Question about Ovens
Fan not turning in baumatic cooker - Ovens
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Is the element hot?
>> check fan motor
> replace fan motor
Posted on Oct 18, 2013
My beaumatic oven fan light and heating up is not working but clock and timer is fine,can any one help
If you have a problem with your Baumatic B180 cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jan 20, 2015 | Baumatic B180 Electric Single Oven
Ywhy does the heat not come on when the fan is switched on,every thing else is working?
Sounds like your round element has gone oc (open circuit)
Isolate the cooker at its mains switch
open oven door
unscrew back panel (normally 4 screws & some times the light glass may need unscrewing)
take off panel, you will see the fan surrounded by a round element,
if its out of shape or in bits, then it needs replacing
you can also take off element detach the wires and test for continuity with a meter if you know what you are doing. Only do this if you have a degree of electrical knowledge!
Jul 16, 2014 | Baumatic Ovens
I have a baumatic cooker gas hob with an electric double oven model bt2730ss and i'd like to know how to remove the fan element? I took the plate off and undid the nut that holds the element in. Could...
hi if u have taken out the two screws then the element should be just sat there. make sure its turnt off at mains b4 going any further..... now pull element towards you slowly u should see the wires take one off at a time and swap over to new element ... when done put back together ... if u loose a wire down back just pull oven out and take back cover off to get access...
Feb 27, 2011 | Baumatic Ovens
Bottom oven on my cooker has stopped working, it trips the electric after 7 mins running but the top oven is fine why
hi there the most likely cause for this is the element going into a fault condition as it warms up and expands your best bet is to replace the element which isnt that hard to do yourself, you might also want to check that the fan is spinning freely as it may stick and overload
Oct 16, 2010 | Baumatic B905SS Stainless Steel Electric...
Good evening i have a BT2431SS baumatic cooker,i have no heat in main oven yet i have the hob and the grill that work ok.
If it is a fan assisted electric oven, and the fan is wrking o/k, then it will probably be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Baumatic Ovens
Fitting this cooker into an under bench unit
Yes
Should be no problem as long as you have some kind of vetilation.
Jul 27, 2008 | Baumatic B904SS Stainless Steel Electric...
Oven not heating up but fan and light on
oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
