Question about LG DS8421P DVD Player
Lens number want lens number as i want to change the lens..
  • 80 Answers
502w
Posted on Oct 15, 2013
How do I switch to an aperture higher than f/32 on my nikon d3000?
Yes. Just lock the lens aperture ring at its smallest setting (largest f/number). If you need to change the aperture, change it from the camera body by turning the command dial, the same way as with a lens without an aperture ring.
Jul 18, 2014 | Sigma 50mm F2.8 EX DG Macro Lens For Nikon
How to remove number plate lens cover on volvo s40
dont do that....
its glued
jast take a flaxible magnet and pull it out
Dec 16, 2013 | Cars & Trucks
Nikon d80 lens
Turn the aperture ring on the lens to its smallest setting (largest f/number) and lock it if it has a lock. If you need to change the aperture then do so on the body, the same way as when using a lens without an aperture ring.
Mar 27, 2013 | Nikon D Cameras
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
Broken tail light lens, where can I get a replacement lens and how do I change the lens?
Call your local auto salvage dealer or I can give you aftermarket suppliers and salvage dealers phone numbers.
REMEMBER TO RATE THIS ANSWER
THANK YOU
Dec 26, 2010 | 2004 Honda Odyssey
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
When you turn the printer on the number E212 will appear and the printer says Switch the power off and on again. I did that several times getting the same reply. There is no manual with the printer for...
  1. Remove the glass
  2. check the Lens Y home position sensor (clean it properly), or replace it
  3. check the Lens Y Motor
if you change the sensor and the error code still, you need to change the Lens Y motor. this is the picture of the Lens Y Motor and Lens Home position Sensor (good luck) mabroukmedal_35.jpg
Dec 10, 2010 | Canon NP 6230 Copier
Using a Nikon D200 with a new 18-200mm lens. When
HI I AM SAGHA CAMERA REPAIRER FROM MUMBAI,FIRST READ YOUR LENS SPECIFICATION CAREFULLY IT SAYS 18-200/3.5-5.6 IT SHOULD BE READ AS AT 18 MM IT IS F3.5,THEN AT 200 MM IT WILL BE F5.6 THATS WHY IT MOVES APERTURE FROM 3.5 TO 5.6.IT IS QUITE NORMAL. REPLY ME IF YOU ARE SATISFIED WITH MY EXPLANATION.
Jul 30, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
The f number is constantly showing 95 and i can't change it. the pictures are coming black. sometimes there is no f number, instead of it, a sign like f-- is showing. what to do????
This error means the lens is not connecting properly.
Remove the lens and give the contacts (silver pins) a quick clean. Also wipe the camera body contacts.
This should fix it.
Jul 04, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon f65 slr
annlane123,
Since you have been taking photos in one of the other modes, say shutter or aperture mode you may have changed the F-stop in the process, check to see that the ring is set back for auto mode by aligning the red numbers (ususally F-22) to the white dot on the lens, that way when the camera in auto needs more light the lens will open enough to allow it. Test it with the metering in the viewfinder you'll see it as you change to each number. Remember both the lens and camera are communicating with each other. Not allowing the shutter to release is kind of a safety.
randy320sgi
Aug 27, 2008 | Nikon F65 35mm SLR Camera
LG DS8421P DVD Player Logo
Computer Repairing
Computer Repairing
