Question about Electronics - Others
Xxxxxu167 controller usb
Usb flash memory doesn't work
My pendrive doesn't work speedy
Then buy one that's USB 3.0 and a computer with USB 3.0.
Mar 30, 2013 | Electronics - Others
How to access lexar memory card without loker,my memory card loker has been breaked
If it's still a usable card, I would suggest just placing it back into your camera and then connecting it via USB cord.
If that doesn't work, check if your computer has a slot for SD cards. If it does, try placing the card in one of the slots gently.
Sep 15, 2012 | Lexar Professional High-Speed 2GB Secure...
Ps2 not recognising memory card
Try formatting the card. If formatting the card doesn't work, either the reader inside your PS2 is broken, or the card itself is damaged somehow.
Jul 05, 2012 | Sony PlayStation 2 8MB Memory Card - Black
Transcend 16 gb pendrive is not recognised
Right-click on COMPUTER. Select PROPERTIES, Go to DEVICE MANAGER. Under UNIVERSAL SERIAL BUS CONTROLLERS, check all the USB ports to see if they are working properly. If the USB PORT in which you have inserted your pen-drive, is showing an error, right-click over it and select PROPERTIES and make a TROUBLESHOOT.
If this troubleshooting doesn't help you, use another computer to check if your Pen-drive is working there. If the problem persists, go to the manufacturer's service center and ask for a replacement or repair.
Hope this helps, Mrityunjay.
Jun 25, 2012 | Electronics - Others
My memory card display 1mb and formaing the card please help me
Hi, connect your SD with a PC and run a virus scan with an updated anti-virus.
If it doesn't work,try formatting it.
good luck!
Sep 11, 2011 | SanDisk 2GB microSD Memory Card
I formatted my 4GB TDK flash drive, now it show me only 3.95MB memory only. how can i recover it back to 4GB memory space, now it doesn't show me even the flash drive lock status & that screen when...
there is an overhead for the space on a drive, the system needs a File Allocation Table and other administrative information, so the total 4 GB is usually not 100% available. It would not work properly without this "administrative" space.
Jul 15, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
My memory card does not format and has msdc error.how can i format it in windows xp because when i try to it brings windows can not format the disc.
Hi ,JHONPIX
If your computer affected by virus,then your memory card will not show in the pc .so you will install it to another pc,and format it .Flash drive can not recocknize,becayse there are some reason .
  • VIrus affected
  • Sometimes when a flash memory stick or USB external hard drive fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory USB hard drive device appears to malfunction it may be possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted then it will indicate that it is Healthy.
If this doesn't work then it is faulty.
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
hope it will help you
Apr 25, 2011 | Computers & Internet
Electronics - Others Logo
48 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
