Question about LG ALLY VS740 FATHOM VS750 LGIP-400V BATTERY
Battery pin out - LG ALLY VS740 FATHOM VS750 LGIP-400V BATTERY
I have a ezgo 36 it's got power but runs slow, batteries are full
Does your controller have a 6 pin connector on the top? If it does then only 4 pins are wired. Pins 1 and 2 are the throttle, pin 3 is reverse and pin 4 activates the controller.
First I would check the batteries under load. then check voltage from main negative battery post to pins 3 and 4. Should get approx. 15 volts going to the ITS throttle and other pin should get 5 volts at full throttle. If you get no voltage at either pin then probably a bad controller. Go to buggiesgonewild.com and search for wiring diagrams, they have a few for download.
Aug 14, 2015 | EZGO TXT Golf Cart Golf
Hi there, I bought a 2007 electra glide fairing w / harmon kardon radio . Which wires on the 23 pin harness do i use for power,ground, & speakers. I have a 99 Kawasaki Nomad 1500 that i installed...
If it is the basic radio then here are the wiring pins for it:
RT FT Speaker - Pin 18
RT FT Speaker + Pin 1
LFT FT Speaker + Pin 16
LFT RR Speaker - Pin 17
Power and Neg pins are Battery Pin 10, Ground Pin 11
Ignition Pin 12
Another Power & Neg pins are Battery Pin 19, Battery Pin 20
These are the Pin Connectors for the stereo.
Mar 14, 2011 | Harley Davidson FLHTCUI Electra Glide...
Want to reset Bios password
There will usually be a jumper near the CMOS battery on the motherboard (watch type battery). If it is two pins, then short the 2 pins together. If it is three pins, move the jumper so that it shorts the other 2 pins together. For example, if the jumper shorts pins 1&2, move it to pins 2&3, then back to 1&2. It is best to refer to your manual when doing this. If all else fails, unplug the system, remove the battery, hold the power button for 15 seconds, and go ahead and leave the battery out over night. Install the battery the next day and plug the system back in. This may cause a CMOS error that will cause you to setup your BIOS before booting.
Mar 13, 2010 | Computers & Internet
Bios password, how do i remove it. I need to change the boot system to install windows.
Unplug the power cord from the power supply.
The fastest way to clear the bios password would be to first find the bios/cmos battery on the motherboard. See the picture below.
Next find the 3-pin bios jumper. Asus motherboards usually mark the motherboard bios pins as, CLRTC.
It will be rather close to the bios battery. Pay attention to the current position of the bios jumper. It is currently set as normal. The jumper will cover pins 1 and pin 2.
Remove the jumper and place over pins 2 and pin 3. Doing this will clear the bios and will reset all bios settings to DEFAULT. Grab a small flat- head screw driver. Gently insert the screw driver slightly under the battery edge to help you to remove the battery. Wait 30 seconds and reseat the battery. Reset the bios jumper back to pins 1 and pin 2.
Reconnect the power supply cord. You will need to enter the bios and re-configure all your settings. Use your motherboard manual to help guide you through all your bios settings. Next time include the model number of your Asus MB.
Happy holidays!
Mike
Dec 19, 2009 | ASUS Computers & Internet
I have old intel 386a MB and am trying to install a battery, there is no battery I think it has disappeared..I can see where it was velcroed to an area on top by the power supply. Can you give me alink to...
There will be two pins on the motherboard (near where you see the velcro, probably) that say BATT and give you a + and a -
The battery is not one of the modern round ones.
Nov 19, 2009 | Intel Computers & Internet
Compaq 8150p bios password need to be reset. Is the cmos battery soldered on or unplugable.
The BIOS battery could be a button type battery or it could be a battery with a plug-in lead.
Oct 08, 2009 | HP Compaq 8510p Notebook
I am getting a Invalid battery sign on my phone. Do I need a new battery/
I found a fix on Yahoo Answers by somebody named Cos.
"Take the battery door off and take the battery out.
On top of the battery (BR50) where the Caution statement is there will be a hollow section to the battery. (you may have to feel for it as it may be covered with a sticker)
Cover this hollow section with tape or wedge a small bit of card between the battery and the location pin so that the pin cannot intrude into the gap. And thats it folks.... my quick fix! I'm guessing that over time the power pins push the battery against this location pin and strech the sticker hence unseating the battery."
It worked for me! I put a small piece of card stock over that indented place, and Scotch taped in in place. I put the battery back in and connected the charger and it reads "charging battery"! Something so simple, after months of frustration with my Razr not always charging!
Apparently the "invalid battery" message appears whenever the battery isn't making good contact with the pins at the bottom of the battery compartment. With the cardboard in there at the top, the battery is pressed down harder onto the pins.
Thanks to Cos for this great easy fix!
Sep 17, 2009 | Motorola Mobility RAZR V3
Battery dead garmin streetpilot c530
you have a battery for the wrong model, I think they also changed the configuration of the same model number so that it had to be returned for proper service.No matter what you do a 3 pin wont fit a 5 pin socket.
Jun 21, 2009 | Garmin StreetPilot c550 GPS Receiver
How do I reset cmos?
You need to located the jumper on your motherboard. Usually located near the battery. Just remove the jumper from the current location and place onto the other pins. You should see 3 pins after you remove the jumper. Pins 1 & 2 might of had the jumper on it. You then need to place the jumper on pins 2 & 3. Do this with the power off. Wait a few seconds and them place the jumper back on pins 1 & 2 and restart your computer.
Mar 28, 2009 | Computers & Internet
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Aug 22, 2007 | Raymarine C80 GPS Receiver
LG ALLY VS740 FATHOM VS750 LGIP-400V BATTERY Logo
19 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
