Question about Exercise & Fitness
Healthstream t450 - Exercise & Fitness
Healthstream manual for GS1185T Asteroid HRC Plus. where can i get a manual for it.
Try Googling (Healthstream)(GS1185T)(manual) without parens.
Jun 05, 2017 | Exercise & Fitness
Want to download a manual for the healthstream GS1180T
Your model doesn't seem to be listed on the manufacturer's website. Contact them directly for additional support.
http://www.healthstream.com.tw/index.php?act=contact
Feb 24, 2015 | Exercise & Fitness
Where can I download a manual for a Voyager HealthStream HS9000 (serial: 04091112)Please
Here is customer support for them. Maybe they can point you in the right direction as to where to find a Manual. 1-800-521-0574
Customer Support Hours:
7:00am to 7:00pm CDT
Monday through Friday (except for holidays)
Sep 29, 2014 | Exercise & Fitness
Healthstream manual I have a GE3400T healthstream
go please to www.fitness.manualsonline.com or www. retrevo.com
and download for free.
God bless you
Oct 31, 2013 | Exercise & Fitness
Healthstream Elation HS 2200T - E3 code - incline not working
1) Lube the shaft and gear from elevation motor
2) Tight the connection motor very well.
3) Adjust the potentiomenter from elevation motor
4) Measure the voltage input.
5) Try to RUN the software calibration for diagnose, and troubleshooting see the block diagram.
God bless you
Jun 13, 2012 | Exercise & Fitness
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Mar 16, 2012 | Exercise & Fitness
How can fix my healthstream LS720T treadmill? my healthstream LS720T treadmill after i turn it on it slowly run then it will go faster then stop and will indicate error message E1, what is wrong with it?
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Jul 30, 2010 | Exercise & Fitness
Where can I purchase a power unit for a Dell Dimension XPS T450?
When you say power unit, I imagine you mean the power supply. They can be purchased in different places, such as Best Buy, or probably anywhere a computer is sold. Microcenter is a good store if you have one near you.
The place where I get my PSU (power supply unit) is a website called http://www.newegg.com, which usually has quite nice deals on things, and you can filter through products in a nice efficient way.
If you'd like to know more about purchasing power supplies in general, I'm providing a step by step guide which you can find here.
Hope this helps :)
Dec 02, 2009 | Foxconn 6100K8MA-RS Motherboard
Dimension xps t450 CPU upgrade problem
your lucky if you didnt blow your porocessor. did you adjust the voltages?
Oct 24, 2009 | IBM I System Board (61H2600) Motherboard
Exercise & Fitness Logo
62 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
