Acer gz5 when hooked up to my flat screen tv it won't show a picture I have tried pushing fn and f5 but still a black screen
    Sergeant:
  • 486 Answers
If the FN key doesnt work then may some of your utility dirvers are missing however you can manually configure it by going to screen resolution properties and chose the option that what to do with second screen.
Posted on Oct 14, 2013
4 Suggested Answers
Wybmasiity
  • 6 Answers
SOURCE: Acer Travelmate 8100 when pressing fn and f5 nothing happens
I found the problem. The drivers needed for the keyboard are:
Windows\system32\DkbFltr.sys
provided by Dritek System Inc. Version 1.3.00
Windows\system32\8042prt.sys
Windows\system32\kbdclass.sys
I looked at the current drivers for the keyboard. Somehow the keyboard must have been reinstalled or drivers got corrupted. I did a system restore to a time before I installed some new hardware and drivers. Then I looked at the drivers for the keyboard through the control paned =>
keyboard =>
hardware Tab =>
Standard keyboard =>
properties =>
Driver Tab =>
driver details.
And found that the drivers were different except for the last one in the above list
You can update the drivers. Do a search for the first one in the list and the second one in your windows directory(search for hidden files and system files). I found the files in my system32/drivers directory. You may also find it on the disks that came with the Acer.
I have looked on-line for the first one and could not find it. perhaps a better search term swould find it. I also looked on Ace rs site.
Good luck,
Wybmasiity
Posted on Mar 22, 2008
SOURCE: Laptop's dark screen is pissing me off
Hi, i have an Acer 5100 and the screen is really dark... can only just make out the screen. I have tried the fn key trick with no luck. I have replaced the inverter and also the screen.... again no joy. Can someone help me please :)
Posted on Jul 20, 2009
SOURCE: acer travelmate 4200 'F5' key not working
Following an advice in this forum I loaded the launch manager for the travelmate 6592, installed it and It put working on the silver P key of the laptop, i.e. the launch manager, and at the same time the fn+F5 key started to working on again. For a long time this key was disappeared from me laptop, just the same time that the fn+F5 key didn`t work.
Posted on Sep 22, 2009
Acer GZ5 will not show picture on my flat screen tv
Check if the cables are setup correctly.
Next step, choose the right source from the TV remote (i.e. HDTV1)
If you still can't get picture, try to lower the resolution on the PC - the TV might not be able to see the full res. Set it at 800x600 and see if that helps.
Last step, if still cannot see image, try to update your PC video drivers and try everything again.
Oct 14, 2013 | Computers & Internet
I'm trying to figure out how to make the display show on a larger flat screen monitor. Any help would be appreciated. I found where you would change the resolution under Control Panel and it showed 2...
if you are trying to use a lap top to display on a Flat Screen TV, then hook the laptop to the TV with a 15 pin D cable or a HDMI cable(what ever connector you have in common), the switch the TV to PC and then look on your laptop for an ICON that shows a TV set and acomputer screen together. On mine it is hold down the function key and tap the F6 key( Fn+F6) on some computers it is the Fn+F5 key, this switches the display from the laptop out to the TV on to the Aux PC input.
Jan 22, 2011 | Computers & Internet
I have an Acer Aspire netbook that I want to hook to a projector. I finally got the right cord to hook it up, but it will not display on the projector screen.
One of the F keys will toggle between the Laptop Screen and the VGA output - look at the F keys and see if one has a picture of a screen often F4 / F5 - needs to be used with the FN key
FN key+ F4 Key (Or which ever key has the symbol on)
It will toggle between <laptop screen only><laptop screen and VGA output><VGA output only> Not necessarily in that order
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 30, 2010 | Acer Aspire One Netbook 8.9" Notebook
Connectted to big screen monitor, the button Fn and F5 not work. what is the reason?
What is the screen Resolution set to on your current Display?
Try setting your current Display to 1024x768, then try the FN+F5 key
this might work. IF your current Display is set to high the other screen might not show any picture at all.
Feb 25, 2010 | Acer Computers & Internet
Cannot connect acer extensa 5220 laptop to hd tv via aga
Hold down Fn and tap F5, you may have to tap F5 a couple of times to get it to switch screens.
Regards.
Feb 19, 2010 | Acer Computers & Internet
The picture on my laptop doesnt want to show on the screen through the projector, it only shows the acer screen
start your laptop first and then your projector------try to press fn in laptop with combination of f3 or f5 or f7twice every time you try it.
Dec 27, 2009 | Acer XD1150 DLP Projector
I have an Acer Aspire One MiniBook. I once had it hooked up to another VGA monitor. Now when I log in it shows the ACER logo and the XP screen then turns black. i can hear the windows start up sound and...
try pressing the fn key and F5 or look for 2 monitors on one of the F keys its F5 on my acer 5520 that switches display modes also try going into the bios i think its F2 as soon as you turn on the laptop press F2 or look on the screen for the key to enter setup or bios and restore everything to default save settings restart
Nov 06, 2009 | Acer Aspire One AOA150-1635 Notebook
I have an acer aspire 5100 and am trying to vue my screen through my tv. I have a vga lead connected to both but my fn F5 button doesn't seem to switch my screen from 1 to the other? can you help
you need do
1) set your TV interface to PC port
2) connect the cable (you are sure it is a good condition) between laptop and TV
3) power on laptop boot system and then hold Fn and click F5(screen change), maybe click 1 or 2 times if you see LCD black and then next to TV screen.
hope help you do it well
May 11, 2009 | Acer Aspire 5100 Notebook
ACER cracked screen..external monitor???
Hi there.
The keyboard toggle you are using is the correct one.
Sometimes you have to hit Fn + F5 a couple of times to stay on there is no real set time. Make sure Fn + F6 is on so the laptop screen stays on.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
