Question about Harman Kardon AVR 130 Receiver
I own a HK 130 and i gott no sound. it workt when i shut it off bute whene i started it i gott no sound plz help me
    Problem Solver:
  • 6 Answers
HK's must be programmed to output sound. It's probably back in the default mode and you need to go thru the menu for setup of sound output.
Posted on Oct 15, 2013
Working only after 10 minutes harman kardon
I dont know what to say bute it works bute i cant gett any sound from it it whas working and after i turnd it off then when i started it came no sound from it ?
Jun 18, 2014 | Harman Kardon AVR 130 Receiver
1995 grand cherokee rouring noise from front driver side when excelerating
Have the front CV joints inspected and lubricated if applicable. Most shops should inspect this for free. Hope this helps.
Dec 23, 2011 | 1995 Jeep Grand Cherokee
I have a harman kardon AVR 132 and have just purchased a Samsung UA55D7000. I am running HDMI from the sammy to my ps3 for video and then an optical cable from the ps3 to my HK for audio and im having...
Hi, You might want to run your ps3's hdmi into your hk, as I'm sure it has hdmi inputs. Using your hk as the audio /visual switcher may resolve this issue-and by the way the hdmi cable has audio built in. I hope this was of some help and thanks for choosing FixYa, good luck Prodzilla.
Apr 20, 2011 | Harman Kardon AVR 130 Receiver
Which jack do I use from my computerr and which jacks do I use on my H K avr 130
The audio jacks from the pc and the RCA audio inputs from the HK.
You will need 3 special cables: ones that have one 3.5 minjack at one end and 2 RCA connectors at the other.
May 27, 2010 | Harman Kardon AVR 130 Receiver
How can i make the sky remote control th avr 130 (harmon kardon)
Does the sky remote have a code for the HK receiver? If it does, use that code to program it. Most other remotes won't work completely because this receiver uses a seperate button to turn it off...
Mar 14, 2010 | Harman Kardon AVR 130 Receiver
I cannot install the software for my hk-750 bluetooth device.it will not uninstall what is already installed and will not install completely.what can i do.thankyou
go to my computer and right click on my computer go to properties and look for device manager open it up and look for your device and after you find it do a right click on it and look for somthing saying delete or remove and say yes and then it will confirm removal of the device after it has said it has been uninstalled than close out of all programs and restart the computer once started the new hardware found w ill pop up and reinstall it and confirm that it is working and if not it will tell you that there is a problem normally it is a device driver that is not updated good luck!!!
Aug 09, 2008 | Computers & Internet
Channel out.
The DSP board is defective. You need help from a HK tech
Mar 18, 2008 | Harman Kardon AVR 130 Receiver
Harmon kardon avr 125 shuts down
If you want to fix it:
It must be a contact problem arount the power switch, power cable, fuse or the condensator area.
Maybe you can se a black color on the board.
And checking the solderind points with a magnifyer can help too.
Thats all from that distence.
Nov 11, 2007 | Harman Kardon AVR 130 Receiver
No location shows
BNG stands for 'British National Grid'
  1. Go to the Setup menu
  2. Select Units
  3. Change the Position Format to hddd°mm.mmm'
Aug 19, 2007 | Garmin eTrex GPS Receiver
Olympus FE-130 Video Playback has no volume..............PLZ HELP!!!!
well did u use zoom while u made the videos???? if u did forget because the camera while doing zoom doesn´t record sound, u didn´t use zoom, probably the camera microphone needs to be replaced.
Feb 09, 2007 | Olympus FE-130 Digital Camera
Harman Kardon AVR 130 Receiver Logo
100 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
