Question about Cameras
The image is black i cant see it well
When i capture an object and transfer the image on the computer the picture can not be seen as normal before the camera got this problem
  • 2 more comments
  • Anonymous Apr 24, 2009
    when i capture an object the image is not seen clear
    when i capture an object the image is not clear
  • benesilla200 Apr 24, 2009
  • benesilla200 Apr 29, 2009
    how to set low resolution on may camera digimaxA400 sumsang 4Megapixel
Dear Bene,
Try capturing the pic with Low Resoultion. Do mention you camera model.
Regards,
Posted on Apr 24, 2009
Hello, Would it be possible to have a copy of Black and Decker vegetable steamer manual?
Black Decker HS1050 Use And Care Book Manual
If you click the tiny thumb pictures, they enlarge to readable size. If this cannot be downloaded, there are tedious ways to capture the images of each page. (Screen shots to snapping pictures with your phone camera and transferring such to a computer if need be.)
Jun 02, 2017 | Kitchen Appliances - Others
SONY DSC-T1 CAMERA WHEN TURNED ON PREVIOS PICTURE SHOW UP FINE ON THE VIEW SCREEN BUT WHEN THE THE SELECT MODE SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO MOVIE MODE THE VIEW SCREEN IS MOSTALLY...
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected. If the CCD Image Sensor is affected, the images captured may be discolored or with lines on it. Even if the CCD is affected, the previously captured images and icons of the Camera will display normally. You may try power resetting the Camera.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also try resetting the Camera back to factory default: The RESET button is located at the lower right side of the control button. To reset the camera just press the RESET button using a sharp-pointed object.
If the issue remains the same, then service may be required.
Thanks for using FixYa.
Mar 01, 2011 | Cameras
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
While taking pictures at normal settings (without zooming), every image is coming blur ,but when we zoom.....then the image is clear. Please suggest how can we correct this setting ?
Maybe you should check the object distance setting in your camera (in FOCUS setting I think). If the camera have this setting, you can choose longer object distance for daily capturing.
Hope this help. (^_^)
Jan 08, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
I cant see the person im taking a picture of on the LCD, its black.
This is due to the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD issue is there in the Camera.
If this happens only with the live view, then try resetting the Camera.
The RESET button is located at the lower right side of the control button. To reset the camera, press the RESET button using a sharp-pointed object.
You may also try power resetting the camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Jul 24, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
WHEN TAKING PICTURES OF MOVING OBJECTS THE IMAGES ARE VERY BLURRY, ALSO SOMETIMES WHEN WE TAKE A PICTURE THE WHOLE PIC IS BLACK ANY HELP?
WHEN TAKING MOVING PICTURES YOU SHOULD BE ON THE RIGHT SCENE MODE. AS FOR BLANK PICTURES WE HAVE FOUND THAT GENERIC SD CARDS CAN CAUSE THIS.
Nov 23, 2007 | Panasonic Lumix DMC-FZ50K Digital Camera
NEF Image will not open - Macintosh
RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Transfering pics on mac
Do the following to transfer your pictures: Connect your camera to the computer. Turn on the camera, and move the Mode dial to Connect mode. From the Applications folder on the computer hard drive, launch the Image Capture program.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Cameras Logo
37 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
