Hard disk DRIVES PASSWORD
I need to set a password on my hard drive partitions so that i can make my files private and restrict users to not to copy or paste files in it. can i do this? Please help Regards
  • 83 Answers
Right click on the partition select properties. go to security menu. select the users and then edit or modify what they can do. you cant really place a password on the partition. but if you have a user password for your pc you can also control what they can and cant access that way too.
Posted on Apr 24, 2009
OS Hard drive missing
Using Recovery Partition
The Recovery Partition quickly restores your Notebook PC's software to its original working state. Before using the Recovery Partition, copy your data files (such as Outlook PST files) to USB storage devices or to a network drive and make note of any customized configuration settings (such as network settings).
About the Recovery Partition
The Recovery Partition is a reserved space on your hard disk drive used to restore the operating system, drivers, and utilities installed on your Notebook PC at the factory.
Sep 12, 2013 | ASUS Computers & Internet
Changing partition on Verbatim 8Gb drive
You need to remove ALL partitions, define ONE partition, and then reformat as FAT32 for multiple system compatibility. there's a partition size limit for FAT3.If you hit the limit, then make TWO equal size partitions
Oct 11, 2008 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Tip
Hard Disk Data Recovery
Definition of Hard Disk: Hard Drive is a storage device where you can store any types of data and file. Hard Drive is available as external and internal device. We know PC storage device as internal system Hard Disk. When you save data or install programs on your computer, the information is typically written to your Hard Disk. The Hard Disk is a spindle of magnetic disks, called platters, that record and store information. There are several interface standards for passing data between a Hard Disk and a computer. The most common are IDE and SCSI. Hard Disk is made of one or more aluminium or glass platters, coated with a ferromagnetic material. Most Hard Disks are found as Parallel ATA (PATA), Serial ATA (SATA) or SCSI device.
Difference with Floppy Drive:
The term hard is used to distinguish it from a soft, or floppy, disk. Hard Disks hold more data and also faster than floppy disks. As an example a Hard Disk can store anywhere from 10 to more than 100 gigabytes, where most floppies have a maximum storage capacity of 1.4 megabytes. Floppy is more risky device than Hard Disk for losing data.
Problem with Hard Disk:
Most common problems of Hard Disk which may arise anytime are Booting problem, OS Installation problem, Hard drive crashing and another Hard Disk not showing original space or not showing partition etc. But in every case the risk is loss of data. In some of cases formatting and reloading of Operating System can recover your Hard drive and make it useful but formatting can recover a blank Hard Disk only without data. But you have to recover Hard Disk with data, so formatting is not possible.
Data Recovery:
Data recovery is the process of retrieving back data from the damaged media. The damage of storage media can be physical damage and logical damage. The data is retrieved back by recovery experts after determining the type of the damage caused to the storage media. Most of cases data recovery is important and formatting is not possible there. So that I need to choose another way for solution of this type of problems of Hard Disk. The first and secure way to recover a Hard Disk is using data recovery software.
Recover Data from crashed Hard Disk: Power surges, Software Corruption or Malfunction, Hardware or system failure, Natural calamities, User errors may crash your Hard Drive. Data recovery software helps to retrieve or recover the data from the crashed hard Drive. Data recovery software gives an easy and Graphical User Interface with less difficulty so that the data can be recovered easily. The recovery software helps to recover the data and restore them on a second Hard Disk, the Hard Disk being connected to the computer and recognized by the BIOS, the recovered data can be stored on a safe location on the second disk.
Logical data recovery: In a data loss situation when the Hard Drive is perfectly fine and the BIOS recognizes the Hard Drive but reports a read error, logical data recovery technique is very helpful. Here the files that are damaged or corrupted by any user error or virus attack are rebuilt rather than repairing the Hard Drive.
Fragmentation: When the FAT entry is lost during accidental file deletion, formatting or partition deletion that particular block of Hard Drive becomes inaccessible. Some data recovery software makes an attempt to rebuild the files without a FAT entry. This technique is very efficient if the file size is smaller than the clusters size. But it is inefficient in recovery the larger files.
Data Recovery from deleted partition: Partition is allocation of memory in different sections. Each partition will be like separate disk drives. Partition is very use full when the user is using operating systems more than one. Usually after formatting the disk it may not be able to recognize a partition because of accidental deletion of the partition table or by virus infection. The partition is not actually deleted; it can be recovered by using recovery tools and copy the data present in the partition to the required destination. Formatting the drive erases a large amount of data present on it, but not all the data. The recovery of the data depends on the fragmentation of the file system as the parts of files are being placed on different places in the drive. The data recovery software will assume that files were not fragmented and stored in continuous clusters. If the partition was formatted using different file system, then recovery process will be very complicated.
Another Data recovery process: If you don't have any data recovery software you can try another process to recover data. Attach the Hard Drive with another system in slave or second SATA.If detect the drive then boot to the first Hard Drive and use the bad Hard Drive as secondary. Then you can copy the data from the second drive to first drive easily. Here have another process to recover data from a crashed Hard Disk. But it is so risky, and should not try to do this for an inexpert person. First pack the Hard Disk in a bag properly where moisture can't attack. Now freeze it upto get chill. After freezing quickly attach with a system in secondary, and copy the data within the Drive will come in room temperature.
So the most secure process to recover data from a Hard Disk is to use data recovery software. It is available in market.
on Mar 18, 2011 | Computers & Internet
How to unlock a partition on a flash drive
Hidden partitions on hard drives and USB flash drives store files, recovery and utility software. Many personal computer manufacturers use a hidden partition for the recovery software and no longer ship software CDs. Some people use hidden partitions to store files, which contain sensitive, illegal or private data. Since most USB flash drives are marked with the drive , you can check for differences between this marking and the capacity reported for the drive. A Any significant disparity may indicate the presence of a hidden partition.
Log on to the computer as an administrative user. Click the "Start" button. Select "Control Panel." Double-click the "Administrative Tools" icon. Open "Computer Management." Click on the "+" beside "Storage." Select "Disk Management." The hidden partitions do not have drive letter assignments and are shown in the "Disk 1" or "Disk 2" areas. The "Disk 0" area is usually used by your boot drive or the C:/ drive. A read-only partition on a flash drive may show up in the "CD-Rom" area. Step 4. Right-click on the hidden partition. Choose "Change Drive Letter and Paths." Click "Add." Select a drive letter to use. Click "OK." Click on the red "X" in the upper right corner of the "Computer Management" window to close it. Double-click on "My Computer" on the desktop. Double-click on the drive letter you selected in Step 4 to open the drive and view the files. Hope this helps.
Jan 17, 2013 | Kingston Electronics - Others
I WOULD LIKE TO RESTORE TO FACTORY SETTINGS TY
You will loose all data you have put on the computer. When you turn it on right at the beginning there is a black screen and there are a few f key options.
They will flash up with the option when you turned it on, before windows kicks in. Take a look at the user manual to find out for sure.
Press the correct f key before windows starts up, then go through the menus in setup (it will look all crappy and dos like) and find restore factory settings (or something like that) and click yes.
It's a great feature, and will completely kill any virus or **** problems you have had and couldn't get rid of.
Hope this helps. I would appreciate your feed back as I do this for fun not pay.
Oct 01, 2011 | Acer Aspire One PC Notebook
I forgot my password to open this jump drive.My computer will not let me gain access to any of my files on the disk. What can I do to access it again?
Retrieving a forgotten password on a Cruzer Enterprise drive How do I recover the password on my Cruzer Enterprise drive? Password hint
If you set a hint when you enabled the password protection, click Hint in the log in window to display the hint you entered. If you did not set a hint or still can not remember your password, you can click Forgot Password on the logon window and choose a new password. This will reformat the drive.
Reformatting will delete all files and applications in the user-accessible removable partition.
Password attempts
There is a limit of 10 attempts (default) before the drive is locked and no further access is possible. During this process, you MUST change the password and reformat the drive. This is an important security feature, protecting data in lost devices from brute force hacking attempts.
Cruzer Enterprise drive managed by CMC (Central Management and Control)
A drive managed by the Cruzer Enterprise CMC software can be unlocked remotely by the System Administrator when it is inserted into an online computer. The System Administrator can unlock the drive remotely even after the maximum failed password attempts has been reached. The user must then choose a new password. Data stored in the removable partition will be preserved.
If the device is managed but in an offline computer, the System Administrator can send the user a one-time unlock code. The user must enter the code then choose a new password. The existing data on the removable partition will be preserved.
hope this helps
Feb 27, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Drive only reports 56gb to partition - missing 100gb! How do I access the remaining space?
Click Start
Right-mouse click "My Computer".
Click "Manage".
Expand the "Storage" part of the tree.
Click "Disk Management".
View the diagram for your disk-drive.
Does it show the 56GB partition, followed by 100GB of "unallocated" space,
or does it show one (approximately) 160GB partition?
If the former, backup all the files in the partition (copy to an external disk-drive, or copied to DVD-recordable disks, or to another computer).
Then, use "Disk Management" to delete that "small" partition, and to define a new partition that "spans" the entire volume, and to initialize the partition.
Then, copy the "saved" files back onto the drive.
Dec 18, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
Ntldr missing, trigem dreambook, windows2000 P3 600Mhz
Windows 2000 users If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the rootdirectory of the primary hard disk drive. For example, C:NTLDR andC:NTDETECT.COM should be the locations of these files on manycomputers.
  • Please keep in mind thatthese files are hidden system files, if you need additional help withviewing hidden files in Windows please see document CH000516.
Oncethese files have been copied to a floppy diskette reboot the computerand copy the NTLDR and NTDETECT.COM files to the root directory of theprimary hard disk drive. Below is an example of what commonly should beperformed from the A:> drive.
copy ntldr c:
copy ntdetect.com c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Jan 13, 2010 | Microsoft Computers & Internet
Hello,pls I am having problem with my laptop IBM R30. Whenever I turn it on,It displays NTLDR file missing.MY mail is abincojay@yahoo.com
Windows 2000 users If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive. [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers. Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516. Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive. copy ntldr c: copy ntdetect.com c: After the above two files have been copied, remove the floppy diskette and reboot the computer. Windows XP users Insert the Windows XP bootable CD into the computer. When prompted to press any key to boot from the CD, press any key. Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer. copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\ Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Jun 05, 2009 | IBM Computers & Internet
Hardrive help!
Unfortunately this is a little like closing the gate after the horse has bolted. as there is a possibility that the files you copy onto the drive may be infected with the virus. however, It is usuall that External drives are not configured for use (as the application for the drive's use is varied) it is up to the user to partition and format the drive. if you are using win XP it sh a case of connecting the drive (the hardware should be detected) install drivers if neccesary. Then the Disk needs to be prepared, Right Click "MY Computer" and select MANAGE. This should take you to a management window. Select "Disk Management" Under "Storage" from the "tree" on the left of the window. You should now see on the top right a list of named partitions, and below you should see the partition maps of the drives connected to the system. your 100 GB disk should be shown here, as an unformatted unpartitioned disk, once this disk is selected you can partition it any way you like however most choose a single partition, once the disk is partitioned you need to format the partition, FAT32 is the most portable. once this is done the disk should now have a Drive letter, This can be changed if required. yould now be able to access the disk :) `
Aug 16, 2007 | Seagate (ST3100203U2-RK) (ST3100203U2RK)...
Computers & Internet Logo
David Payne
David Payne
