * user definable Picture for phones
    * chess game via SMS
    * You can just click to anonymously register your phone in
    myphonesafe.com database, which helps to protect your phone from being
    stolen or sold.
    List of supported phones
    Changes in MOBILedit! 3.0 11/04/2008 - Now with support for Windows Mobile:
    New features:
    * Support for Windows Mobile added!
    * Improved support for Apple iPhone (1st gen)
    * Fixed possible bug when handling files located on phones
    * Several minor bugs fixed
    New phones:
    - OS Windows Mobile 6.1
    - OS Windows Mobile 5.0
    - OS Windows Mobile 2003 SE
    - LG HB620T
    - LG KF310
    - LG KF700
    - LG KU250
    - LG KU311
    - LG KU380
    - LG KU990
    - Nokia 6124 Classic
    - Nokia E66
    - Samsung SGH-G810
    - Samsung SGH-M150
    - Samsung SGH-M310
    - Samsung SGH-M310V
    - Samsung GT-S7330
    - Samsung SGH-G400
    - Samsung SGH-U800
    - Sony Ericsson W980i
    you can download this at this link below;
    http://rapidshare.com/files/160781334/MO...
    to open the file:
    download and install this first..
    http://www.rarsoft.com/rar/wrar380.exe
My LG Arena KM900 could not be recognized when I try to connect it to PC via USB cable or bluetooth
Do you have the LG PC Suite software installed on your machine? You will need this software to access most of the functionalities in the phone. Please download the latest LG PC Suite(Offline installer) from LG's support site at http://uk.lgairsync.com/cm.dif.DownloadStaticFile.tws?fileSpec=pc_suite The file is around 115 MB in size, so be patient. For more details, check out a similar support page at http://webtrickz.com/download-lg-pc-suite-iv-with-lg-air-sync/
Have a great time ahead. Regards,
Brainiarc7.
Mar 09, 2011 | LG KM900 Arena Cell Phone
LG PC Suite does not detect the LG KS360 phone!
You need to change the usb connection type on the LG. By default it is set to "mass storage", if you change it in your "connection" setting to "data storage" when you next plug in your phone, it will have all of the PC Suite settings available without any grayed out non-functionality.
Jul 22, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Nothing happens when i put my usb cable
common problem is that the USB plug you using is not the right one, as I have a phone that acts the same way certian plugs charge it but one of my plugs the Windows OS sees it as a new divice added to my computer and promps me to nquestion wheather I want to open the device or other options, common mistake is that not all Nextel/Verizion/alltel smart phones use the same USB to mini pin configiration same with digital camera the mini plug may work on a camera but not you smart phone
Jul 03, 2009 | LG Secret ? KF750 Cellular Phone
Manual for my LG KF700
you can get through lg support page and they will ask you to install a software and software will ask you to put your IMEI number and you will be able to download the user manual !
http://au.lgmobile.com/web/web.product.manualSoftwareRF.laf
Best Regards
Jun 26, 2009 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
My usb problem
I hope you have installed the software provided by LG with the phone, if not look on LG website for that download and that should work. Some phone does not work by simply connecting(not plug and play)
Apr 14, 2009 | LG Shine KE970 Cellular Phone
Pc connection
ok, some cpu's have pre installed software installed that will automatically latch on to this phone when you plug the usb cable into the computer. you will have to hook the usb cable to the phone then plug the other end into your usb port located on your pc. most Windows operating systems will find and install the correct usb drivers as soon as the usb is connected. there are exceptions to this rule. your phone software may need to be downloaded of the LG main website.
Mar 07, 2009 | LG Shine KE970 Cellular Phone
Getting music from my pc to my lg kf700 cell phone.
1) Install software and drivers on CD. (Use the default installer settings)
2) Run "LG PC Suite" by double clicking the icon on the desktop before connecting the phone.
3) Follow the software prompts until it says "connect the phone."
4) Once phone is connected (upper panel says "KF700 is ready," click on the contents icon to the right of this left panel. It will open a new window with an explorer like interface.
5) Cut/Copy & paste like in Windows Explorer.
Nov 20, 2008 | LG KF700 Triband 3G HSDPA 3MP A2DP Phone...
PC SYNC OF PHONEBOOK
I CAN NOT SHARE DATA TO MY PC FROM MY LG MOBILE PHONE RD8000 RELIANCE.I PLUGED USB PORT IN MY PC,
THE PC ASK ME INSTALL SOFTWARE CD,WHEN I PURCHASE MOBILE THERE IS NO CD ONLY DATA CABLE,I GOT.
KINDLY GUIDE ME. &REPLY ME
PGOWRISHANKAR,
CHENNAI.
jananiengrs@yahoo.co.in
Oct 18, 2007 | LG KG800 Cellular Phone
Open Questions:
See all LG KF700 Triband 3G HSDPA 3MP A2DP Phone Silver Questions
LG KF700 Triband 3G HSDPA 3MP A2DP Phone Silver Logo
229 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
