Question about Car Audio & Video
Toyota unser speaker sizes - Car Audio & Video
I have 4.50 speakers in the front of my toyota carolla and 5.25 speakers in the back can I convert them to a bigger size?
If there is room, you can change sizes. It's easier just to keep the same size and just get better speakers because certain door speakers require specific spacing and room for the magnet of the speaker to hit and retract effectively. But after upgrading to good speakers, you may want to run them thru an amp to get the full potential of the door speakers. If you hook it up thru your head unit it will be 50 watts max to each speaker usually.
Feb 22, 2015 | Toyota Cars & Trucks
Pioneer deh-x36ui. Sound cuts out when turned up
Hello there,
When it cuts out, then if you dont get an 'AMP errror', on the display, then it sounds like your speakers are faulty. Try using a different pair of speakers temporarily to prove if its the Pioneer or the speakers.
If its the Pioneer, then back to base unser Warranty or repair shop.
Sep 15, 2014 | Car Audio & Video
I need the wiring colors for a after market radio harness for a 1997 toyota 4runner withe the premium radio
here to your 1997 Toyota Camry. Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Dark Green
Dimmer Wire: White/Green
Antenna Trigger Wire: None
Front Speaker Size: 6 1/2′
Front Speaker Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: 6′ x 9′
Rear Speaker Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Nov 05, 2010 | Toyota 4Runner Cars & Trucks
I HAVE A 1990 TOYOTA CAMRY AND I NEED A WIRING DIAGRAM FOR RADIO INSTALLATION.
does this help, or do you need more?
1990 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 3 1/2?
Front Speakers Location: Dash
Right Front Speaker Wire (+): Light Green
Rear Speakers Size: 5 1/4?
Rear Speakers Location: Rear Deck
Oct 17, 2010 | 1990 Toyota Camry
Need wiring diagram for 99 Toyota Camry stereo
May 04, 2010 | 1998 Toyota Camry
I want to change my factory installed speakers on the ae100 toyota corolla. I do not know the size of the speaker
for the front door speakers,the size is 4 inches and the rear speakers are 5 and1/4 inches ok. hope this info helps.take care and good luck, manny
Apr 10, 2010 | 1993 Toyota Corolla
2002 toyota rav4, what is ACC on harness
The acc wire is the switched + on this diagram
2002 Toyota RAV4 Car Stereo Radio Wiring Diagram
Radio Ignition Switched 12V+ Wire: Gray
Radio Illumination Dimmer Wire: Green
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Hope this helps
Feb 03, 2010 | Buck Toyota Rav4 2003 Stereo/radio...
Need car stereo color codes for 1996 toyota avalon xls v6
Check this for 1996 Toyota Avalon Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Blue/Yellow
Front Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Rear Speakers Size: 5 1/4" Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Doors
Hope helps (remember to rate and comment this free answeer).
Jan 06, 2010 | 1996 Toyota Avalon
I recently bought a 2005 toyota corolla verso(irish model) is there any way i could get my hands on the audio wiring diagram because i want to fit a parrot bluetooth handsfree kit
2005 Toyota Corolla Car Stereo Wiring Diagram
Radio Constant 12V+ Wire: Blue/White
Power Antenna Wire: Black
Front Speaker Size: n/a
Front Speaker Location: n/a
Rear Speaker Size: n/a
Rear Speaker Location: n/a
rate pls
Dec 10, 2008 | 2005 Toyota Corolla
Toyota corina
1990 Toyota Corolla Car Stereo Radio Wiring Diagram.
Radio Amp Trigger Wire: N/A
Front Speakers Size: 4′
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Rear Speakers Size: 4′
Oct 03, 2008 | 1990 Toyota Corolla
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
